Question about Canon NP 6050 Copier
Copy result is blur and I see the acceleration of paper too fast
Copy machine Canon 6650 II
  • Canon Expert
  • 1,326 Answers
When you say Blur? Is it a scattering of toner or is the whole image blurred or out of focus? You may have a problem with the lens HP or a problem with the scanning mirrors. Do you get a error code? Is the blur like toner strikes down the page? Check you corona wires and look for any small pieces of paper that maybe lodged in or around the drum unit. You may want to give a little more info. on the exact problem, to narrow down the cause
Posted on Dec 28, 2008
Copy result is blurred
Does the printer scan OK?
Is the platen glass clean?
Dec 10, 2013 | Epson ME OFFICE 620F MULTIFUNCTION INKJET...
Mesin saya canon np 6650 II, mesin tidak jalan, pada layar monitor tertulis E210 remettre copieur sous tension, bagaimana ?
Mesin saya canon np 6650 II, mesin tidak jalan, pada layar monitor tertulis E000 remettre copieur sous tension, bagaimana ?
Feb 07, 2013 | Canon NP 6650II Copier
Mesin saya canon np 6650 II, nesin tidak jalan, pada layar monitor tertulis E001 ! turn the power on again, bagaimana solusinya?
PAGI gan saya mau tanya foto copy saya NP6650 II di monitor ada tulisan nya 002 ! TURN THE POWER ON AGAIN BAGAIMANA SOLUSINYA TRIMA KASIH
Nov 11, 2010 | Canon NP 6650II Copier
Blur about one inch from trail edge 2270
Do you hear any kind of a thump thump noise when the machine is running? These machines flat spot the fuser rollers easily and this will cause a blur line towards the trail edge of the copy. This is because the trail edge of the paper is still having toner applied to it when the paper is going thru the fuser. When the flat spot "lops" over itself it puts a quick yank on the paper and creates the blur. If you are hearing any kind of thumping noise this is the cause and you will need a service person out to replace the pressure roller in the fuser.
Good Luck and Thank You for using Fixya.
Mar 16, 2010 | Canon imageRUNNER 2270 Copier
Canon PC921 copier has blurry section on copy
what you probably brushed over was the transfer roller(black and spongy?). first try running 20 or 30 blank copies through the machine. If that doesnt work take a dry paper towel and gently wipe and rotate that black roller. that should take care of the problem. If the roller needs replaced you should have a technician do it. You could break the machine beyond repair.
Apr 07, 2009 | Canon PC-921 Black and White Copier
1/4" weak, blurred line from top to bottom of page on every copy...has new drum, cleaned optics and glass, including **** glass...
hi, if the class is clean and the drum is not bad, this means is the fuser unit role cause this problem, but sometimes the cleaning blade too do this when it becomes bad and it doesnot clean the drum well. to help you trouble shoot this problem do this:
open the document feeder donot put any paper on class, and hit start, let the ,machine copy when the feeder is up and no paper, the copy will come black paper, check it if u still see the line there this means the fuser, if not its cleaning blade or drum.
let me know wat happen and if u have pics will help too.
Best Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 10, 2009 | Canon imageRUNNER 2000 Copier
Blurry bottom 2 inches of copy from IR 1600
Take a Normal,reduction and an enlarged copy(at any ratio) of a Newspaper in different size papers. Then check whether the blurred position is at the same position or not.If it is at the same position, check scanner for its free movement, there may be an obstacle which will not allow the scanner to move freely resulting in blurred copy. or else let me know.
Dec 27, 2008 | Canon ImageRunner 1600 Copier
Fax problem
How is the copy when you try to just make a copy of something? If it copies good, then it might be the senders machine.
If when you make a copy, and the copy is blurred, then it is probably your ribbon/ink cartridge.
If it is the cartridge, just replace the cartridge, and you should be good to go.
Hope this solves your problem.
Good luck.
Mac =)
Feb 09, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Canon ir5000
hi im jules_09.have you set the paper size first before copying.there is nothing wrong with adf its fine.if you want to use fls go to the program then set the size of the paper and which tray you are going to use each paper tray can be adjusted according to your paper size needs
Nov 06, 2007 | Office Equipment & Supplies
Canon pixma mp780 Copying mode very slow
is this using it on its own[Stand alone mode] or through the computer?
May 13, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon NP 6050 Copier Logo
150 people viewed this question
old marine
old marine
