Question about Fujitsu Siemens Lifebook C2230 Notebook
Auto shutdown and troubled startups.
Ma Fujitsu Lifebook c2230 occasional crashes or shutsdown on its own. Usually while doing something relatively processor intensive, but nothing it hasn't been able to do in the past. Startup is also an issue. The Fujitsu screen will appear, then it will often just shutdown again, before booting windows. I usually need to try 3 or 4 or more times before it finally boots up properly. It seems to be more of a hardware problem than a software problem, but I don't know. Maybe a good old fashioned reformat will do the trick, but I wanted to check if this is a known issue.
  • Jim Robinson Apr 20, 2007
    I have cleaned out the fans and it (the fan) is running fine. I will try th memtest
  • Anonymous Mar 20, 2008
    i have fujitsu c2230. from some days it is not starting infact if i press start button it stats for 2 to 4 seconds and turns off suddenly. i opened up and cleaned all contents. Pls tell me what is the problem, before 1 month it was running properly. one more problem some keys of it(Esc,I,O,P,[,J,K,L,;,") are not functional.
    President:
  • 2,961 Answers
Yes it sounds as if it's a hardware fault, maybe a processor overheating by the sound of what you say, just check around all the vents and gently hoover them incase there is a circulation problem and the processor is shutting down. It could also be a failing memory module, you can download a programme to test this called 'memtest' if you do a google on it, but alas not a processor test.
Posted on Apr 20, 2007
Fujitsu LIFEBOOK A6230 how to factory restore without the cd?
Usually there is a second partition on newer laptops that you can recover with. Look for a startup options when booting or a recovery options key, usually something like F5 or F10, then there will be options to choose from. What operating system are you using? You could possibly use a system restore state from the laptop first being setup.
Sep 18, 2013 | Fujitsu LifeBook A6230 (FPCM33401) PC...
I have a brand new Fujitsu Lifebook AH512 laptop, have not been able to charge the battery at all, plugged in, not charging, what should I do?
If it's brand new take it back to where you bought it from and tell them. Don't try to fix it within the 12 month warranty - that's what it's there for!
Aug 25, 2013 | Fujitsu Siemens Lifebook C2230 Notebook
How can i turn on bluetooth on a fujitsu b series lifebook
in control panel there should be an option for the bluetooth
Oct 01, 2010 | Fujitsu Siemens Lifebook C2230 Notebook
I can"t remember my password to enter my laptop
choose this link:
http://www.password-reset.com/file_download.php
Sep 21, 2010 | Fujitsu Siemens Lifebook C2230 Notebook
When I switch my wireless connection sith on at the front of my fujitsu lifebook S7010D the laptop encounters an error and closes down
Use another machine to download latest drivers from the following site: http://support.ts.fujitsu.com/com/support/downloads.html Search for
Device Driver - Intel® PRO/Wireless LAN 2200 BG - LIFEBOOK S7010
or alternatively use the Deskupdate to auto update all drivers for your S7010
Save the zip files to a USB key. Turn the wireless connection off using the switch at the front of your laptop. Unzip and install the new drivers. You should be good to go from here.
Good luck.
Apr 18, 2010 | Fujitsu Siemens Lifebook C2230 Notebook
I have dell laptop.Cursor is showing. caplock on
No display? but you have an mouse cursor showing? So you must have an display and it is locking on startup of the OS. Do you have an bootable cd? If not lets try to start it up in safe mode..
1: power down system
2: on power up hit the F8 key keep taping it till you get display saying startup in safe mode.
3: start up in safe mode no network.
4: if it starts up to an desktop then its an driver or software which you have installed causing normal startup to stop.
If it doesn't start in safe mode we will have to boot to an OS CD.
Let me know how these first steps go..
Feb 23, 2010 | Fujitsu Siemens Lifebook C2230 Notebook
Where can I get fujitsu c2230 sound drivers?
For Fujitsu C2230 Notebook PC's with either Windows 2000, or Windows XP, right here on Fujitsu Support,
http://support.fujitsupc.com/CS/Portal/supportsearch.do
Whoops FAILED! Tried to give you a direct link to the Drivers page.
(Have you ever seen those vid's of Failed? Like the skateboarder who went down the pipe railing, and wound up straddling it?
Ummm, ..err,...Never mind!)
Let's go the long way instead.
http://support.fujitsupc.com/CS/Portal/supporthome.do
On this page go to the right hand column, and under the white - Mobile Support - heading, left-click on - Driver Downloads
On this page you will see three headings at the top.
Select Product
Select Series
Select Model
Under Select Product click on - Notebook
Now under the Select Series heading, scroll the side bar down, and click on - C Series
Finally under the Select Model heading, click on - C2230
Click on Go, to the right of the arrow in the red square.
You will see the - Windows 2000 Compatible Drivers - heading, and
Windows XP Compatible Drivers - heading.
Go to the operating system you are using.
Left-click on Audio
Click on Accept on the next page.
In the small window that comes up on the top right, left-click on -
Save File.
If you do Not have your downloads, set to save to your My Documents folder, this file will go to your Desktop screen.
(My Documents for Windows XP. Documents for Vista.
Windows XP? Click on Start>My Documents)
The name of the file is C2230_AUDIO_REALTEK_V5.10.00.3696_2KXP.EXE
When you see the file name, Double-click on it.
The Installation Wizard will come up.
Follow the easy instructions.
(Basically just click on Next, Next, and Finish.
If you are asked to restart your computer, do so.
If you are not asked to restart, close all windows until you are back to your desktop screen. Restart your computer.
Start>Turn Off Computer>Restart)
The above, is stated that you are using your Fujitsu Lifebook C2230, to download the Audio, (Sound) driver.
If you are using another computer to download this Audio driver, download it to the computer, then right-click on the Audio file name, and burn it to CD disk.
Take the CD disk, and install it in the Fujitsu Lifebook C2230 optical drive, with the laptop on, and Windows loaded.
If your Fujitsu Lifebook C2230 has Windows XP, left-click on Start, then My Computer.
Double-click on the optical drive that the CD is in.
Follow the easy instructions of the Installation Wizard.
If you have problems, or further questions about this, post it in a comment.
Dec 24, 2009 | Fujitsu AMILO D-7820 Notebook
Need to factory reset fujitsu laptop
The label on the bottom of the laptop should give you more detailed information about the model number.... when you say you can't log on.... what exactly are you referring to ?
Robert
Sep 17, 2008 | Fujitsu Siemens Lifebook C2230 Notebook
Fujitsu Siemens Lifebook C2230 Notebook Logo
367 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
