Question about Vantec 1 Bay NexStar 3 USB 2.0 External Drive Case
Accessing I hooked up a toshiba hdd2188 to a nexstar-3 enclosure. The light blinks as soon as I plug the usb cable in and then it stays on steady. But my computer will not even recongnize something has been plugged in. It was a laptop hard drive before. Could the hard drive it's self be no good?
    Novelist:
    Scholar:
  • 158 Answers
If you can get another hard drive and place it in the enclosure plug usb cable in then turn on the enclosure and see if this works if doesnt place it on another unit or pc and see if it accepts if it does then the usb drivers need to be re-installed goto my computer device manager and find usb it looks like a trident hilight this and click uninstall from menu list in properties then on the top of manager there will be a computer with a spyglass click on this and windows will find new devices let it continue then reboot then re-try enclosure if all goes well it will come up found new device. retry other hdd you first placed in enclosure if it dosen't feel hdd is turning the platters then get rid of hdd. hope this goes well
Posted on Aug 14, 2007
I have a Toshiba MK 8825AS taken from a HP NX5000 laptop. Is there a cable that will allow this to be connected to an desktop, either IDE or SATA? I need to access the data on the drive. Thanks
Yes, go to Tirgerdirect.com, and look for a hard drive enclosure. Your Hard drive fits inside and it will then plug into a USB port. You need to order one that fits the drive you have, so you need to know size and type of hook up. I use one for my old laptop HD's.
Aug 28, 2011 | Toshiba (HDD2188) 80 GB Hard Drive
Windows 7 NexStar CX USB 2.0 3.5 inch SATA drive when connecting, windows 7 can't recognize the USB drive and shows a message "unknown device". The blue light of the the hard drive...
This is the usual reason:
USB port has 4 pins (connectors). The two at the ends supply 5 Volts to the hard drive (or any other appliance you connect. I don't think there's a problem with those two because you can see the power light on the hard drive.
The middle is for data transfer. If one gets damaged, although the device gets power, the OS cannot recognize the device.
Try changing the USB cable you are using. Connectors in the wire are damaged more easily than those in the device.
Jul 09, 2011 | Vantec NexStar-3 External 3.5inch...
Are the lights on the router stay on or blinking ?
The power light should stay solid as long as the router is plugged in. The WAN light and LAN lights are solid when you are connected, and the connection is idle. The lights blink when traffic is present. The lights are off when there is no connection.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 15, 2011 | D-Link DIR601 WirelessN 150 Home Router...
I have a NexStar 3 external hard drive that is not being recognized by my computer. It used to work now it gives an unknown device message
remove the hard drive restart your computer the plug the hard drive back into your usb port this should come up with new hard ware found and install the driver If not try a different usb port or your sata drive
Mar 30, 2010 | Vantec NexStar-3 External 3.5inch...
500 GB Fantom Drive not recognized on either of my Macs. Tried Firewire and usb; blinking light turns to steady red.Worked fine for about 2-3 years.
The symptoms don't look too good. Looks like the host controller is querying the hard disk (blink) and not liking the answer - or lack thereof (red).
It looks like the internal disk is defective. Sometimes the disk can be (possibly partially) recovered by disassembling the enclosure and mounting it in another enclosure or directly inside a compatible desktop PC.
Aug 14, 2009 | Fantom Drives 120 GB Hard Drive
CPU won't read it im running xp
Ok, here's some step by step instructions.
First is the light on the nexstar coming on when you plug it in, if so what colour? If not try using both USB connectors on the PC end to plug in, it's possible you're not getting enough power if the light is not on as many 2.5" hdd enclosures require 2 USB connections one for power and data and the other for additional power.
Next, if the light is on but no drive in my computer, right-click on my computer, then left-click manage, select disk management from the MCC window that pops up. If your Nexstar HDD shows up here, identify it on the bottom part of the window and report back what is said there.
If it is not there and the light is on, try a different USB port. If the light is not on or you tried the other ports and still no luck the enclosure itself may have failed.
Try moving the HDD into a new enclosure and try again. If this works, Great, if not then the HDD may be damaged and may need a pro to get your files back. If that is the case report back here with your progress and region and I will recommend an appropriate pro.
Hope this helps FixYa,
Chris
May 09, 2009 | Vantec NST-285S2-BK NexStar SX 2.5"...
Nexstar.3 Sata external drive woun't start
I also have the same problem. I bought a 500gb WD HDD and it worked great via USB for about 4 days, not the computer does not have it. i am running windows xp home. i can also hear the drive working and the blue light comes on, but it is delayed. When it was working correctly it came on instantly and the computer found it instantly.
May 19, 2008 | Vantec NexStar-3 External 3.5inch...
Nexstar External drive
If neither computers detect it, which is a good form of process of elimination, I would test the cable with a known working. I would then extract the drive from the enclosure. And try mounting into a desktop machine as a slave, or find another enclosure.
Oct 04, 2007 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Vantec 1 Bay NexStar 3 USB 2.0 External Drive Case Logo
236 people viewed this question
Top Vantec Computers & Internet Experts
Arora Singh
Arora Singh
David Payne
David Payne
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
