I have a linksys wireless-g broadband router. A couple of weeks ago I became unable to connect to the internet through this router. I am able to connect to the internet, however, using a direct connection from my internet provider's modem, whereas previously I was able to connect to the internet by going from my internet provider's modem, which was connected to the linksys router.
What do I need to do to restore the previous set-up using this router?
Linksys reset
The easiest method is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
Since you did not include your exact model number and type of internet provider I cannot give you more specific instructions. Although you can refer to the links below on how to set it up. If you require further assistance just reply to this and give me the model number of your ISP and the model of your router. Also answer this question " When you plug your computer to your modem do you get online automatically or do you need a username and password"
lost wep key for philips adsl2, trying to install and asking for it! does anyone know how i can find...
(More)
lost wep key for philips adsl2, trying to install and asking for it! does anyone know how i can find it?
My BT home hub will not recognise the ethernet connected hard drive connected to the router, how do...
(More)
My BT home hub will not recognise the ethernet connected hard drive connected to the router, how do i get it to be recognised. It works when conneceted in usb mode to the p.c. but does not work when connected via LAN to the p.c ? can you help pls.
My opera browser gives a download speed of 95kbytes/sec on 512kilobits/sec, can I get it more by...
(More)
My opera browser gives a download speed of 95kbytes/sec on 512kilobits/sec, can I get it more by Port Forwarding router??
