Question about HP Photosmart C5280 Printer
Ink will not dry on photos. comes out real wet.
I am selecting my photo paper.
    Problem Solver:
In the printer little sceen go to the settings and and select Clean Print Head
Posted on Dec 27, 2008
  • 3 Answers
I cant get to far into detail but where the ink comes out of the cartrage is probably inlarged. It may be just a defect in the printer, cartrage or poor hadling no offence.
Ive just bought this printer from currys & im trying to print a picture from my memory sd card & the picture is coming out all smudged? could it be because im not using photographic paper?
You should be able to select the paper type you use before starting the print. The printer should optimise the print to match the paper you have specified. If the paper is not for photos, it shouldn't matter too much unless the ink is taking too long to dry. It is more likely that your print heads are skimming the paper or something is brushing the image while the ink is still wet.
Apr 13, 2016 | Office Equipment & Supplies
Element that dries the ink on photos isn't working after replacing ink cartridges.
heating element in a photosmart printer?
have you made sure you're printing to the right sort of paper in the printer settings. it's obviously dispensing too much ink for the paper you're using.
Mar 15, 2015 | HP Hewlett Packard - Photosmart 7520...
Changed all my ink cartridges on astylus PHOTO R280 and now the print comes out with a green ting.
I suggest that you clean the inkhead with a wet paper cloth (just a little amount of warm water . enough to make the paper cloth wet).
Remember to remove the inkhead before wiping it with the paper cloth. After that, let it dry and put it back in. Try printing.
Dec 06, 2012 | Epson Stylus Photo R280 Series
PICTURE IS SMUGGED
If you're printing on photo paper, make sure you are printing on the correct side. Most photo paper has only one side to print on, the other side is a non-porous backing, and ink will sit on the surface until it dries (15 - 30 minutes, depending on temperature and humidity). And it won't look good even when it dries.
If you're printing on the correct side, try a different brand/type of photo paper.
Dec 28, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
When I print on photo paper the ink doesn't dry and picture quality is unrecognisable
You have to match your print settings with the correct type of media used !
When you print, set the preferences, set to PHOTO quality and not draft, set paper type to PHOTO PAPER, or GLOSSY PHOTO PAPER whichever - If you select wrong media type your colors might be off. Select the settings that match the closest to your media. If you use paper use "plain paper" setting, if you use glossy photo paper, use "glossy photo paper" as settings and PHOTO quality.
I recommend use you use inkjet PHOTO paper, glossy, you can use HP or EPSON or even the cheap LIKON ones work amazing for me, they should be able to dry quickly, if they don't you are not using the correct settings.
By your description above it looks like you are using economy or draft mode - NOT good for photo paper.
Sep 26, 2009 | HP Office Equipment & Supplies
Color photos come out awful!
I can only hazard a guess but it sounds like your photo paper is not absorbing the ink correctly or the ink does not have time to dry before the next page comes out
As for transfer to next page do you mean when the next one comes out and drops on the first or as it is going through the printer.
If it is after it comes out then you may want to print one at a time and take them off the printer before the next one comes out and place it where it can dry.
Photos do take a little longer to dry than regular paper.
This may be the cause
Aug 21, 2009 | Ricoh SP C220N Aficio Laser Printer
Lexmark 5400 Printer does not use the photo cartridge
First of all as this Catridges are Non Intelligent they will not be able to show u the exact Ink level on the catridge then too if thats really happening this Solution below will fix it: In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the Photo on the left........ Good Luck
Jan 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
Printer does not print
Know insert both the catridges inside the Printer....
Now try to Print.........
This Should Work.........
Jan 23, 2009 | Epson Stylus Photo R200 InkJet Printer
Poor red color quality with Epson photo R2400
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer......... Now it should work if still it doesnt work........... This can be a problem with the camera itself...........
Jan 21, 2009 | Epson Stylus® Photo R2400 InkJet Printer
Photos print wet and smudged
all the dx /cx range do this when printed on the high quality settings you just have to let ink dry about half hour or use a lower seting when you print on gloss paper hope this helps
Dec 07, 2008 | Epson CX8400 All-In-One InkJet Printer
HP Photosmart C5280 Printer Logo
284 people viewed this question
Seeker5211
Seeker5211
