Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
Dish washer that does not pump out the water on it"s final cycle
I installed a new frigidaire dish washer Model # FDB4050LHB1 after the first cycle it will pump the water out but will not pump it out after the final cycle
  • Anonymous Jan 02, 2009
    our dishwasher starts ok and if fills but when it is done with the wash cycle it will not drain out the old water and just starts to was again
I had this same problem and after having the repairman over to our house several times and having the circuit board changed, I figured it out on my own...
It turns out that the pressure created from the steam during the water heating stage (HO) was pushing on the door latch just enough to prevent the motor from running properly. Because the door wasn't latched completely, the water wouldn't drain and the dishwasher would go to the "Drying" cycle without ever pumping the water out of the basin.
I adjusted the levelling on the DW and that helped, but I'm still not sure that the problem is fixed. We may need a new latch assembly.
To test this, when the DW stops running at any time, push on the door. If the motor kicks back on, this is the problem.
Posted on Feb 20, 2009
I have a new dishwasher, it fills with water, but water will not pump out
Posted on Nov 28, 2009
Dishwasher does not drain
Dishwashers do not drain the water has to be pumped out of them.
If the water is not being pumped out on any cycle then the pump has failed and you either need to replace the water pump (which will be quite expensive) or buy a new dish washer. Pump failure is a pretty common in part because of the amount of debris many users don't rinse from items before placing them in the washer. Also the filters at the base of the washer need to be removed and cleaned frequently and this is often neglected.
If the water is only remaining in the washer for the final rinse cycle but is otherwise being pumped out on the wash cycles, then the issue will be with the electronic control board.
Dec 08, 2015 | Frigidaire Dishwashers
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
Is it normal to have substantial amount water remaining in the washer after final spin?
Hey friend, thank you for allowing me to assist you!
It is normal to have water in the tub after your Frigidaire washer has completed the final spin cycle. The water that is in the tub is there to help prime the pump. Hope this information is helpful. -Matt
Jul 27, 2014 | Frigidaire Affinity ATF7000E Front Load...
I have a model FWT867GHS0 and serial number XC11512433, when it gets to the final spin cycle there is still water in the machine and it will not perform the final spin.
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump may need replaced
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Frigidaire 14 Cycle Tumble Action Washer
Dishes bottom rack are marginally clean. upper rack is never clean anymore. The dish washer cycles through NORMAL and Dries dishes OK. Motor is running, and rinsing can be heard as well as washing cycles....
Just fixed my Frigidaire. The outboard o-ring on the main pump became distorted and stretched. Check your local hardware store as Frigidaire wants $17.50 + shipping. Good luck
Dec 25, 2009 | Dishwashers
Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Water runs during final spin cycle
You have a blockage in the drain pump. Remove the front panel to access the drain pump.
Bail the water from the tub.
Remove the hoses on the pump and clean out the lint or garment from the pump.
Mar 26, 2009 | Frigidaire Washing Machines
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Dishasher does not drain
If it gravity drains, but the pump does not push out the water.......replace the drain pump. I just repaired an 8-year-old  Frigidaire dishwasher with this very problem, and although it sounded like the pump was operating, it was not....it was just vibrating. I replaced the drain pump and it now works perfectly. I am a service tech with 38 years experience.
Jun 21, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
774 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
