Question about Sony KP-53S65 53" Rear Projection Television
Sony KP-53S65 Vertical Transistor
Hello, i take off the Transistor of my TV, and i lost it, yes, sorry, I think is D....., please if some body know the piece number, please answear, in the board is Q502, please help
Dave
Q502-Horizontal output-2SD2348
Posted on Mar 02, 2009
Tv was dead no vvidei no sound after checking found that power supply capacitor and horizontal deflection output transistor was defective i lost that tr no part no please tell me what should i do?
Hello
There are few models of Sony telivisions which uses transistors in vertical output section. It will be a matched pair of PNP and NPN transistors. According to Sony schematic which I have with me used 2SB6494(PNP) AND 2SD669A(NPN) as vertical outputs and 2SC2383 as vertical drive, 2SC1364 as vertical oscillator. Just try to get the orginal numbers or find its equivalents from data book. Ok.
Oct 17, 2010 | Sony KV-35S42 35" TV
The tv has no power its a sony kp-53s65 no light or nothing
hello you may to check the glass fuse inside the tv it will be in the power supply if it's black in colour it's blown make sure you put in the same rated fuse back in the value will be at the end of the fuse or on the fuse holder on the power supply board but beware if it blows again then you have a dead short inside the tv someware good luck
regards
shaun
Jul 29, 2010 | Sony KP-53S65 53" Rear Projection...
I need to replace the bulb in kp-53s65
This TV does not have a lamp only 3 CTR tubes which bulb are you looking for?
Jul 11, 2009 | Sony KP-53S65 53" Rear Projection...
Sony kp-53S25 issues please help
The vertical circuit needs to be checked. It could be the vertical output needs to br resolderd or you could possibly have a bad capacitor. if you need more assistance let me know.
May 22, 2008 | Sony KP-53S25 53" Rear Projection...
Conversion of PAL (B) into NTSC
you will need a pal/ntsc digital video converter
Dec 01, 2007 | Sony KP-53S65 53" Rear Projection...
I have a sony kp-53s25
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
good luck
please mark the post with a fixya!
Nov 21, 2007 | Sony KP-53S65 53" Rear Projection...
Sony kp-53s65
i have a sound no picture
Aug 07, 2007 | Sony KP-53S65 53" Rear Projection...
Sony KP 53S65 Rear Projection TV
I don't know if this will help you but I just experienced a similiar problem with a sony kp-53s35.
It turns out that a fluid leaked out of a rubber boot on one of the guns( I have no idea what the fluid is or why it is corrosive), down to a circuit board and started to desolve a jumper wire. when it had eaten away enough of the wire, the residue or solution1.gif was conductive enough to cause an arc to a ground bus bar that ran along the circuit board. The TV still worked but would crack and pop like firecrackers inside.
I was able to increase the distance to the ground source by bending the bar away. Then I scraped and scrubbed the board with contact cleaner to remove residue and replaced jumper wire.
Has worked fine since.
Mar 18, 2007 | Sony KP-53S65 53" Rear Projection...
Need to know part number or value for C514 in horiz out put circuit for kp-53s65
C514 has three different values possible. Just use this value as it has worked fine for me in the past. 680pf /2kv Sony part# 1-162-116-00
Jan 20, 2007 | Sony KP-53S65 53" Rear Projection...
Standby timer light blinking, tv will not turn on
Check out Ceramic Capacitor C514 by the horiz. output transistor (burned/shorted?) My question is how do you find the specs of the capacitor and where do you buy one?
Dec 11, 2006 | Sony KP-53S65 53" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
81 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
