Question about GE JKS05 Electric Single Oven
Install bake unit in GE wall oven model JKP07J
I need to install a new Bake Unit (lower heating element) in a GE wall oven model JKP07J. I thought I could just unplug the old element by pulling on it and plug in the new one, but the old element will not come out by just pulling. This oven is over 15 years old.
  • 405 Answers
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Posted on Dec 27, 2008
  • bradfdx Dec 03, 2010
    My bake unit (lower element) just went out. There were two screws, one on either side of the element, that required a 1/4" wrench to remove. Came out pretty easily. Then there were screws -- same size, fastening the wires to the element contacts. Remove those and it comes right out. Reverse order to install new part. Mine was $35, including FedEx charge, from PartSelect.com.
    NOTE: TURN OFF YOUR BREAKER BEFORE REMOVING THE ELEMENT.
How to change the electric oven GE 168947 elements
Basically you unplug the oven and remove the back, you should see two wires connected to the elements where they come through the oven wall in the back. Unhook those wires. The elements are held in place with nuts on the portions that poke through, remove the nuts and pull the element out through the front, and install the new one. Note that if you break one of the connections on the wires to the heating element, they can be a real chore to repair because they are high heat connections.
Feb 18, 2017 | GE Ovens
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Whirlpool oven WGP30801
Your model suggest a gas unit on gas units only bottom burner operates in bake on electric bottom elements heats broil cycles.
Feb 12, 2014 | Ovens
Whirlpool built in electric oven bake (bottom)heating element does not heat up only tot heats when in bake mode
CHECK FOR CRACKS IN THE BAKE ELEMENT. IF THE UNIT IS NOT HEATING THE BOTTOM, BUT THE TOP IS STILL HEATING, YOU MORE THAN LIKELY HAVE TO REPLACE THE ELEMENT. THIS IS A 220 VOLT OVEN WITH 110 VOLTS ALWAYS GOING TO THIS ELEMENT, SO TURNING OF THE BREAKER IS VITAL FOR SAFETY PURPOSES. WITH AN OHM METER, UNINSTALL THE ELEMENT AND CHECK BOTH WIRE CONNECTIONS FOR OHMS. YOU SHOULD GET SOME KIND OF READING BETWEEN 10 OHMS AND 500 OHMS. IF YOU'RE NOT AT LEAST GETTING A SOLID READING, REPLACE THIS ELEMENT.
Jan 24, 2013 | Whirlpool 24" Double Electric Built-In...
Have a frigidaire oven, model# PLES389ECE. Broiler heating heats up but lower (bake) element does not. Element need replacing?
mos likely yes... but to confirm is very easy... unplug unit or turn circuit breaker off... in the oven with door open you will see the back of bake element where it goes into oven wall a couple of screws remove them and you should be able to gently pull element out...there are 2 terminals connected to element with a wire attached to each of them... first we are making sure the wire hasn't burnt off or cam edisconnected and second we can remove wires and use a volt meter and test power... set it up so you don't get electricuted and tuen oven on bake 350 do you have power coming to the wires with element diconnected from wires...if so then you have a bad element if not then a bad thermal cutooff usually located in back of unit ... good luck to you...
Jan 11, 2011 | Frigidaire Ovens
Dual Oven - upper oven bake element replaced but no heat from it
Usually no internal fuses, and most of the time the controller is rated for fault interupt current.... age will degrade them though...
How did you change the element without pulling out the stove? is it a 'click/plug' in? might be that the socket is messed up...
You should not have to disassemble the cabinet, should just be a few screws and the unit slides out... sometimes hidden behind small movable pannels..
Peace
Feb 27, 2010 | Ovens
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Ge wall oven will not heat up on bake,boil or clean cycle
GE JKP86BF3BB COMBO MICRO/ELECT OVEN
NO HEAT ON BROIL OR BAKE ELEMENTS
CKD WIRING FROM PANEL OK
CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
FAN COMES ON
THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
MICROWAVE WORKS FINE
I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
STUMPED
Mar 16, 2009 | GE JTP15 Electric Single Oven
GE JKS05 Electric Single Oven Logo
861 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
