Question about Route 66 ROUTE EUROPE 2004 (601184407502) for PC
Route 66 Mobile 8 Windows Mobile - software update creates error
When the upgrade (Australia) is loaded and the application is re-booted on my Samsung Omnia, the following error message appears:
"String resource initialisation error. Please reinstall the application".
Re-installation doesn't work.
To upgrade, use the website version of Route 66 Sync rather than the version on the disk or the upgrade file from the website, both of which do not work. The website version works in conjunction with Microsoft ActiveSync.
Posted on Dec 28, 2008
Hi there, I hope someone can assist me with this
Sometimes it helps to upgrade your OS ...from say (a)4.2.0.442 to say (b)5.0.0.1015. I was getting tons of uncaught applications on my 9550.I upgraded from (a) to (b) and the problem is gone.Along with battery issues.Can you try that?Your carrier must have OS upgrades for your device on their website.Good luck!
Aug 15, 2013 | RIM BlackBerry 7100G Smartphone
Cannot read disk
"A disk read error occured press Ctrl+Alt+del to restart " FOLLOW THE BELOW INSTRUCTIONS TO RUN DELL DIAGNOSTIC ON INTERNAL HDD Open the Dell Diagnostics on either your hard drive (F12) or from the Resource (Drivers and Utilities) CD. Running from the hard drive is the preferred method of using the diagnostics. If problems occur when running from the hard drive or there is no Utility Partition, the diagnostics can be run from Resource (Drivers and Utility) CD. From your hard drive: Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. When the boot device list appears, highlight ?Boot to Utility Partition? on desktop systems or ?Diagnostics? on portable systems and press . Note: On portable systems, PSA will be executed first. When PSA completes, press any key to load the Dell Diagnostics.? Go to step 2. NOTE: If you receive a message stating that no Diagnostics utility partition has been found, follow the instructions on the screen to run the Dell Diagnostics from your Resource (Drivers and Utilities) CD. From the Drivers and Utilities CD ResourceCD: Insert the Drivers and Utilities CD into the CD drive. Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. NOTE: This feature changes the boot sequence for one time only. On the next start-up, the computer boots according to the devices specified in the system setup program. When the boot device list appears, highlight IDE CD-ROM and press . Select Boot from CD-ROM option from the CD boot menu. Select Run the 32 Bit Dell Diagnostics numbered list. If multiple versions are listed, select the version appropriate for your platform. Go to Step 2. After the Dell Diagnostics loads, the Main Menu appears. Click the button of the option you want. If a problem is encountered during a test, a message will display the error code and a description of the problem. Write down the error code and problem description and follow the instructions on the screen. If you can not resolve the error condition, contact Dell. If you run a test from the Custom Test or Symptom Tree option, click the tabs above the right window for more information: When the tests are completed, if you are running the Dell Diagnostics from the Drivers and Utilities CD, remove the Drivers and Utilities CD. Close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and restart the computer, close the Main Menu screen. Regards Sunil Dsouza
Dec 04, 2009 | Dell Dimension 2400 PC Desktop
Samsung Omnia - Does not display caller name
Put names to phone instead to SIM, and use international format (eg. +44789...)
Jul 29, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Phones rebooting
there are many different problems that can cause the IP phone re-booting on a network, apart static.
Check if there are errors being reported by the pbx.
A common cause is an IP conflict due to a DHCP problem.
Check if the rebooting phone is connecting to data VLAN and then rebooting in voice VLAN, that means that is getting the right IP, and therefore is no DHCP problem.
If the rebooting phone is booting into vlan correctly, it can still be a different phone, with a bad MAC address, getting the wrong IP , and causing a different phone to reboot.
In that case you try isolating the problem by disconnecting switches one by one, and if problem stops, find the bad unit on the specific switch.
Mar 23, 2009 | Lands Phones
Three errors recently occuring, causing som problems
Try to remove that on the boot.ini on your system.
You can do that by following this.
1.Click Start>Run>type "msconfig" (without the "") then press enter, On the new window that will comes up that is the msconfig window.
2. uncheck the EABServ.exe on the startup or on the boot.ini. then click apply and restart. I'm not sure if the EABServ.exe is a virus or a malicious file that is not recognize by your antivirus but I know its not a microsoft application.
May 13, 2008 | HP Pavilion dv1000 Notebook
Route 66 ROUTE EUROPE 2004 (601184407502) for PC Logo
1,464 people viewed this question
Top Route 66 Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Route 66 Computer and Internet Expert? Answer questions, earn points and help others
