Question about Acer AL1715s (Silver) 17" LCD Monitor
Acer AL1715s i hvae acer lcd monitor al1715s 17" while working some white pixls appears around the dark areas, and it rises through the time. my lcd do that many times in the last three monthes.
  • Acer Master
  • 12,061 Answers
Hi, Maybe it is a stuck pixel try this link perhaps this will give ya some insight ... But it sounds as if ya monitor is going flakey :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Posted on Aug 01, 2007
Hi, I have an Acer AL1715s monitor and the VGA cable is cut about 5 cm from the backside. The monitor has no VGA input on the back but is connected inside with a 13 pin connector. I have to make a new...
you have a rgb connection or a dvi connection.
do not engineer your own version of a vga/dvi cable.
just go and buy a new cable, which should be cheap
here is a service guide for this monitor
http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/s.g_al1715_book.pdf
Oct 15, 2010 | Acer AL1715 17" LCD Monitor
Where can I buy an Acer AL1715 monitor from, I have checked ebay and many price comparison sites but no luck =(
Hello frebib, I found one on on EBay from a top rated seller. Here is the link: Hope this helps! Edward
Aug 24, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Hello i have a acer lcd model AL 1715 SM it doesn t have a vga input and cable is damaged how do i chenge it
Apr 07, 2010 | Acer AL1715 17" LCD Monitor
My acer al1715 has a pink tint. It started
This is a low-end monitor and the image processor is failing. You will require a replacement but since the monitor is low-cost, it is cheaper to simply by a new one.
Jan 20, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1715 no lights
We are seeing this same "issue" with this model regularly. If there is no screen and No led/lights, then the power supply has gone out.
It appears on that model there is an external power supply.
Google the model number of the Monitor for replacement parts.
Plug something into the same outlet and verify the outlet is good.
Oct 20, 2009 | Acer AL1715 17" LCD Monitor
Monitor acer lcd AL1717a
Looks like you have a burned lamp.
Most LCDs have a lamp that lights the screen's image.
If you see the image, but its too dark.....you need a lamp replacement.
Please rate this answer if its useful
Jun 18, 2009 | Acer AL1715 17" LCD Monitor
Trailing of discolouration when mouse moved
Got it working by adjusting the hardware acceleration.
Nov 25, 2008 | Acer AL1715s (Silver) 17" LCD Monitor
Acer AL1715 Monitor - screen distortion, discoloration, several times each day
Certain versions of the Acer AL1715 monitor had a problem with the VGA socket. Specifically, the plastic case around the socket was not wide enough. The plastic lip interfered with the plug and so the plug does not seat properly. This causes all sorts of intermittent problems. The version of the AL1715 with the problem with had the UPC code of 0 99802 19889 3. I fixed several of these monitors by shaving off the excess plastic with a Dremel Mototool. A hand file would probably work as well. You have to remove the plastic back to get the clearance to do the job.
e82875f5-b8a2-4548-9fdb-e60e2a37e9f1.jpg 14e1c79c-dd10-4643-b23c-053cfb0678e4.jpg fcd3ba29-2571-453c-838f-32c7fa61078d.jpg 038eb9e5-53a2-4fa0-88b9-56eb63be9378.jpg 19ef87e5-fc9a-423a-af2e-b0d949b0e884.jpg 092e022f-c3ac-4aa4-86ff-99eaa0075f07.jpg fe6adb60-288d-425f-9d35-156c724a2285.jpg
Oct 30, 2008 | Acer AL1715 17" LCD Monitor
Certain versions of the Acer AL1715 monitor had a problem with the VGA socket. Specifically, the plastic case around the socket was not wide enough. The plastic interfered with the plug and so the plug did not seat properly. I fixed several of these monitors by shaving off some of the plastic with a dremel mototool. A hand file would probably work as well. You have to remove the plastic back to do the job.
Sep 02, 2006 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1715s (Silver) 17" LCD Monitor Logo
123 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
