Question about Sanyo 6102641943 Projector Lamp for 5500N, 5500N
Sanyo PLC-5500NA I've got a problem with a new globe first 2 times worked okay but now only works randemly the projector was on a fairly steep angle not sure if this will cause a problem but found that temp may might be affecting when globe works. found that sometimes it will fire up when left alone for a couple of days
nick_helpap
  • 334 Answers
SOURCE: reset lamp counter on Sanyo Projector PLC XU100
in main menu lamp reset in settings
Posted on Oct 07, 2008
  • 43 Answers
SOURCE: i need instructions for my sanyo plc-sw35
Hi There,
I Have a plc-sw35, Gave me many issues (switching off etc..) Ive managed to repair it, and made the manual available. http://www.entwan.netau.net/1_8_Repair-Schematics.html
My repair story is there also.
Posted on Sep 18, 2009
SOURCE: sanyo plc-xp46 lcd projector
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on
Posted on Aug 03, 2010
robertsager
  • 24 Answers
SOURCE: I have a Sanyo PLC-EX20 projector which shuts down
There are 2 possible causes.
The first may be due to overheating. Most projectors have a "air filter" that can be removed and cleaned. If it gets clogged with dust over time, the projector can't breathe and shuts down.
The second cause may be your lamps life hour clock. Most projectors keep track of the amount of time that their bulbs have been active. Once a preset # of hours has passed the projector will limit functionality until a new bulb has been installed AND the lamp life clock reset. Most projectors do not automatically reset the lamp life clock after a new bulb is inserted.
There should be instructions on how to reset the lamp clock in your users manual, and info on cleaning the air filter. Unfortunately I went to the Sanyo website and was unsuccessful in locating a PDF of the user manual for you.
Posted on Mar 07, 2011
SOURCE: please advise how can i
como resetar lampada de sanyo xu300
Posted on Sep 29, 2011
Sanyo Projector won't switch on
The ballast board controls the lamp. The lamp socket wires connect to this board. The ballast board isn't working.
May 16, 2017 | Office Equipment & Supplies
I put a new bulb in a sanyo plc-xu73 projector still no light how do i test the bulb to make sure its not bad
There's no test equipment for DLP lamps.
The only way to test the lamp is with a working projector.
I am a Tech many times, I can tell by a visual inspection.
If you purchased a cheap lamp, or from someone beside a Sanyo dealer then, you may have a bad lamp.
www.aaatvservice.com
Jan 26, 2012 | Sanyo PLC-XU73 Multimedia Projector
I have a Sanyo PLC-EX20 projector which shuts down after five minutes, what could cause this?
Mar 04, 2011 | Sanyo PLC-XE20 (Chassis XE2000)...
Hi Guys, I have a sanyo XE31 projector, i am getting pink spots in corner the same as this one listed on ebay (see link) http://cgi.ebay.co.uk/Sanyo-PLC-XE31-LCD-Projector-with-remote-01...
the Lcd panel was broken,
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Feb 28, 2011 | Sanyo FOR PLC-XE31
Ive put a new lamp in my Sanyo PRO-x Multiverse projector PLC-SU30 but still not working. I've been told I need to reset the machine by pressinmg a combination of menu buttons - is this correct and can...
I'm having a similar issue wit a Sanyo. Installed new Sanyo lamp but when you plug it in the warning indicators show that there is no lamp detected. Ballast issue? Sanyo tech support told me this is rare. I'm not all that confident about the lamp socket. it seems to be a loose fit. Can't find any info on a reset.
Aug 12, 2010 | Sanyo (6102932751) Projector Lamp for...
Sanyo plc sw20a dose not work with my laptop what
you need to activate the external monitor port on your laptop.
Oct 04, 2009 | Sanyo PLC SW20A Multimedia Projector
My dell projector image is at an angle not striaght
hi,
Check it's lense angle & take it in correct angle OR check setings of its angle.
Sep 22, 2009 | Sanyo PLC XU35 Multimedia Projector
New globe - instructions not in english
http://online.projectordoctor.com/PLC-XU51
they have the lamp for about $300 (scroll down the page for the cheaper one).
Sep 11, 2009 | Sanyo PLC-XU51 LCD Projector
I have a Sanyo PLC xu38 projector broken receptical.
you should find a new db15 female connector, and install on to pcb, this required good knowledge of soldering...
Apr 20, 2009 | Sanyo PLC XU48 Multimedia Projector
Sanyo 6102641943 Projector Lamp for 5500N, 5500N Logo
64 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Rod Donovan
Rod Donovan
Level 1 Expert
k24674
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
