Question about Sony KP-57WS500 57" Rear Projection Television
Blue light on black screen
Do we need to replace globe or TV if blue lights are stating to break thruogh in the balck screen
  • 29 Answers
IT SOUNDS LIKE YOU HAVE A BAD CRT OR DRIVE IC
EST $350.00 -$1300
30 YR SERVICER
APGONZO
Posted on Jan 12, 2009
Why does it turn from blue to black after 10 sec.?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Dec 15, 2015 | RCA Televison & Video
Blank screen with blue light
Hello
Check the backlight inverter board to your TV. This is a common fault for most of the LCD TVs. If it is faulty, the backlight won't light up, resulting a balck screen with sound.
This is the picture of the backlight inverter board to your TV. OK.12_23_2011_4_29_45_am.jpg
Dec 23, 2011 | Sceptre X400BV-FHD 40 in. LCD TV
I instaled a timer Leviton 5-10-15-30 to the bathroom fan. I put everything in the correct place, balck with black, blue with the black that goes to the fan, white with withe and green to the ground. The...
1) To test the timer, put it on another Load, for example a light.
2) Also you can test your wires.
Take wire nut off Black-black connection and test to bare ground >>> tester should light up.
Next take wire nut off Black-blue connection and test to bare ground >>> tester should NOT light up until push button is activated and countdown begins.
3) Another thing to try is reversing the blue and black wire, just to double check your wiring.
Jan 04, 2011 | Leviton Hardware & Accessories
16" lcd new out of box flashing blue light on power indicator
Under a year old tv?This tv have power supply problems.Call the for warrenty repair.Or tries websites like shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 14, 2010 | LG 32LG30 32 in. LCD HDTV
Brake light doesn't light up
first you need to check the easiest thing, the rear light globe. replace the light bulb. if still not working, check fuses,, then you also have a front and rear brake lamp switches. Most likely it's just your rear light globe. easy fix!
May 20, 2010 | 2003 Moto Guzzi California Stone Metal...
Blue tint across screen and black shadow of sort
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 02, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
SONY KP57WV600-Turns Blue and then turns black leaving no picture
Blue picture tube in TV is bad and requires replacement by qualified TV tech.
Apr 29, 2009 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
27 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
