Question about Bose Lifestyle 35 System
No power to the Acoustimass bass
I have LS35 and now it just stopped working. The media center is playing but the subwoofer does not power on. I checked the fuse and it is Ok. How does one check if it is the power (subwoofer) problem or the Audio input problem? I am now struck for sometime without the sound. Is it possible to connect a non-bose speakers to the bose media center???
  • jbu87 Jun 14, 2008
    I have the same problem. How do you access the internal fuse and what rating is it?
  • Anonymous Dec 08, 2008
    I Have the same problem Mi fuse blown up and there is a damage in the power module of the sub component
I had similar problem. I wasn't the fuse though. I had to send it to bose repair center and spend $300 to fix it.
Posted on Jul 21, 2009
  • Darren Feb 23, 2011
    Hi I have the same fault. Did they say what was wroung?
Hi, have you checked the internal fuse in your sub?
Posted on Dec 22, 2007
My break light fuse keeps blowing in my 97 suburban any ideas why
Assuming it's a K1500, 15A STOP/HAZ fuse 1 in the instrument panel fuse block is the source of power. If the stop lamp switch checks OK, and the center high mount stop lamp is OK, the cruise control system gets input at this point and may be defective. Fuse 1 also feeds power through the turn/hazard switch to the stop filaments of the tail/stop/turn lamps and these presumably are OK
Sep 22, 2012 | 1997 Chevrolet Suburban
Power ON/STANDBY switch is blinking only nothing is displaying and i did microprocessor reset.Actually My son was playing with the disc holder he open that and close that suddenly it stop working
OK, i Fix it, after checking the Power-parts in the Subwoofer, i check the receiver, it was the IC-802, a 2,5A Fuse which looks like a little Transistor (on the Print with the 25pin.connector).since the repair it working......
Dec 01, 2011 | Denon S-101 System
I have a rover cd32 radio /cd it was working fine i stopped for 5 minutes and when i started the car again the radio was dead.the fuse appears ok as the clock is working and are on the same fuse,pushed...
  • This shows a faulty head unit sometimes...
  • The fuses for these systems are usually two.
  • One right behind the music system, clock and the head works on it.
  • Then the second on the fuse box of the car.
  • Usually used fuse is the accessory- cigarette lighter kit fuse. Check for any blown fuse in the fuse box.
  • Then check the connection lines of the main supply(red\yellow), ground(black).
  • If this is not a remedy then go to the service center to get an advice. Do not open the head unit yourself !!
Sep 23, 2011 | Blaupunkt Car Audio & Video
The sub on the left speaker don t play and the light went off but the mid and tweeter have sound coming out
The amplifier that drives the built in subwoofer has stopped working. The first thing to do is check that the power cord is plugged in to a live power outlet. Next, replace the fuse which you'll find on the large black metal plate on the back of the speaker. Use only the size and type fuse specified. If that does not work contact Definitive customer service at (800) 228-7148.
Apr 02, 2011 | Definitive BP7006 Main / Stereo Speaker
Jvc subwoofer sx pw22 working fine then just stopped working. power light is on and fuse is not blown. any suggestions?
First check all the connections. Something as simple as a loose wire will cause your sub to shut down. If all connections are secure, then your coils on the sub itself may have come apart. To test, try pushing in the center of the sub as it is playing. If sound comes out, it's your coils.
Hope this helps.
Dec 23, 2010 | JVC RX-778V
How do i turn on the media center buttons?
Yo can create custom shortcut by doing the following : Start > All Programs > Windows Media Center, and right click on it. Select properties. Under "target" you will see "%windir%\ehome\ehshell.exe".
Simply add the switches you wish Media Center to start with and hit OK. For example, if your shortcut looked like the following: %windir%\Ehome\Ehshell.exe /nostartupanimation /noshutdownui /mediamode
Hope this helps.
Here is a list bellow.
/nostartupanimation stops the startup sound and Windows Media Center logo "pebble" going off into the distance /noshutdownui removes the "shutdown" item from the tasks menu /mediamode starts in media only mode (no close/minimize/maximize options in top right corner) /widescreen start in widescreen mode, even on 4:3 display (windowed only) /nochrome display windowed mode Media Center but without the window chrome /playallmusic plays all your music instantly /playfavslideshow plays your favorite slideshows only /playfavslideshowwithmusic plays your favorite slideshow with music /playslideshow plays all slideshows /playslideshowwithmusic plays all slideshows with music /screensaver starts the Media Center screensaver /configuress starts Media Center at the "configure screensaver" screen
Feb 10, 2010 | Gateway M-6866 15.4" Widescreen Laptop...
I have no power to the the radio
You will have to chase your power wire back to the fuse panel and/or the battery itself. The burning smell was more then likely the main power cord burning up. Replace it and it should all work well.
Dec 16, 2008 | 1992 Honda Accord
My Earthquake Supernova MK-IV 12 stopped working
kindly check out maybe the fuse was already explode...check the connections specially the coil of the speaker using a multi tester....thanksss and gud luck
Nov 28, 2008 | Earthquake Sound MKIV-12 Subwoofer
Bose Lifestyle 35 System Logo
1,345 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
