I have no sound on my desktop computer. All volume controls are set to maximum, yet I cannot get a single sound from the speakers. I have a Compaq Presario processor and HP monitor. Any ideas?
    Problem Solver:
  • 6 Answers
(In order of things to try)
1. Make sure everything is plugged in properly (speaker power, connection from speakers to computer), etc.
2. (Clarification) By all volume controls, does that include the windows sound panel options? It may be on mute. Tell me what operating system you're using and I can help you with this one. Also, your keyboard may have a mute button. Try pressing that if it does.
3. Plug in another pair of speakers/headsets to your computer and see if those work. If they don't, it's either #2 or your sound card.
4. If it is definitely not #2, it is your sound card. You'll have to purchase a new one. Go to your local computer parts dealer to get one, they can help you. If you don't have one, buy one from www.newegg.com . Post questions here or on forums, don't waste money on someone from Geek Squad or anything. Installing sound cards and the like is pain-free and easy.
Posted on Dec 27, 2008
Internal speaker does not work
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
Sep 06, 2012 | HP Compaq dc7600 Small Form Factor PC...
Hp dc7600 S speker does not work
if you mean speaker does not work
reinstall drivers
hope this helps
Sep 06, 2012 | HP Compaq Business dc7600 PC Desktop
Sound (volume) of media player is at maximum but still very soft.
Go to your volume control via Control Panel or double click on speaker icon on task bar and check sound settings and computer volume or check your speaker's volume. Otherwise your speaker at fault.
Aug 25, 2011 | Computers & Internet
How do I turn off the internal speaker and only use the desktop speakers?
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
hope this helps
Mar 19, 2011 | HP Compaq Computer Speakers
Am using hp compaq desktop , my pc sound is not wrking,wat solution?``
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Jan 30, 2011 | Compaq Computers & Internet
I have just installed speakers on my computer, but I can't get any sound.
Check to make sure the speakers power up.
Check to make sure you have installed the speakers into the correct jack on the back of the PC.
Go into Control Panel and check the settings by double-clicking the "Sounds and Audio Devices" icon. Make sure the Mute box isn't checked and that the volume is turned up.
Dec 09, 2009 | Dell Dimension 4600 PC Desktop
BOSTON ACOUSTICS BA735 volume is LOWER than MAXIMUM LEVEL
OK, a few things here. First of all, what program are you using to listen to music? Some programs have an automatic volume leveling setting. If you're using Windows Media Player, it has one. Next, you should NEVER set any speaker/volume/amplifier knob to Maximum setting if you want to get any life out of your speakers. Speaker ratings are for consistent volume levels at a "clean" power level. When you turn any music source up past 80% you are pushing more distortion through the speakers that they cannot reproduce without self destructing. The human ear cannot hear this, and the volume gain is minimal. Next we'll talk about that your dealing with a combination of power levels compiling into an amplifier that may be taking in more than it can aptly amplify according to it's power multiplier scheme to increase the volume at the speaker level. If you've got everything maxed out, you're probably just pushing it all WAY too hard. All over exerted energy that is not being used productively will end up in generating heat and distortion. Those are your 2 biggest enemies when it comes to anything audio. Distortion tears voice coils and generates disruptive electrical currents, and heat destroys circuitry and components in amplifiers. The times where they jump up in volume, just look at that as borrowed time until they blow. If you want louder, get a better or more powerfully rated set, and still, NEVER turn it up past 80% if you want it to last.
Jun 09, 2009 | Boston Acoustics BA735 Computer Speakers
Sound
Click Start, Settings, Control Panel, then double click the "Sounds and Audio Devices" icon. Make sure the Mute box isn't checked and the Volume bar is at least 1/2 way on the Volume tab. Also click the Speaker Volume tab and adjust the sound there as well if needed. You might also want to check the "Place volume icon in the taskbar" icon so you can easily adjust the sound settings next time.
Apr 20, 2009 | Compaq Presario S5100NX (E120866) PC...
Only one speaker works
if you have plugged correctly without any losse contact it should work if not o think your speaker configration is not correctly set go to the control panel->sounds and audio devices->device volume->advanced there u set that balance slider to middle of all volume control,wave,sw synth,line in etc.. then go to speaker settings in the same window of sounds and audio drivers there in speaker settings click on advanced you get another window in that drop down box specify your speaker configration wether is desktop speakers laptop mono speakers or stereo headphones etc specify the right one you have then ok after this in speaker settings click on speaker volume and keep left and right speakers to maximum then apply ok this will work check it out if stil not worked tell me what ws the result ill solve that for u
May 07, 2008 | Cyber Acoustics CA-3550 Computer Speakers
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Jul 16, 2006 | HP Compaq nc6320 Notebook
Computers & Internet Logo
61 people viewed this question
Alun Cox
David Payne
David Payne
