Question about Clarke Air Tools & Compressors
Clarke air compressor ac2500 - not working - no compression
Was using my compressor today with a brad nailer and it was working find. Suddenly the compressor starting making a huming sound. I turned it on and off, several times, checking the fitting, but no luck. Isthe humming a sympton of the motor seizing? I have not used it much and have not did any maintenance. Help
  • ian stalker May 11, 2010
    sounds like either the motor or the pump may be at fault
    is the unit belt driven?If so remove the belt and by simly turning the pulleys will tell you witch is at fault ,otherwise you will have to take the motor of the pump on a direct drive unit to find wich one is at fault .please contact me again once you know and hopefully i may be of further assistance
    best of luck ian
  • 52 Answers
Your pressue builds up and stays trapped in head which causes the motor to lock up. Your pressure switch is probably bad.
Posted on Jan 14, 2009
Air compressor does not shut off at 150 psi
If its new take it back. If its used,, the pressure regulator is not working. Make sure the pop off valve is working, safety first.
Oct 10, 2013 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
I am trying to obtain 18 gauge brad nails for a clarke air nail gun ,can i use any type of straight 18 gauge brad or do clarke make brads for their own tools
you should not have any problem with using any other brand of nail .18 gauge brad nail are pretty much the same in all brands.
Mar 30, 2011 | Air Tools & Compressors
I just bought the Bostitch SB1850BN 18 gauge brad nailer with the Bostitch CAP2000P-OF air compressor. When I hook the hose up and start the compressor, I cannot get the nailer to fire a nail. Only air...
Check the position of the switches and selectors. It sounds like you are in between settings. Also, put in a few drops of oil, and try your gun out on scrap wood, so oil doesn't come out on your good work.
--W/D--
Jan 21, 2011 | Stanley Bostitch SB1850BN 18Gauge Brad...
I want to use a 120psi brad nail gun on a clarke ranger 115psi compressor ..will it be ok
It'll be perfectly fine. Wear safety glasses with them nail guns, they can really send a nail flying.
lp
Dec 29, 2010 | Clarke Power Products Clarke Pioneer 2 Hp...
Does the brad nailer only use 2" brads or cam smaller nails be used also
Most nail guns are labeled with the longest nail/brad they can shoot but are capable of shooting shorter nails/brads. There should be a data sticker on the gun, usually on the magazine rail, or at least in the manual that tells you what pressure to operate the gun at, what guage brads the gun can shoot and the size of brads from shortest to longest it can handle.
Oct 22, 2010 | Sears TNT 3 gal Air Compressor with 2 in...
I have a Porter Cable brad nailer BN125A, at 125 PSI and depth adjustement turned to the deepest drive setting, the brad does not set flush with the surface. Problem?
A brad nailer in good working order, set to the deepest setting and using 125psi should almost shoot the brad through the wood. If you have been oiling the gun properly (three to four drops at he beginning of your work session and again in the afternoon if under constant use) then you probably have some worn o-rings inside the gun. Porter Cable makes a driver maintenance kit (PN1001 60062) for your gun that will make it work like new.
Oct 04, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
Hello My PC 18ga brad nailer its piston wont retr...
Check the regulator gauge on your air compressor to make sure you have enough air pressure going to your nailer. After replacing my nailer because the driver wouldn't retract, I discovered, when the replacement nailer had the same problem, that I had somehow turned the regulator and decreased the pressure. Now I have two fully operational nailers.
May 20, 2010 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
I have a poter cable brad nailer and after running
Sounds like a trigger seal. I assume this is an oil-less brad nailer as that is the standard. You should be able to find the seals at any local hardware store including Home Depot or Lowes. If you can't find the portercable O-rings just grab the random assortment from Bostitch which is usually readily available. Refer to your parts manual for the correct size/gauge
Apr 15, 2010 | Porter Cable Cable Brad Nailer and...
Dont know what nails to use on my makita brad nailer
is that a model AF505? if it is, your problem may be the gauge. make sure you use 18 gauge nails, he 16 gauge are too big and will jam in the gun.
Feb 26, 2009 | Makita Brad Nailer Finish Nailer...
Air Tools & Compressors Logo
234 people viewed this question
Top Clarke Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Clarke Air Tool and Compressor Expert? Answer questions, earn points and help others
