Question about Linksys Wireless-G Broadband Router
Port Fowarding for my Logitech Webcam
I have been trying to manually set up port forwarding for my logitech computer and it's not working. It says I need to:
Forward the ports manually by changing the settings in your router.
You need to forward port 8888 for TCP traffic and port 8081 for TCP and UDP traffic.
I have tried that, but I am still not getting any streaming or http. Can you advise? I'm at a loss. I have a
Linksys WRT310N
  • geekgurl35 Dec 29, 2008
    Thanks, I figured out that I was not telling the linksys which port to forward from (IP address that is). It finally worked and yes I did both entries, so hope this helps someone else. ;)
    President:
  • 623 Answers
Do you know how to do portforwarding in general?
Have a look at the manual - page 21. You can also find it here: ftp://ftp.linksys.com/downloads/NA/userguide/WRT310N_V10_UG_B-WEB.pdf
You should give your computer a static IP address (or enable static DHCP), otherwise the forwarding will fail if DHCP assings a different address to your computer.
Important is that you have two entries, one for port 8888 /TCP and a second one for port 8081 /Both.
If this helped, please come back and leave a comment, to help others with the same problem.
Posted on Dec 28, 2008
How to to instal logitech webcam
Logitech webcam usually comes with a CD to install software and drivers. If you are using windows 7 your computer should recognize Logitech Webcam when you connect it to your computer's USB port! Its necessary to have internet connection for your computer and Logitech webcam is just plug and play that means!
Just connect the webcam to your computer and remaining is done automatically!
Also drivers for logitech webcam are available online at their site www.logitech.com
good luck!
Sep 11, 2011 | Logitech Computers & Internet
My logitech webcam is connected but when i pull up the software it says my webcam is not plugged in
There may be an issue with your USB port.
Try unplugging your camera, Restarting the computer, and then plugging the camera into a *different* USB port. The camera should re-enumerate in your system, and that should fix the problem.
May 22, 2011 | Logitech Webcam
Troubleshooting
Instructional steps to follow
  1. Verify that the Logitech webcam is connected to your computer if your computer doesn't register its existence, if the webcam's power light isn't glowing or if no image shows on your webcam software. The webcam's USB cord should be firmly inserted into an open USB slot. For the best results, use a USB port on your computer instead of a port on a peripheral device like a USB hub or a keyboard.
  2. Adjust your room's lighting if the Logitech webcam image is excessively dark. Logitech's cameras have no built-in light. For the best viewing image, your light source should come from behind the Logitech webcam instead of shining into the webcam's lens.
  3. Quit any open programs other than the software that's using the Logitech webcam if you get errors regarding more than one program trying to use the camera (e.g., a chat software and a voice-over-IP program both trying to use it at once). This can create data problems and software conflicts.
  4. Check for updates to your Logitech drivers from Logitech's support site. The company regularly releases software updates and patches that resolve commonly encountered glitches and problems. Download the patch and double-click it to initiate an automated installation process. Your computer typically needs to be restarted before you can resume use of the Logitech device.
  5. Contact Logitech's webcam support line at 646-454-3209 if you still cannot get your webcam to work correctly. Support technicians are available weekdays from 6 a.m. to 6 p.m. PST and on Saturdays and Sundays from 7 a.m. to 5 p.m. PST. Have your model and 10-digit part number ready. Such numbers are usually located on the bottom of the webcam or on its packaging.
Oct 31, 2010 | Logitech Webcam
When I am on Skype my microphone works then doesn't work. It is a logitech webcam/microphone.
I found this problem on my computer.
I had connected the Logitech into a USB hub then connected the hub to the computer's USB port. Then saved the configuration in Skype didn't work, every time I opened Skype I had to configure the microphone and video setting in Skype again.
The FIX. connected the Logitech direct into the computer's USB port and configured the Skype - Logitech microphone and video save settings. No more problems
Feb 11, 2010 | ASUS M2N-E SLi Motherboard
Logitech Video cam 9000 with Fedora 12, no video is obtained with Skype , which comes up, gets its password, says something about another version, or starts, but does not use video Radha Krishna...
When you connect the Logitech WEBcam to the computer/laptop and configured the Skype Video Options for LogitechWEBcam and when you open Skype again you get a different WEBcam even though had saved the settings.
The fix - connect the Logitech WEBcam directly into the
computer's or laptop's USB port, DON't connect the WEBcam into an USB hub and then the USB hub into the compurer's or laptop's USB port.
Dec 16, 2009 | Computers & Internet
I got logitech web camera it's not working. What should i do? Model Name is Quickcam Go
try this driver:
http://www.logitech.com/pub/techsupport/quickcam/qc1050enu.exe
but first of all uninstall your webcam software if it is installed
unplug your webcam from USB port
install the software
restart your computer
plug in the webcam
and ..... that's it
Jul 08, 2009 | Logitech Webcam
My computer will not let me install software
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 27, 2009 | Logitech Webcam
Need help setting up logitech webcam
Go here and click your webcam. From there you can download the software.
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
Good Luck
Jan 17, 2009 | Logitech Webcam
Logitec Pro 5000 not being recognised by USB Port
Hi .
Had same problem:
uninstall quickcam 5000 v11.50 drivers.
install quickcam 4000 v10.51 .
There is few files missing ( /removed) from version 11.50.
rob
Aug 28, 2007 | Logitech QuickCam Pro 5000 Webcam
Linksys Wireless-G Broadband Router Logo
663 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
