Http://www.techsupportforum.com/hardware-support/motherboards-bios-cpu/208408-solved-how-do-reset-bios-password-toshiba-satellite-a135-s2276.html
Re: How Do Reset Bios Password In Toshiba Satellite A135-s2276 ?
1)Remove Laptop Battery
2)Take off Memory Cover(underneath - square cover, Sits
in middle of laptop 1 retaining screw
3)Using two thumbs spread spring clips to outside and
pull out RAM memory.
4)Remove clear vinyl label opposite RAM memory slots in
upper left corner( laptop battery slot is on right, DVD
drive is facing away from you)
5)Using a magnifying glass (unless you have perfect
vision)in the upper left corner you will see JOPEN1 with
a white silkscreen square next to it . Inside the square
you will see what looks like the letter T over a U.
Using a metal paper clip short the U to the Silver 1/4"
post connecting the motherboard to the laptop case(this
is you ground, it is located above what looks like a
silkscreen outline of a chip)hold for 25 -30 seconds.
6) Place back your RAM memory, put in the laptop battery
and test start laptop. you should see a selection of F1
or F2 for setup. Using the F2 gets you into the Bios
menu where you reset the time and date. Then Tab over to
the SECURITY setting tab and change your passwords. Now
hit F10 key ,yes to save and your done!
Note: if your having trouble your most likely grounding
the ground(that blob of solder about 1/8"dia on both
ends of the "silkscreen chip outline" This is about as simple as i can break it down
tell please ! i ready for do this now ...
