Question about Epson Stylus 2200 InkJet Photo Printer
Epson 2200 printer ink pads
I just purchased a used Espon 2200. Seemed packed well. Set it up, turned it on, all the lights are flashing and it won't print. Contacted Epson support and they said "The error condition that you are experiencing is the INK PADS." Is replacing the ink pads something I can do on my own? Where can I purchase the ink pads?
  • ericmyers2 Jan 29, 2009
    i have the same problem thanks to losing the air breathers on my 2200 after leaving due to a hurricane. took printer, left the kitchen sink! now my pads are full of ink. soaked is more like it. need new pads AND a set of breathers. if anyone has a set of air breathers for the 2200 ciss, please contact me at ericmyers2 at gmail.com. thanks
  • Epson Master
  • 4,338 Answers
First download this Epson utility to reset the ink counter:
http://inkjetprinterhelp.us/epsonSSC.html
Read the disassemble instructions on this link:
http://www.fixyourownprinter.com/forums/inkjet/35177
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Dec 27, 2008
Espon printer's ink pads are at the end, how do i reset or fix it? thank you
Try unplugging the printer for a few minutes. Then plug it back in. When it runs through the initial set up it should reset.
Jan 18, 2013 | Epson Artisan 800 All-In-One InkJet...
Espon T 11 has "Service
Usually when you receive this error its either the waste ink pads,has already to much ink on it where the inks go to when you clean the printhead.
Try going in this site http://inkjetprinterhelp.us/epsonSSC.html and download the SSC service utility. then reset all the counters. After that the printer will be working fine, but there is a possibility that the excess ink will leak out on your printer. Hope this would help
May 19, 2011 | Office Equipment & Supplies
Hi expert of ESPON CX4400 machine: after I did change a new black ink pack on it, why the on and ink light flash so i couldn't let it work?
Ink cartridge is not seated. Take it out and push in until you hear a click. Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Aug 04, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Green and red light flashing
SSC Service Utility allows you to do many things to your Epson printer, Work directly with CSIC in Epson Stylus printers cartridges, Freeze internal ink counters, Reset internal ink counters even with empty cartridges, Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode, Hot swapping of cartridges supported, Resetting of protection counter (even then it is already full), More then 60 different Epson printers supported This allows many people with high printing demands to save money (program works with both black and color cartridges).
May 12, 2009 | Epson Stylus C43SX InkJet Printer
Epson 2200 ink replacement light stays on
I had the same problem with the light black and light magenta as well. It took trying only one new cartridge with the light magenta before it worked.
The light black took 4 new cartridges before it worked. I had called the Epson support center on this problem and after going through suggestions they made that did not work, I told the guy I had another new cartridge on hand. He said to go ahead and try it. This time the printer worked. He took my name and address and said the other cartridges were faulty. Epson is sending me new replacement cartridges at no charge.
Dec 04, 2008 | Epson Stylus 2200 InkJet Photo Printer
I have an Epson 2200 and the Light black ink light is on even thought I have a new cartridge in there. This is the second cartridge I've tried. Same thing. Any suggestions?
this means that your printer wast pad is full this is how you can reset your printer
  1. Turn off the printer power and unplug the power cord from the wall. Disconnect the computer interface cable at the back of the printer.
  2. After one minute reattach the power plug to the wall, but don’t reattach the computer cable.
  3. Hold down the ROLL and the PAPER ADVANCE buttons simultaneously.
  4. Turn the printer on. after 2 blinks, all the ink lights come on, then release the buttons being held down.
  5. Press and hold the ROLL button for 10 seconds.
  6. Release the ROLL button and the printer will initialize, which resets the Waste Ink Pad Counter.
  7. Once initialization is complete, turn the printer power off.
  8. Reconnect the interface cable.
  9. Turn the printer on and print a document.
  10. make sure you have got new wast pads in
EPSON 2200 - Waste Ink Pad Replacement
You can replace the pads yourself.... I wouldn't really mess with it though. There are other ways Google search "Waste Ink Epson 2200" to see how to setup an external tank.. I have mine setup this way and its been no problem.... If you're set on taking them out remove the screws from the sides and middle and the bottom will drop away and reveal the pads.
Mar 25, 2008 | Epson Stylus 2200 InkJet Photo Printer
2200 locked up
disconnect the printer from the computer - power off printer - check for obstructions / torn papers - power on
if paper light is still on/flashing and pressing it does not do anything - you got a hardware issue - call manufacturer for reccomendation
this might help also - http://www.epson.com/loyalty
Dec 23, 2007 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus 2200 InkJet Photo Printer Logo
432 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
