Question about SanDisk Sansa e260 MP3 Player
Can't sync with wmp 11
I have windows vista and I am unable to sync to a portable device. At one point I was able to do this and now I am not. I can play my playlist..but as soon as I plug a device into my usb port windows player shuts down.
    Problem Solver:
  • 8 Answers
On your player, go to Settings, USB Mode, and switch to MSC. After that, plug your player into your Windows Vista and now you can input music on your player manually. To do that, go into your player's storage from "Computer" and you will see a folder "Music". If you do not see it, it is because it is hidden. To unhidden it, simply press ALT key when you're still on the device storage. Tabs will pop up on the top. Click "Tools" and then click "Folder Options...". You will see three tabs. Click the "View" Tab. Look at advanced options and search for the sentence "Show hidden files and folders". You will be able to mark it so that you will be able to see the hidden folders/files in your player/laptop/computer. After you mark it, close the window and go back to your device storage. Now you will see transparent folders. If you see the music folder, you can just right click it, go to properties and look at "attributes" on the bottom and uncheck "Hidden". Now you can go back to tools and switch the hidden files/folders back to hidden so they don't show up hidden files on your laptop/computer (optional). Now you can manually switch/edit songs on your player without syncing. If you'd like to sync songs instead, you can format (reset) your player by plugging your player on your vista and go to "Computer" and right click your device when you see it. Click "Format..." and your device will reset itself. I recommend you manually editing your songs if you don't want your player to lose any files. If it still doesn't work, I think you need to get a new windows media player version if youd didn't get it yet.
Posted on Dec 28, 2008
Cant get any of my wmp 11 music to download to it
You can use the easyRip software's Player Loader module to easily put music on the device. Otherwise, you can always drag and drop media using Windows Explorer or use the WMP Sync option (may require the device to be in MTP mode)
Nov 11, 2009 | Audio Players & Recorders
My WMP 11 on Vista will not recognise my philips
Could be driver problem. You can try reinstalling the driver for the device. If it's a vista system, you might want to run the executable file in administrator mode, or even change the compatibility to XP.
Uninstall the current installation of the device software.
  • Insert CD in CD-ROM
  • Right click on the setup file
  • Choose properties / Compatibility Tab
  • Set it to XP
  • and tick the box at the bottom run as administrator.
I hope that help.
Aug 16, 2009 | Philips HDD1630 MP3 Player
Error when trying to download MS strrets and trips 2006 w/ GPS lo
I have used every version of streets & Trips since 05, and have never had any issue with Win Media Player, currently using streets 2009 on one machine with Windows 7 RC1, which has WMP 11, and on another PC streets 2008 and Vista with WMP 11. You may need to change your default program settings for media back to WMP if you ever had another media player installed.
Jun 13, 2009 | Microsoft Streets & Trips GPS 2006 x GPS...
Sansa e260 won't accept songs
Hi Janworks4u. Question for you... Did your mp3 work fine with WMP 10? I ask because WMP 11 is known for causing problems w/mp3 players. You can try reverting to WMP 10 to see if that fixes your problem. To do this:
click START, click on CONTROL PANEL, ADD OR REMOVE PROGRAMS (look at the top center of the Add or Remove Programs box that pops up for a little square you can click on that says "show updates." Click that box and then scroll down to WMP 11. Click to change/remove. A box will pop up confirming that you will revert to WMP 10. NOTE THIS WILL NOTE DELETE ANYTHING FROM YOUR COMPUTER! All of your music that is in WMP 11 will still be there in WMP 10!
Now you can try to load your songs back on through WMP 10 and hopefully it'll work for you. Good luck!
Sep 29, 2008 | SanDisk Sansa e260 MP3 Player
Redgroove pt544 mp3
The songs are copyright encrypted - convert them to mp3; that is the problem with WMA format. Also, make sure you have the Windows 2000 driver.
The instructions in these pages, which are largely links, pertain to Windows Media Player 10 and 11 only.
Windows Media Player is made by Microsoft. The general help page for Windows Media Player is:
http://www.microsoft.com/windows/windowsmedia/default.mspx
Through this link, you can enter a variety of search terms that will help you find what you are looking for (exs.: “add files to my mp3 player”; “delete files from my mp3 player,” etc.)
Important Vocabulary:
The code word for “mp3 player” in Windows Media Player is “DEVICE” or “portable device”
The code word for adding files is “SYNC,” “syncing,” or “synchronizing”
The code word for copying files from CD is “RIP,” or “ripping”
The code word for files stored on both My Computer and my Mp3 player (when it is connected to the computer) is “LIBRARY”
To add files (SYNC) to your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/wmp10/harrison_wmp10.mspx
To add files (SYNC) to your mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/player/faq/sync.mspx
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
To copy (RIP) files from CD to Mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/getstarted/ripcd.mspx
To copy (RIP) files from CD to Mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/easystart/mp11guide.aspx#RippingCopySsongsfromCDstoYyourCcomputer
Mar 10, 2008 | iRiver iFP-895 MP3 Player
Can't install MTP drivers
As I like MTP mode a lot better than MSC (I can use WinAmp to sync and it doesn't have to restart and refresh its database after disconnecting) I didn't like a lot of the solutions to this and similar problems telling to go to MSC mode.
However, I was able to go into Device Manager (right click on My Computer, click Properties, select "Hardware" tab, click Device Manager) and find the Portable Devices sublist, right click on "Sansa e280" (it had a yellow exclamation point on it) and click install driver. I followed this through, selecting automatic installation for the driver, and presto! Sansa is installed and ready to go. I actually had Windows Media Player open during this process, and while it wouldn't recognize it before, after doing this process, I went back to WMP and it had already found it and was trying to get me to sync it. So if you like MTP, try this. It worked for me.
(Note: this method may not work, unless you tried to plug the player in and it told you that there was an error in setting up the device. My problem was that I had installed WMP 11, but had not done the final "setup" process. After I had run WMP 11 for the first time, I was able to do this successfully).
Feb 06, 2008 | SanDisk Sansa E280 MP3 Player
Syncing
It is possible that you do not have Windows Media Player 10 or 11. If you do have WMP 10, then try resetting the GoGear first (with GoGear turned on, find a small paperclip or other such device, and press it into the reset hole; it works when the player turns off). Try syncing again.
If you have WMP 11 or Windows Vista, perform a firmware upgrade:
just open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website; click on the Update tab - this will give your player the firmware upgrade.
If these methods fail, reply to message using FixYa website (not my personal e-mail).
-Tha Mp3 Doctor
Jan 13, 2008 | Philips GOGEAR SA6045 MP3 Player
Possible Incompatibility with WMP 11: Deleting Recorded Files
Its Nothing YouCan Do I Tried Everything...This MP3Was Set Up For The Older Version Of WMP Because At Work I Have WMP 10 And It Works But A Home I Got WMP 11 And It Doesnt Work...Its Just Something To Kee You Coming Back TO Buy Their Items
Dec 08, 2007 | Samsung Yepp YP-T7JX MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
