Question about RCA P52937 52" Rear Projection Television
Picture no sound
I have a RCA p52937 52in projection screen the picture is perfect, changes channel's, but has no sound.
  • tiiaa1 Apr 30, 2009
    I have this same problem but I looked on the back of the tv and i cannot find this switch he mentioned. i even took the back off to see if i could find a switch...no luck. did u figure out what was wrong with yours...did you get it fixed?
    Thanks
  • 585 Answers
If you will look I bet you'll find a switch on the back of the TV for internal or external speaker. It's probably gotten switched to EXT. somehow.
Posted on Dec 27, 2008
Rca 32" lcd tv.vertical lines on entire screen,no pix.
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
www.youtube.com/watch?v=PWoz_-3OHIMJan 25, 2013 - Uploaded by Tampatec I have a LG 42PM4700-UB plasma tv that just went black. The red power .... I have a RCA 32 inch it has no sound or picture !Just a light blue ...
Sep 09, 2015 | RCA L32HD31 32 in. LCD HDTV
The picture is bigger than the screen... Picture is cut off and when I unscrewed the back of the tv I could see that the picture was showing perfect but it was to big for the screen... There's not a way to...
Have you tried hitting the format picture button on your remote control. Seems the picture is in zoom mode. If you have a cable box for HD Channels then look on the remote for a button (format) or Screen size.
Nov 11, 2009 | RCA P52960 52" Rear Projection Television
No picture good sound good lamp can change channel
I have the exact same TV and have had the exact same problem. I talked to a TV repairman who said it has to be my deflection board. I just found this out today so I am looking all over the web for a deflection board. I hope this helps! Tyson
May 31, 2009 | RCA M50WH185 Television
50Inch RCA dlp Scenium
Its the color wheel assy. Its changing speed due to worn bearings. You may also hear a hum coming from the rear of the TV. Seek an RCA authorized service center to resolve this.
michtech
Feb 12, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
RCA P61940 No picture but sound ok.
I've anwsered on your premium post.
Try using the audio/video inputs to bypass the RF converter (tuner).
Jul 04, 2008 | RCA P61940 61" Rear Projection Television
Rca projection tv has no picture or osd
Check the bulbs. If one is burned out, you will get this problem. The bulb is easy to change but will run you about $300.
Feb 10, 2008 | Televison & Video
RCA 52" projection
When you are changing channels and the screen normally blanks to black between channels, do you instead see a reddish screen?
Did you check your event codes?
Dec 05, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rear projection snow
Bad primary tuner==can be replaced,or==by-pass by using video inputs.
Aug 26, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tuner problems
it sound like the tuner to me here is rca part# for the tuner 264658 abour $70.00. good luck
Dec 26, 2006 | RCA D52W19 52" Rear Projection Television
RCA P52937 52" Rear Projection Television Logo
90 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
