Question about Mamiya 645 Medium Format Camera
Mamiya 645 1000S
The light meter does not come on. Red test button lights green test light and the battery measures 6.3 volts. Cleaned contacts between body and view finder. This view finder does not have a battery like some models. Camera has been sitting a long time.
  • browderjames Dec 27, 2008
    Yes, silly me. That's whats happens when you don't use your equipment for a long time!!!
    Thanks
  • 100 Answers
For complete details the link to the manual is given below for ur device:
www.mamiya.com/assets/pdfs/645/M645_1000S_v4.pdf
Posted on Dec 27, 2008
I have a strikers st#1blue scooter brand new it won't drive at all and the lights only come on when the charger is connected then the red orange and green lights are all on can anyone help?
Sounds like a defective battery. If you have a volt meter you need to measure the battery voltage, if you don't, you need to have the battery tested. AutoZone and Advance auto parts will test a battery and charge a battery free of charge, but you would have to remove battery or load scooter and take to have the battery tested.
Sep 20, 2015 | Health & Beauty
While I was charging the power chair all the indicater lights came on and with a block lights went from all green to 2 red flashing lights, w/ 2 red lights flashing I stopped and shut it off 4 five se
Two red lights blinking means the electronics on the chair think the batteries are low. Test the voltage on the holes marked 1 and 3. Hole 1 is positive and hole 3 is negative. Your meter must be set on DC volts and the meter leads must be in Common and Volts. If your meter has to have the voltage range set, put it on 200vdc. The red lights will blink if the voltage is approximately 22.5vdc or less. The green lights turn on about 24.5vdc or higher.
Sep 18, 2014 | Invacare Pronto M51 Power Wheelchair
Battery wont stay charged while running put in new battery problem still not staying charged.
Step 1. First things first, load test the battery. Most places like Auto Zone will do it for free. Even if it measures over 12.5 vdc it can still be bad under a load. Battery is typically rated at 19 amp hours and 270 Cold Cranking Amps (CCA).
Start the engine and measure DC Volts across the battery terminals, the regulator should be putting out 14.3 - 14.7 vdc at 3600 rpm and 75 degrees F.
Step 2. To check the regulator unplug it from the stator. Take a test light and clip it to the negative terminal of the battery and then touch first one pin and then the other on the plug that goes to the regulator. If you get even the slightest amount of light from the test light the regulator is toast.
To do this with a meter which is more accurate: black lead to battery ground, red lead to each pin on the plug, start with the voltage scale higher than 12vdc and move voltage scale down in steps for each pin. Any voltage is a bad regulator.
Step 3. On the other part of the disconnected regulator plug. Set the multimeter for Ohms x1 scale and measure for resistance across the pins of the stator. You should read something around 0.1 to 0.2 ohms for the TC88 32 amp system.
Step 4. Then check for continuity between each pin on the plug and frame/engine ground. The meter needle should not move (infinite resistance)(digitals will show infinite resistance) if the meter needle does move (indicating continuity)(digitals will show some resistance), recheck very carefully. If the meter still shows continuity to ground the stator is shorted (bad).
Step 5. Set the meter to read A/C volts higher than 30 volts (the scale setting for voltage should always be higher than the highest voltage you expect or you may fry the meter). Start the bike, and measure from one pin to the other on the plug (DO NOT cross the multimeter probes! - touch them to each other). You should read roughly 16-20 vac per 1,000 rpm.
Step 6. If the battery was good under load test, if the stator is NOT shorted to ground, and the stator is putting out A/C voltage, then the regulator is bad (most likely even if if passed step 2).
Jul 24, 2011 | 2001 Harley Davidson XL Sportster 883...
2003 lincoln navigator. The air ride compressor will not come on. Checked all fusses and relays and they r good. The compressor will run when u straight wire it. Why won't it come on automatically?
I know you stated you checked all fuses and relay and they're ok but The 2003 Lincoln Navigator had two differently (wired) air ride systems. A early production and a late one, and I think I may have a good Idea of what your problem may be and will walk you through how to properly test the system. The early production navigators used a solid state compressor relay and the later production units used a standard style relay. The early ones with the solid state type has been known to have some problems and working for a Ford, Lincoln Dealer for 21 years I have replaced a good number of these solid state relay for a air ride compressor inoperative concern. There seems to be some confusion on the location of the solid state relay. I would advise you to look behind your front bumper on the passengers side of your vehicle (and below your headlight) and see if you have a 4 wire relay that's aluminum and finnd ribs on the front of it and I believe a black base where the wiring connector plugs in. (this will be mounted to the radiator support) if so, you Have got the early production style. I will walk you through how to test this relay and also help you to isolate the cause of your problem. I highly recommend using a volt ohm meter for these tests. I do not recommend using A TEST LIGHT due to the fact that you will be testing a circuit that is wired to the air ride control module, and there is a possibility of you damaging the module with a test light !!! I have been there, done that, NOT GOOD.
