Question about Whirlpool AWM6120 Front Load Washer
AWM 8121 NOT DRAINING OR SPINNING PROPERLY
During a wash cycle machine stopped and flashed red lights on wash indicator and 2 spin speed indicators (bottom two lights for 0 and 100).
I have tried to just drain the remaining water by selecting drain and the machine attempts this for a while and then flashes these same error lights again. I have tried other cycles witht the same result.
  • Whirlpool Master
  • 2,699 Answers
That isn't a good model number,open the door,look around the opening where you put the clothes in and next time send the model number off of the machine,if you can't get it to drain and water is in the machine get a shop vac,suck out the water from the tub,then go to the pump,loosen the center of the pump until water starts to come out vac it up until no more water comes out,remove the center catch and see if there's junk in there,if so this is your problem,stick the nozzle of the vac inside and clean out the inside,put it back together and see if it will drain
Posted on Sep 30, 2017
SOURCE: whirlpool 6th sense front loader awm 8121
my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
Posted on Aug 17, 2008
capsman
  • 111 Answers
SOURCE: not finnishing cycle AWM 8121
Can you manually advance it through all the steps of the cycle? If so, you can live with it until you replace the little timer motor. (I once carved a tiny wooden gear to replace a tiny nylon gear on the timer, and that worked fine for another 20 years.) If not, then I'd say the control unit needs replacing.
Posted on Nov 11, 2008
barkencoa
  • 3463 Answers
SOURCE: Whirlpool Washing Machine AWM 029 is not draining
Hi.
I assume you have checked to see if the pump is working,
Select drain and spin, if water does not go away, then you have a pump problem, which will stop the programme completing.
Please leave feedback.
Thanks
Posted on Nov 25, 2008
  • 4 Answers
SOURCE: Washing cycle starts and takes hours even for short cycle.
Try checking for good water supply.
Pull out detergent tray and check for good water supply during filling.
if poor filling-
Try checking the hoses.
Turn taps off, disconnect from machine, place hose end in sink, turn tap on and check for good water flow.
if the hose has a red indicator in the side of the hose (end which is fitted to the tap) - Red indicator is a failed hose.(for models with Water Stop hose type "B")
Posted on Dec 15, 2008
Hit it again
  • 13 Answers
SOURCE: Whirlpool AWM 6100/s - stopping
Yeah. This is a pump problem. Our machine first did this about 3 months ago. I took the filter plug out and removed about 10 coins from around the pump impeller area! I removed the pump and dismantled it. Unfortunately water was getting in past the seal on the pump spindle. I cleaned it all out and reassembled it. Worked fine till a couple of weeks ago. It has worn out the spindle "bearings" and because of the loose play it gets stuck, intermittently. If you are by the machine when the drain cycle starts , you can give the filter housing a few bangs(take off the circular cover) . The pump will start up .It makes a grumbly sound, as it is knackered. But once started will generally keep going.The answer however is a new pump. And probably a pact with everyone in your household to be more careful not to leave stuff in the clothes you put in the machine. Our washer has got through 2 mobile phones. a packet of bradding nails, a lot of cash, both coins and notes.Various other stuff that i wont mention! The pump gets very hot when it is trying to turn but cant because of debris on the impeller. This will lead to the pump failing after a time.
Posted on Jan 27, 2010
Machine stops during the spin, especially with heavier loads.
Maybe you overload your washing machine. Minimize your washing machine usage to avoid stopping during the spin.
Aug 23, 2015 | Baumatic Washing Machines
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Why does the lid lock light start flashing after the wash cycle and will not rinse or spin?
Lift lid, stick screwdriver into slot where lid latch-pin inserts and see if it goes into the cycle. If so, try adjusting position of latch.
Sep 01, 2014 | Washing Machines
Zanussi ZWF580- after the wash cycle I press the red button to rinse & spin but it just tumbles & rinses again, then the red button comes on again. This could go on all day. I find that to finish...
If the START / PAUSE button lights up red, the washing machine detects a malfunction. Now you should count how many times the START / PAUSE button lights up red and tell to us what kind of malfunction is being done.
Try to rapid reading of alarm codes when the appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and the nearest option button for at least two seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
LED indicator START / PAUSE with red light = indicates the first digit of the alarm code (family)
• LED indicator START / PAUSE with green light = indicates the second digit of the alarm code (internal number of the family)
Dado
Jan 21, 2018 | Zanussi FS1155W Front Load Washer
During the wash cycle the machine stops and
Hi
Thanks for using FixYa. Error F06 is your whirlpool duet indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
Fisher and Paykel WL80T65D washing machine won't fill or spin
Hi just read your posting.Now when the red spanner light was flashing were there any other lights that were on.If there was then they will be in your cycle selection row.This row has 8 lights on it.Starting from left to right what lights were lit?Is it the 1st and 4th or the 3rd and 7th ---etc---?Please reply with additional information on the questions and I can help you rectify this problem.
Jul 10, 2010 | Fisher and Paykel Washing Machines
Flashing Active Light and not taking fabric conditioner
1: The flashing wash light usually indicates a problem with the door latch while a flashing rinse/spin light usually indicates a problem with your inlet valve. 2: The cold water inlet has 2 independant outlets. The issue that you are describing indicates that one part of the cold water inlet is not opening to allow water to flow to the proper dispenser port.
Mar 10, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Whirlpool AWM6120 Front Load Washer Logo
132 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
