Question about Nintendo Wii Console
Wii console will not power on regardless of outlet plugged into
  • 111 Answers
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqrtyctr-23
Posted on Jul 23, 2009
  • 82 Answers
Try the Wii "RESET".
Here's how:
1. Unplug the Wii for at least 5 minutes.
2. Plug it back in.
Posted on Jun 11, 2009
4 Suggested Answers
gamerfixer07
  • 344 Answers
SOURCE: Storm last night, now Wii won't power up
Unplug everything! There is a "breaker" in the power supply and it may need to be reset. Just unplug all cables from the TV and outlets. Let it sit for a couple hours then plug everything back in and it should work fine. If not then the power supply has shorted out due to a strong power surge. You can claim it under your home owners insurance or call Nintendo and try to get it replaced. Thanks! Good luck and happy gaming!!
Posted on Aug 31, 2008
paei
  • 14 Answers
SOURCE: wii console not turning on
185
Posted on Mar 22, 2009
localwonder
  • 6784 Answers
SOURCE: my wii console will not power on. have checked
HI. the power supply board has failed. There is a fuse(3amps) inside the power supply unit. you will need to remove the cover from the power supply to access this fuse. once inside the power supply, inspect the fuse. if it is truly blown, replace it. if the fuse is not blown, this will confirm a failed power supply unit. it should be replaced in this case...
Posted on Aug 05, 2009
Hook up to the Wii
Alright so first of all, you should have gotten a cord with a big, grey power brick attached to it. Plug the end in that goes in a outlet, and the other end should hook up to one of the outlets on your Wii console. Then, there should be a cord with three branches. They should be colored red, orange/yellow, and white. On the back/front or on the cable box for your TV there should be plug-ins that are colored either red, white, green, blue, or orange/yellow. The specifications should be written under the outlets (visual, audio, etc...). Plug the white and red part of the cord in to the "audio" outlet (on your tv). The other cord (yellow/orange) should plug in to the outlet that is labeled "video" or "visual" or "screen" or something along the lines of that. The next step is pretty simple. Your Wii (should have) came with a sensor bar. It is thin, long, and black and has a very long, very thin cord attached to it. Plug one side of the cord into your Wii console, and the actual sensor bar goes on top of your TV. There are small, sticky rectangles that help with the sensor bar sticking to your TV. After you've done all that, your Wii is ready to go! Just push the power button and your ready to start playing!
Nov 28, 2013 | Nintendo Wii Console
Wii wont power on
Wii Console Won't Turn On, and Has No Power Light
Situation:
The Wii console won't power on, and the Power LED is unlit
The console powers on, but shuts off after a few seconds/minutes
Attaching an accessory to the console turns the power off
Information:
This issue can be caused by an accessory or power surge tripping the circuit breaker on the AC Adapter.
What To Do:
Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
Oct 29, 2012 | Nintendo Wii Console
My wii won't turn on
Wii Console Won't Turn On, and Has No Power Light Situation:
  • The Wii console won't power on, and the Power LED is unlit
  • The console powers on, but shuts off after a few seconds/minutes
  • Attaching an accessory to the console turns the power off
Information:
What To Do:
  • Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
  • Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
  • Perform an AC Adapter Reset. (How To)
Dec 23, 2011 | Nintendo Wii Console
What's your problem? the wii wont turn on
    • 1 Disconnect any accessories, such as GameCube controllers or SD cards.
    • 2 Unplug your Nintendo Wii AC adapter from the wall outlet and from the back of your Nintendo Wii. Leave the adapter disconnected for two minutes. Reconnect the adapter to the console and plug the outlet end straight into a wall outlet, not a surge protector.
    • 3 Remove the AC adapter from the wall outlet again. If the Wii has yet to turn on, the problem may lie within your electrical outlet. Plug a lamp, nightlight or something electrical into the outlet the AC adapter was connected to. If the outlet appears to work, then you'll have to test the AC adapter itself.
    • 4 Run your fingers along the AC adapter cable and visually look for any damage, such as frayed wires or a cracked piece of cable. Also look for the model number "RVL-002" and "Wii" on the adapter. If you don't see the "RVL-002" model number and "Wii" on the adapter, then you are using an unlicensed adapter, which can cause instability and power failure. If the adapter has incurred any damage, you will likely have to buy a new adapter.
    • 5 Spray air to clean out the vents on the back of the Nintendo Wii. If your Wii has been sitting for a long time, then dust and dirt may have built up around the vents, preventing the console from cooling itself. If the console cannot cool itself, it overheats and shuts down.
    • 6 Click "Start," "Internet Explorer" and visit the Nintendo repair page (see Resources) to open a repair claim. If you tried the above steps and your Wii has yet to power on, your system probably needs professional repair.
Oct 05, 2011 | Nintendo Wii Console
Breaker tripped and now my nintendo wii wont turn on
Few things to try:
1. Different Outlet. Plug the console into a different outlet in your residence. If the Wii turns on, the outlet is dead. I would recommend an electrician to fix the outlet.
2. Try a different power adapter. You could purchase another power brick or get one from a friend and use the new one to try and power up the console. Also try in a different outlet (step one) to be sure
3. If none of this works, the console may have just received too much power and burnt out the power supply. Contacting Nintendo. Information below:
http://www.nintendo.com/corp/contact.jsp
Mar 06, 2011 | Nintendo Wii Console
I purchased a Wii console about 5 months ago. I never played the thing because I dident have any games. I just recently got a game, went to turn it on and there was no lights and it wouldn't turn on. I...
First, Check your wii adaptor, In normal conditions the wii adapter provides the output 12volt. You can test the output using multimeter or a 12volt lamp.
then
plug it into the outlet, If the light is still off/flashing, disconnect the AC Adapter unplug from the wall outlet, wait 2 minutes and plug it back into the outlet. Turn the console power ON.
hopefully this help..
Mar 05, 2010 | Nintendo Wii Console
Console will not power up
Try to reset the AC adapter.
Unplug everything from the console, then unplug the power cord from the Wii and the wall outlet. Let it sit for 60 seconds and plug it back in.
Aug 02, 2009 | Nintendo Wii Console
My wii does not turn on and all connetions are plugged in
Make sure power connection firmly in both ends.
Change power outlet... if plugging in to strip TEST directly to wall outlet.
Try differenct wall outlet.
Try different WII power adapter.
Jul 28, 2009 | Nintendo Wii Console
Wii console will not turn on
aqrtyctr-18
Apr 05, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
