Riello burner will not pump oil to nozzel to burn.
Have a f3 model riello burner that went out, replaced new filters, photocell, etc.can not get fuel to the point of ignition. also replaced
new pump.
Revisit the photocell:
1. Check if you connected the socket end, into the two pins properly, as it is possible to miss a pin.
2. Try to borrow a working photocell or use yours in another burner to make a determination.
Posted on Jan 03, 2009
Riello 40 burner giving off black smoke,new pump and nozel installed same problem?
Black smoke indicates a lean burn - meaning that the fuel to air ratio is to great for optimal combustion. This will cause a soot condition in the heat exchanger very quickly and drop efficiency. Too much air will make the burn to lean. The oil burner technician will do a smoke test and adjust the air intake damper on the burner motor as part of an annual tune up that includes setting the amount of carbon dioxide, excess air, stack temperature, draft and more. Doing so will provide the most efficient transfer of energy in the fuel to heat your building and prevent premature failure of the burner and furnace. To do this properly, you need the right test equipment - it can not done by "eyeballing" it.
Feb 25, 2014 | Heating & Cooling
Riello burner
You need to measure the manifold pressures before and after the gas valve and adjust accordingly to fuel used, 3.5" NG or 11" Propane.
Nov 06, 2013 | Honeywell Biasi B10-3 Boiler ,riello...
Wiring Diagrams
Check out this site
www.peerlessboilers.com/Products/ResidentialBoilers/
SeriesWBVWV/tabid/118/Default.aspx#dnn_relateddocuments
Oct 18, 2013 | Peerless WV-DV-04, Oil Fired, Hot Water...
I have a riello 40 burner it fires for 2 seconds then cuts out what could be the problem
If it actually fires up and you have a flame for 2 seconds and then it shuts off, I'd bet that the photo cell is either dirty or has failed. If it is dirty, it suggests that the burner has been neglected for some time and probably is in desperate need of a tune up. The photo cell is located under the ignition transformer and is aimed into the combustion chamber to see the light created by the flame from the burning oil.
If it is clean, the photocell has likely failed and will need to be replaced. If it still runs the same way after photocell replacement, it is probably related to the primary controller or one of the other safety devices. Is this a forced hot air or hot water system?
Oct 05, 2012 | Honeywell Biasi B10-3 Boiler ,riello...
I have a riello oil burner, starts to fire up for a few seconds and fails , fuel is ok any ideas please
i have a riello oil burner 40 F5, starts to fire up for a few seconds and fails , but then it will start for a few minutes...then shuts off... house is not being heated sufficient. There's hot water but after one shower the water starts getting cold....fuel is ok any ideas please
Nov 28, 2009 | SySTOR Systems (400S52) Burner
Oil went too low, now don't start
There is a bleed screw on the pump, turn a 1/4 turn to the left, and bleed until oil is free of oil. On older pumps, instead or a bleeder valve it is just a plug, you will have to remove the plug, bleed, then replace the plug
Apr 06, 2009 | SySTOR Systems (400S52) Burner
Burner propblem
have you tried to wipe off the fire eye on the unit if it has one? If it's dirty too then it will not see the flame and not let the unit come on correctly. Good Luck and have a Happy New Year.
Jan 05, 2009 | Heating & Cooling
Beckett home oil burner
problem is pump-must replace- there is a valve inside unit that holds pressure to about 150psi -it is leaking by when unit shuts down- causing problem. If left unrepaired you could blow chimeny connection with bad ignition. good luck
Nov 01, 2008 | Water Heaters
I have a riello burner for my central heating system. When i turn the heating on the burner ignites for a few swconds and then goes out.... the burner tries to re-ignite and the same happens. I have...
Replace the nozzle, don't try and clean it. After the burner runs a few seconds, do you have to reset the control (red button) before it will start again? Does it sound like there is a pulsation in the flame when it starts or it is running out of oil? You may have a bad ignition control. Start with the small stuff, nozzle, strainer filter, oil tank filter and then work to the more complicated.
Aug 01, 2008 | Heating & Cooling
Heating & Cooling Logo
987 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
