Question about Refrigerators
Frig temp not stable
The frig. temp drops (digital) to freezing 24/7. Have to adjust constantly. Food freezing
  • the_parkers Dec 27, 2008
    Thanks. How long should the frig. stay unplugged?
    Problem Solver:
  • 14 Answers
Chances are your control dial is bad, your thermostat has gone bad or your compressor has freezen over. As bad as it may seem to trouble shoot this, unplug your frig., to "defrost" then plug back in. If this does not solve the problem, you may need to replace the thermostat or control dial.
Posted on Dec 27, 2008
FRIGIDAIRE SIDE BY SIDE FRIDGE SIDE TOO WARM
adjust the temp on the freezer setting where it links up with the frig'...
Feb 03, 2013 | Refrigerators
Hotpoint frig cxs25gr freezing food
Have you tried adjusting the cooling level? Does it still freeze on other settings? Is this a new or older refer?
Jul 28, 2012 | Refrigerators
Kenmore side by side Model #106.55532400 Orignally the frig. side would not cooled down below 40F even when the digital control was lower to 33F. The unit was unloaded and turned off for 24 hours, doors...
Yes the thermister is the electronic thermostat...on models such as yours that has a computer control a thermister is used..on models that the knob is turned to set the temp. and has no digital dispay a thermostat is used
The part number for the thermister is 2188819
It fits by air damper in the fresh food compartment in the upper left corner of the fresh food compartment
GENE
Sep 09, 2011 | Kenmore Side by Side Refrigerator
My Sub Zero 550 model seems like it is running all the time. It is too cold in the refrigerator compartment,and the condenser fan runs constantly. Adjusting down the temp control has no effect. Freezer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 15, 2010 | Sub-Zero 650 / O Bottom Freezer...
Food freezing in fridge compartment in my side by side
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | KitchenAid KSCS25FKSS Side by Side...
Frig won't hold set temp keeps freezing things.
Thermostat is defective.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 11, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Fruits & Veggies are freezing in both lower frig compartments
Good day,
This problem appears in spades this time of year, every year.
The problem becomes more severe when the temperatures in the house cools down and is made even worse if the usage of the machine becomes lighter.
It occurs when the machine is off, not on.
There is an open vent, near the bottom, between the freezer compartment and the fresh food compartment. This opening or vent is necessary when the machine is running, so that the air pumped into the top of the fresh food section, can return to the freezer compartment. This is by design.
Now,
When the machine is off, the zero degree air from the freezer compartment. can drift into the fresh food compartmnet and drop the temps near the bottom to below freezing.
Off time increases substantialy at this time of year.
Some have even recommended turning the controls colder to offset the problem, but I've no proof it works well, or even a little.
SXS and top freezer models experience it more than bottom freezer models.
Dec 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator is freezing
if you turn up the temp in freezer and down on frig side and frig still freeze's than more than likly you have a bad frigerator thermastate.
Nov 17, 2009 | Kenmore 53642 / 53644 Side by Side...
GE Profile Arctica - Frig Freezing Food
Replace the damper assy, in the Refrigerator section. The damper door is stuck open. Very common problem on these refrigerators.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator does not get as cold as I would like
First check the condensor fan and condensor for dust and make sure they are clean. If these areas are not clear the system will not operate correctly. You should be able to place your hand down low on the front of the frig and feel warm air coming out of the grate there. The presence of a flow of air meens that the condensor fan is working. Depending on how forceful the air flow is, would depend on how much dirt and dust the condensor has collected. The temp controls should be set to midway first. There is a dilicate balance for these settings. Over adjusting can cause problems. Then after several hours check the frig. If not cold enough. Adjust only the fresh food adjustment colder a little bit at a time. Repeating this untill your fresh food side is cold enough. If you over adjust the fresh food side too much then food in the fresh food side will begian to freez. If you set the freezer side too high you may be causing too much frost build up on the evaporator and lowering the air flow to the fresh food side and causing it to be warmer than it should be. This would be a check to see if you can balance the frig temp. If you can`t get it to balance and there are no restriction of air flow in either the evaporator or condensor, then we may have to look farther into problems with the compressor. You may need to check for some ice buildup around the air inlet in the fresh food side from the freezer side. Try this and let me know how it is.
Nov 13, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Refrigerators Logo
102 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