Ok with that said: your wire colors should be as follows:
one that's( gray and red)
another that's (light green and red)
another that's (dark blue and yellow)
and one that (light blue and pink).
Disconnect the connector at the relay and you'll be testing the wires in the connector (THAT HOOK UP TO THE RELAY). The air ride compressor and the air ride solid state relay share the same ground which is the light green and red wire.
Turn your volt ohm meter to dc volts scale and attach the black wire (NEGATIVE) lead of the volt ohm meter to the light green and red wire.
Hook the red lead of the volt ohm meter to the light blue and pink wire.
Here your volt meter should read battery voltage (of your car's battery) if not check the (F2-111) 50 amp designated fuse in the fuse box under the the dash on the passengers side (KICK PANEL).
If this fuse is ok, make sure you were making good contact with your test leads into the compressor relay connector.
If you're comfortable with the fact that you have a good connection at the relay connector and your fuse tested ok, then you have a ground problem at ground point G101 which is located right near the mounting location of the air ride relay.
If you had battery voltage when you tested between the (light green and red) and the light blue and pink wires, you have confirmed the power source and ground to the relay.
I should clarify myself at this point. The wires at the relay are as such: The ground is the light green and red wire, the light blue and pink is the fused power source to the relay, the dark blue and yellow wire is the relay trigger source from the air ride module to the air ride relay, and the grey and red is the relay output (battery +) to turn on the compressor. OK.
So now we're down to checking the trigger source to the relay and the relay output. At this point I want you to re-hook up the volt ohm meter with the meter still set at volts d/c scale and reconnect the (red lead) of the volt ohm meter to the (light blue and pink wire) and connect the (black) lead of the volt ohm meter to the dark blue and yellow wire (again at the relay connector).
Now this next step is best done with the help of an assistant!!
While watching your volt ohm meter, have your assistant turn on the key and open and close the drivers door two -to- three times. After cycling the door, you for a short time should see at least 5 volts minimum, if not battery voltage at your meter.
(this is a little bit unclear to me due to the fact the air ride module shows that the dark blue and yellow wire, as a ground from the air ride module to the relay. but does not clarify exactly what value that ground signal should be). I am referencing Fords own wiring diagram.
A solid state relay usally is allowed a trigger source of a lower voltage then a standard relay. If you find you have no voltage reading at your volt ohm on this test, you'll first want to check fuses F2-20 which is a 30 amp fuse and F2-27 which is a 5 amp fuse in the same fuse box as the F2-111 fuse you checked earlier.
The last test you need to make at the relay is checking the relay output to the compressor. This will be done by again using the volt ohm meter. This time you'll want to hook the black lead of the volt ohm meter to the light green and red wire at the reay connector and hook the red lead of the volt ohm meter to the grey and red wire at the relay connector. Again for this test, you'll need to have a assistant turn on the key, then recycle the drivers door again.
If the relay is working properly you should have battery voltage, aproximately 12 volts showing on your meter. If not and all other test procedures results were correct, you have a bad relay.
If you have 12 volts on this test we have confirmed the relay is good and the trigger signal from the air ride module is operating as designed.
If the pump runs like you said (when it is straight wired ) the remaining possiblity is a broke wire between the air ride relay to the air ride pump (this being the grey and red wire) which you can test by switching the volt ohm meter to the ohms scale and touching one lead of the meter to the grey and red wire at the relay connector and the other to the grey and red wire at the compressor (with the compressor and the relay both disconnected). Your reading here should be 0.5 ohms or less. If you have under 1.0 ohms you're ok but specs are 0. 5 or less.
If you have an auto ranging type ohm meter, be sure your reading in ohms and not kilo ohms or mega ohms.
If you find while performing the test from the air ride module to the air ride relay (dark blue and yellow wire) referenced as the trigger signal, incorrect and all fuses all checked o.k. then it is possible the air ride control module is defective. But, before condemning the module, there are a multitude of input signal;s to the module that would have to be checked.
WARNING: Make sure your tests are accurate. Good to check and re-check each test. Be confident of your results.
Inaccurate tests and inaccurate test results= unnecessary parts replacement. Results are large dollars spent when unneeded.
