Question about HP Pavilion dv9000z Notebook
Laptop turns off intantly, when I unplug the charging cord
If I have the charging cable in the laptop dv9000 it says it is charging but really is not. It never fully charges then when I unplug it the laptop turns off instantly. I just got a new charging cable and new battery. WHAT IS WRONG?
  • xpok7 May 11, 2010
    Are they BRAND new? If they're brand new, take them back. Something probably defective.
  • Lloyd Drose May 11, 2013
    my laptop is also same show plugged in and charging ..............but doesnt chrge really and cant use without charger plugged in
For those of you having the problem of a HP laptop shutting off when you unplug the charger and your battery is fully charged, I can help you. There is nothing wrong with the laptop, battery, or computer, it is a power management setting. If you go to display properties, select the screen saver tab, then click the "power" button, in the power schemes field is a drop down window, click on it and select "Rixane Power Scheme", it is a power switching utility that quickly switches between AC and Battery when the power cable/charger is plugged in or unplugged while the laptop is on. If you have it set to "always on" it will shut off when you pull the power cord, even if the battery is charged. This will also happen on many non-HP laptops, if you don't have a HP laptop or there is not a "Rixane" option available, select the "Portable/Laptop" power scheme. Hope this helps!
Posted on Feb 20, 2010
  • 1 more comment
  • mthmmeier
    mthmmeier Feb 10, 2012
    I have a hp pavilion dv7 with this issue. As soon as I unplug it, the computer shuts off and will not turn back on without being plugged in. Im not able to find the settings that you have explained above. Suggestions?
  • rb_ryanbaxte
    rb_ryanbaxte Jan 30, 2013
    I also have a dv7-6165us and this is happening to me also. Rixane just sounds like a power setting, and I can't find anything that would show it would help. It also seems to only be in windows xp so I don't think it applies to this. Hopefully I will find something else, but haven't yet.
  • care_bear08
    care_bear08 Jul 07, 2013
    I'm on Windows 7. Any way you could give directions for that OS? I'm not able to follow these at all.
I had the same problem at the same time you did. I found the answer on google. It is the bios. Update bios to f .23 A You can download it at the link below. After you download it close all open programs and select run on the download. It installs the new bios.
http://notebook.free-driver-download.com/HP/40714/HP-Pavilion-dv9500(Intel)-Notebook-BIOS-F.23-A-Windows-XP-x32-Vista-x32.html
Posted on Jan 03, 2009
Pig dog
Posted on Jul 05, 2009
  • sarah
    sarah May 08, 2014
    I have a samsung, all I did to fix the problem was create my own power plan settings. Now my laptop works when unplugged :) There was nothing wrong with my battery or charger or laptop itself, was just the power settings.
    Problem Solver:
  • 7 Answers
If you just got a new battery AND you got a new AC charger, then your laptop has a charging defect. Check to see if any of the contacts are missing/broken (that touch the gold contacts on your battery). If that looks fine, chances are, that there is either some physical problem inside (short/broken connection) that is not allowing a charge to flow down to your battery.
  • ruth marie kornahrens
    ruth marie kornahrens Nov 14, 2013
    is this fix able
  • sarah
    sarah May 08, 2014
    I had the same problem with my samsung. I created my own power plan settings and now it works perfect. It doesn't switch off when I take the charger out. If your laptop turns off when you unplug the charger, try changing the power settings before anything else - that's my personal advice. It's worth a try! :)
    New Friend:
Posted on May 08, 2014
Plugged in and not charging
1) Use a multimeter, check the AC adapter (Charger) for power.
Make sure it is putting out the required voltage.
Have an assistant gently wiggle the cable FROM AC adapter TO laptop. See if there is an intermittent reading on the multimeter.
Have an assistant gently wiggle the power cord.
An intermittent reading on the multimeter indicates a broken wire.
Power cord is bad? Replace cord.
Cable from AC adapter to laptop is bad? Replace AC adapter.
If you have posted the laptop manufacturer NAME and MODEL NUMBER, I could have given you more than generic information.
Model Number is in the Bottom of the laptop. Post back in a Comment.
AC adapter works OK?
Check the DC Power Jack.
The DC Power Jack is the jack on the laptop, that the AC adapter plugs into.
DC Power Jack checks OK, this is your problem,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Regards,
joecoolvette
Jan 31, 2013 | Computers & Internet
Tip
HP Pavilion dv9000 battery tips Your new HP Pavilion dv9000 laptop battery comes...
DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery Chemistry : Li-ion
Voltage : 14.8V
Capacity : 4400mAh
Corlor : Black
Original Price: US $85.63
Special Price: US $65.63
warranty.jpg * 1.One year warranty, 30 days Money Back.
* 2.Brand new, 100% Q.C. of every battery.
* 3. Highest quality Japanese battery cells.
* 4. Guaranteed to meet original specifications.
* 5. 100% secure and safe.
  • Shipping: Our laptop batteries are shipped by USPS.
    The battery have a good compatibility with many original laptop batteries for many laptops, even diffenent brands.
  • Descriptions of Hp DV9000 DV9700 DV9600 HSTNN-IB33 Battery 1. 100% new high quality Replacement DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery Compatible Li-ion Batteries.
    2. This Hp DV9000 DV9700 DV9600 HSTNN-IB33 battery can be used for the other models and battery part No.
    3. 30-Day Money Back,1 Year Extended Warranty for Hp DV9000 DV9700 DV9600 HSTNN-IB33 laptop Battery.
    4. Great After-sales Service Department for laptop battery, fast respond to your request!
    5. Fast delivery if you order the Hp laptop battery.
    6. Need any assistance on DV9000 DV9700 DV9600 HSTNN-IB33 Laptop Battery, please feel free to email us!
  • on Jan 27, 2010 | Computers & Internet
    HP compaq 6735s Shuts facing a very weird problem concerning its power. I have left my laptop charging without use for 3-4 days, today I came back home and wanted to use my laptop, I turned it on and...
    You need to replace the battery as it has expired.
    They are available by typing the battery model number or laptop model number into ebay or Google or indeed any search engine.
    Hope that helps.
    Nov 19, 2010 | HP Computers & Internet
    Looks like your battery is having a problem. Remove the battery and replace after a couple of hours. If problem remains replace the battery with another to test, if this works, then the problem is with the adapter unit. Get a new one.
    Nov 19, 2010 | Computers & Internet
    Can this HP Pavilion DV9000 adapter fit Presario V3000 laptop
    just see it from http://www.udtek.com/hp-pavilion-dv9000-ac-adapter-90w-185v-49a-p-2970.html.may this is good for you.
    Jan 15, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
    How long is the battery on a HP Pavilion dv9000 supposed to last?
    Laptop batteries will usually last from 1.5 to 5 hours, depending upon the demand, the battery and the use. Sound burns up a lot of juice as does the DVD player so if you're watching movies or playing games an hour is about right. You can purchase a better HP PAVILION DV9000 Battery with 12 cell , it will work longger.
    detail: http://www.battery-center.net/hp-pavilion-dv9000-battery.html
    Dec 04, 2009 | HP Computers & Internet
    If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all.
    The laptop's charging circuit maybe faulty.
    Nov 26, 2009 | Acer Aspire 5610 Notebook
    Dv9000 won't power on or charge. blue lightning bolt flashes
    I just had this problem with my HP Pavilion dv9005us Notebook PC, and the problem is one of two things (that I know).
    1. Your'e Laptop's battery is completely empty, and needs to be plugged in to charge for an hour or two
    2. Or your laptop cord is broken, or isn't working properly.
    For me, it was the secon problem. I went online searching for answers as to where I could buy a new cord for my Laptop. My previous one was universal, as the one that came with the notbook was chewed by my puppy. So Staples Canada, (or US) and Futureshop where the only places I could but this cord. They had the laptops on one wall, and the cords underneath them. In total, I paid $112.00, $89.99 plus tax, and $10 for an extended 2 year unlimited warranty. It sucked forking out the money, but I knew that I could trust the HP brand, and now have a working laptop.
    Hope this helped (:
    -Hannah
    Jul 16, 2009 | HP Pavilion dv9000z Notebook
    My hp dv9000, has a problem with the charge of battery .
    hi,
    since you have checked your battery and the cable on another laptop and both of them are working fine, that means the problem could be with the connector on the no-working laptop or power circuit on *********** board is bad.
    Further Queries are welcome
    If you find my solution helpfull please do rate me
    Mar 28, 2009 | HP Pavilion dv9000z Notebook
    HP Pavilion dv9000z Notebook Logo
    18,298 people viewed this question
    Top HP Computers & Internet Experts
    Alun Cox
    pankaj rautela
    pankaj rautela
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
