Trying to figure out why i have to connect the blue wire to my laptop from the router, i want a wireless connection?
  • 2 more comments
  • andyrahal Dec 27, 2008
    i have a toshiba pc, using windows, the router is lela cisco WRT160N
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    Did you enter the WEP key correctly when setting up through the windows wireless connection wizard?
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    1. Is the wireless light on on the router?
    2. Is the wireless light on on the laptop?
  • Kevin Shafer
    What kind of router? What kind of computer?
    President:
  • 623 Answers
You do not have to connect your laptop to your router if you want to use it wirelessly.
For doing the initial setup for the router although I would definitely recommend to connect both with a cable and not doing it wireless.
The main reason is, if you setup your security (WEP or better WPA, idealy WPA2), you will loose instantaneously the connection to your router. You will have to copy the network key to your laptop to reconnect to the router.
Therefore: connect your laptop with an ethernet cable to your router and follow the instructions in the user guide (if you don't have it, you can get it here. Setup your router manually and don't use "Wi-Fi Protected Setup button" - that way you know what is happening. Choose a long security key (63 characters) for WPA (or WPA2, if your computer can handle that) and leave everything else on default.
Copy the network key into a text document and save it on your computer, so you have it handy when the router asks for it.
Unplug the cable.
Check if you can connect.
Reconnect the cable to your router.
Change your SSID and use MAC filtering, unplug and check again for connectivity.
If this helps you, please leave a comment here, because it might assist others too.
Posted on Dec 28, 2008
Hi i bought the smc wireless router and i tries to connect it but i couldnt figure out how to connect it because i have a laptop and my internet is connected from my modem to my laptop but i cant seem to...
I'm unsure of the exact part number here but using the model number I checked the manual. This looks like it's just an access point which extends a current network you have. If you only have your laptop, this device and your internet modem it may not give you the wireless connectivity you're looking for. On a normal setup you would plug your modem into a router, plug your laptop into the router and set it up with all your DSL/Cable connection information as well as wireless on/off. You can then unplug from the router and continue life. with this one it's only connecting to an existing setup (another router or another wireless network) and extending it.
If you are looking for a solution to give you a router that connects to your modem and gives you wireless or adding multiple devices on a single connection I would recommend returning this and getting an all-in-one router such as this: http://homestore.cisco.com/en-us/Routers/Linksys-E1000-Wirelessn-router_stcVVproductId97826160VVcatId551966VVviewprod.htm?icid=linksys-specs-e1000-learnmore-btn&src2=linksys-specs-e1000-learnmore-btn
Mar 07, 2011 | SMC EZ Connect g SMCWEBT-G
I am wanting to run my (currently wired) laptop to be wireless (have bought a USB adaptor to do this), but also keep my main PC wired. I clearly need the internet on my PC to set up my DLink G ADSL2+. I...
You will need a wireless router with a built in switch. Most of them these days will have a built in switch. Here is a picture detailing what I am talking about.
You're internet connection goes into the ADSL port. Now, it will be broadcast WIRELESSLY through the antenna to your laptop. With this example, you could connect 4 more WIRED computers through the LAN ports. The built in switch is the division of the connection into the separate LAN ports.
I trust that this will help you greatly and look forward to your response!
Feb 26, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
How do I hook up my Westell wireless router to the zhone modem so I can use my laptop. I have to use a dedicated line with a zhone modem to get DSL service. I want to hook up my wireless router Westell...
Connect the Westell wireless to the Zhone as if the Westell is the PC that used to be connected to it. Then connect the PC (through any available port) only to the Westell. That's the WIRED connection. For the wireless to work, after connecting through the WIRED connection, there should be a CD that came with it that will help you configure the wireless.
Feb 18, 2010 | Zhone 6212-I3-200 Router
Blue Ray connection to Belkin G router
your wireless router is encrypted. To remove encryption, go in your computers web browser: http://192.168.0.1
That will take you to your LAN Administrator.
Follow the simple wireless setup for an unsecured connection or setup your blue ray connection and create your own passphrase or WEPKey.
Hope that helped!
Jun 23, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Can not connect wirelessly with router
The list of wireless routers that are available in Windows is very limited and the signal strength of any router that is detected is weak. This can occur when the Lite-On USB Wireless 802.11 b/g hardware and Windows are not able to fully synchronize the signal strength data. Figure 1: Example of detected wireless devices when the antenna cable wire is connected to secondary port c01153759.jpg Figure 2: Example of detected wireless devices in the same environment when the antenna cable wire is connected to primary port c01153760.jpg To correct this error , download and install Lite-On USB Wireless LAN Driver Update (sp35177) (in English) from the HP Web site. This update should only be applied if your PC has the Lit-On USB Wireless LAN adapter and is exhibiting the symptom. As a work-around, you can connect the wire that runs from the wireless antenna port to the primary port on the cord as follows: CAUTION: This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
  1. Open the side panel.
  2. Find the wireless networking board by following the antenna wire connected to the wireless networking antenna port on the back of the computer. Figure 3: Wireless networking hardware c01153761.jpg 1 - Wireless network board 2 - Antenna wire 3 - Wireless networking antenna port
  3. Very carefully, disconnect the small wire from the board by gently pulling the end of the wire away from the board.
  4. Connect the wire to the other available port on the board. Figure 4: Available port c01153762.jpg
  5. Replace the side panel, connect the power cord, turn on the computer, and use the computer again to verify that wireless signal strengths have improved.
Jan 14, 2009 | Acer Aspire 4520-5582 Notebook
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Wireless with no cable to wireless laptop
this is just the first setup step for you to access the router interface page to setup your wireless network name or SSID, encryption type, encryption key, etc ....
Jul 04, 2008 | Computers & Internet
Iam trying to connect my laptop to the innet. i have wrt54g router.
Hi jjroyc
Let's see if we can get your laptop connected to the Internet.
First, I have some questions and a few instructions for you.
(01) Is this a new (to you) router?
(02) Do you already have one or more computers connecting successfully to the Internet using this router?
(03) If yes, are any of them connecting wirelessly?
(04) Have you recently (at another location for example) successfully connected this laptop to the Internet? If so, did you connect it "wired" or "wirelessly".
(05) Are you trying to connect your laptop to your router "wirelessly" or "wired"?
(06) If you are trying to connect the laptop wirelessly, turn off your laptop's wireless radio and connect the laptop to the router "wired" instead (using an "Ethernet Patch Cable"). Once we've established that the laptop is capable of connecting to the Internet via the simpler "wired" connection, then we'll move on to the more complex wireless connection.
(07) Please, go HERE to download the manual for your particular router. You will need to determine the version number of the WRT54G model 1st. There are instructions there that will guide you through this.
BJ
Apr 03, 2008 | Computers & Internet
Computers & Internet Logo
272 people viewed this question
Alun Cox
David Payne
David Payne