Hope this helps you out.thanks for using fixya
Jan 03, 2011 | 2003 Lincoln Navigator
After leaving the last gas stop returning from a 1700 mile ride, the check eng light came on, the volt meter read 8-9 volts. Shut off the passing lights and the volt meter slowly rose to 11-12 volts. Next...
Ok, let's check the charging system. The battery is easy. Take the battery out of the bike and take it to an automotive parts store. Ask them to load test the battery for you. If the battery is over two years old, it could need replacing.
Once you're sure the battery is good and it is FULLY CHARGED, we can test the rest of the system. You'll need a DVOM (digital volt ohm meter) to check the system. With the battery back in the bike, connect the DVOM across the battery. Red meter lead to the positive terminal of the battery, black meter lead to the negative. Put the meter's function selector switch in DC VOLTS, 20 VOLTS or greater. Start the bike and bring it to a high idle. The meter should read 14.5 - 15.0 volts.
Now, to test the stator, follow the wires from your regulator down to where it goes into the engine cases. Disconnect the connector and look into the engine side of it. You'll see two metal contacts down in there. Set you meter's function selector to AC VOLTS, 50 VOLTS or greater. Start the engine and bring it to a high idle. Touch each one of the metal contacts down in the engine side of the connector with a meter probe. It makes not difference since we're measuring AC voltage at this point. The meter should read at least 30 volts.
Now, if the alternator (stator test) does not put out at least thirty volts, the stator is bad and needs to be replaced. If the alternator does check good but not enough voltage at the battery, your regulator may be the culprit. Make sure all connections are clean and tight and that the body of the regulator is grounded good. Recheck the test at the battery. If it still fails, replace the regulator.
Now, I've seen may problems such as your's that are intermittant. In other words, the problem is here on minute and gone the next. I fought that on one bike for over a year until we finally replaced the entire charging system and fixed it. If your bike proves to be doing that, you may wish to consider that option. Fix the thing and be done with it. I wouldn't buy the rotor, just the stator and the regulator.
Good Luck
Steve
Aug 31, 2010 | 2003 Harley Davidson FLHTCUI Electra Glide...
Battery #1 terminal lights red and stays red.
Disconnect the - lead from that battery, Repower the charger. The LED should be green. If it stays RED, charger defective.
Reconnect the - lead to the battery, measure voltage when charger is on. Should be between 11.5 and 13 volts. If OK, replace the battery. If lower than 11.5, check for charger cable connections OR for a connected load ( power drawing ) of more than 10 amps.
Sep 20, 2017 | Guest 2631a 30 Amp Battery Charger
Battery Light keeps coming on in my 1997 Windstar
Most likely there is a bad diode in the alternator. needs tested.
Jun 24, 2009 | 1997 Ford Windstar
Shure Wireless Mike no Output
Check the battery with a volt meter. If the battery measures lower than 8 volts on a volt meter, replace the battery. I have seen entire cases of brand new batteries that are defective. Make certain to check it with a volt meter. If the battery tests fine, then send the bodypack to Shure for repairs. www.shure.com/service
Dec 18, 2008 | Shure ULX1 Body-Pack Transmitter...
Mamiya RZ67 Camera Older model.
Problem solved- The camera does not operate correctly unless the battery is in good condition, in place, and all the contacts are clean. In the RZ76 as opposed to the old RB models the components "talk" to each other: via electronic circuits. The back "tells" the camera bod if the dark slide ins in or out and whether the film is loaded or at the end of the roll. If the batter voltage is too low or the contacts are no clean and making full contact the body has no way of knowing the condition of the film backs and the interlocking mechanisms fail to work.
What I did was firstly test the battery under load and discovered that the cell was a bit low. It was a fresh battery but it is a good idea to turn the camera off after shooting in case the is a slight current draw when the camera is idle (?) . I replaced the battery and traced the voltages through the body to see if it was getting to some of the contacts such as the onces on the meter prism which has LEDs to be lighted. I also used an ohm meter to check out continuity- everything seemed to be in order. I then cleaned all the contacts including the battery terminals withl alcohol and made sure everything was dry and clean.
Now- everything works. The camera was turned off overnight and the battery has lost no voltage when tested under load..
This camera is equipped with RB lenses which have no electrical contacts and therefore the camera and lenses can't "communicate" so the meter will not work with theses older lenses.
Ed
Apr 09, 2008 | Mamiya Photography
Mamiya 645 Medium Format Camera Logo
169 people viewed this question
Top Mamiya Photography Experts
Tony
Are you a Mamiya Photography Expert? Answer questions, earn points and help others
