Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
I have a Mitsubishi WD-62527 with a brightness (low) issue after replacing the dead lamp with a Mitsubishi 915P020010 lamp part from Best Buy. I have cleaned the filters and wore gloves while replacing the part.
  • GT lover Mar 28, 2009
    I have a Mitsubishi WD-62325 TV that has a very dark dirty fuzzy appearing picture despite several lamp replacements over the 3 years I have had it. I am wodering if the DLP component is dirty or bad. Does anyone have any suggestions
  • 38 Answers
Bad lamp
Posted on Mar 13, 2009
Mitsubishi wd 62527
Possibly the color wheel which is not available, you have to go with the optical engine which is part#: 938P015020
This would make repairs UNECONOMICAL
OR any one of 5 fans:
Chassis fan & Lamp fan: 299P288010 $20.00
http://www.shopjimmy.com/catalogsearch/result/?q=299P288010
PBS fan: 299P296010
Ballast fan: 299P287010 $25.00
http://www.shopjimmy.com/catalogsearch/result/?q=+299P287010
L/V fan: 299P295010 $27.00
http://www.shopjimmy.com/catalogsearch/result/?q=299P295010++
May 06, 2014 | Televison & Video
Mitsubishi wd 62527
hello there it could be a loose connector that u may have disturbed or broken look again inside if it worked before with
sound the chances are its ok
Jan 21, 2018 | Televison & Video
Recently the red light is flashing in stand by, is there a common issue with this ? WD62327
This is a common issue for DLP TV's the bulbs they have are made to last 2000-4000 life hours for Osram lamps this is the lamp the Mitsubishi usually uses so depending how old the lamp is this could be your problem I found the lamp you need for a good price
http://cgi.ebay.com/MITSUBISHI-915P020010-LAMP-PHILIPS-WD-52525-WD52525-/330465131739?pt=LH_DefaultDomain_0&hash=item4cf141bcdb
Sep 20, 2010 | Mitsubishi WD-62525 62" Rear Projection...
The picture is dark or not as bright as it use to be. Tried settings for billant/brignt but no help
It sounds like your lamp is starting to dim.This is normal after so much usage.Mitsubishi 915P020010 Lamp is the one you need and you can find this @ discount-merchant.com
May 07, 2010 | Mitsubishi WD-52525 52" Rear Projection...
LOOKING FOR RELIABLE REPLACMENT LAMP ASSEMBLY AT REASONABLE COST
Hi, your part # will be 915p020010. The original maker is Osram which last around 4000 hrs. You can get the Philips which last 6000-8000 hrs with a superior picture quality,only if you have the housing that has a white cart board covering the back of the lamp.If your housing is complete plastic you will have to get the original Osram. Here's the link where I found it: http://cgi.ebay.com/915P020010-LAMP-FOR-MITSUBISHI-TV-915P02A010-BY-PHILIPS_W0QQitemZ330390868795QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4cecd4933b?Click=48173
Jan 05, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I have a WD-65732. The brightness level is very low dispite the fact the setting are on BRILLIANT and the bright level is high. Please help.
Howdy,
I suspect a bad lamp part # 915P020010. When you order it from factory it will give you detail information on how to install and handle.
Good Luck, Big Irish.
Nov 23, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Apr 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd 52725 lamp troubles
You can use Mitsubishi 915p020010 or Osram E023. Remove the front and clean the lense using only a clean microfiber cloth. dirty lense main cause of dark picture. The lamp could be incorrect wattage.
Mar 05, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Replacing the lamp wd-62327
Did you get correct lamp:lamp part # 915P020010 ?
Sep 07, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
392 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
