Question about KitchenAid KEMC377K Convection / Microwave Oven
Kitchenaid display reads insert temperature probe oven is inop
Oven does not operate just beeps
    Problem Solver:
Told this rip off site to go to hell
Posted on Dec 27, 2008
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Jul 31, 2014 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My kitchenaide convection oven is displaying the E1 F4 error.
KitchenAid ovens are popular for their classic design and simple user interface. When a problem occurs in the function of a KitchenAid oven, an error code will display on the clock as soon as the malfunction registers in the oven's memory. Each code corresponds to a particular type of malfunction. Most can be corrected by disconnecting the power supply for one minute and then restarting. If the code persists, either replace the indicated part or contact a service center. F0/F1
  • The F0 and F1 codes refer to electrical issues. If the code appears as only two digits, the problem is a transistor failure, so you must replace the electronic range control (ERC). If the code displays four digits, it will read F0-E0, which indicates a failure switching from analog to digital, or F1-E1, which refers to a safety flip-flop. Both problems require the replacement of the ERC.
  • F2/F3/F4
  • The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
  • Nov 22, 2010 | Microwave Ovens
    I've misplaced the operating instructions for my williams sonoma remote meat thermometer. I can't get the probe unit/base to sync with the remote transmitter or to show a temp on the base unit and find a...
    This is for a model ET-903WS: Turn the base unit on first. This is the unit with the larger display & buttons. Hold the power/mode button (upper left) down until you hear 3 beeps and the display lights up. Mine then displays "BEEF" and shows 160, with 3 blinking spaces. Next, plug the probe into the smaller remote unit. You should get 1 beep, the remote will display the temperature and the base will now display the same temp where the blinking spaces were. The first couple of times I tried, the base would not display. Unplug the probe, turn the base off holding down the same power/mode button and start over. I've had to do this as many as 4 times but it has worked perfectly while I wrote this!?! I really like this thermometer because I can put the meat on the grill go inside and have a drink while watching the game and then a friendly voice comes on when the internal temp is within 10 degrees of your target and says: Your food is almost done...your food is almost done." If you sleep through that, she comes back on at temp and says "Your food I'd done...your food is done". I take most meat off at the first warning and wrap it in foil. Watch the probe and it will continue to rise for about 20 mins. Enjoy.
    Aug 08, 2010 | Microwave Ovens
    I have pluged in the temperature probe into the wall of the oven as well as inside the turkey. Now what..where do I see the actual temperature of the meat?
    You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
    Dec 24, 2009 | KitchenAid KEMC377K Convection / Microwave...
    Kitchenaid built in Microwave model YKHMS155LSS-0 Starts by itself, displays PAN, beeps intermittently and sometimes displays an F1 error
    Dougmcduff have you resolved this problem with you kitchenaid microwave turning on periodically??? I have the exact same problem. Any solutions? I called Kitchaide and no help there.
    Mar 10, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
    Spacemaker beeping loud and f3 message driving us crazy
    The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
    I recommend calling a service technician to diagnose and repair your oven.
    Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Have a kitchenaid superba part no. 4450786A with the probe indicator beeping for a temperature to be set. Prior to beeping started just used microwave to warm food; didn't need or use probe. What is...
    Put the probe in the oven and beeping stopped. Left it in overnight and next morning took the probe out and there was no beeping. Have not heard beeping all day. Don't know why this worked but it did.
    LaMason
    Oct 12, 2008 | Microwave Ovens
    Kenmore Microwave Displays Error Code Reading "Prob"
    I would bet that the temperature probe socket has some accumulated grease, etc. in it which may be changing the resistance of the contacts, making the control board think the probe is installed but defective.
    First, please unplug the oven before you investigate.
    The best idea is to clean the probe socket contacts.
    You'd need to remove the outer cover, and the probe socket should be located on the right side of the chassis.
    If you can cut thin strips of fine sandpaper and work them back and forth between the contacts, that's the best way.
    You can plug & unplug the probe while observing the socket to see how the contacts work.
    Your socket may be sealed, and that would possibly require you to carefully take it apart. That's a bit of a gamble, as it may crack due to age.
    Another idea is to take a wad of paper toweling, hold it with your right hand over the back of the probe socket, and spray contact cleaner or WD40, etc. into the opening of the probe jack from inside the oven cavity with your left hand.
    Then plug & unplug the probe several times, wipe any spills and try the oven again.
    If the probe unplugs form the control board, you could disconnect it and try the oven.
    Let me know how it goes.
    Aug 02, 2008 | Microwave Ovens
    Kitchenaid microwave oven KBMC140HSO
    I started having the same problem with my KBMC140HSSO. You cannot see the error codes without disassembling the control panel (the codes are on another display that covered by the front panel). After doing so I found the error code to be F2, E3 which is "Key held down too long, or key shorted". I am ordering a replacement keypad and will report back if this fixes the problem.
    Mar 29, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
    Gas double oven--Roper
    This code means you have a bad temperature sensor or thermal fuse, or a fault in the wiring harness to or from one of them.
    You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
    Nov 19, 2007 | Microwave Ovens
    KitchenAid KEMC377K Convection / Microwave Oven Logo
    352 people viewed this question
    Top KitchenAid Microwave Ovens Experts
    William Miller
    William Miller
    Oloyede Monsuru
    Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
