Question about Samsung DVD-R135
Monster Cable 3-way HDMI Switch Reset
I got this thing for Xmas, hooked it up and tried to remote program it.  Nothing would take, but now I can only select (manually) input 1 (TV/Cable) and when I manually select input 3 (Playstation 3) it will swtich, but then switches back to input 1.  I've tried unplugging it, but nothing seems to work.  Anyone know of a manual reset on this thing?  I can't find it if there is and the Monster website doesn't provide any help.
  • swecarnation Jan 16, 2009
    I have the same problem. I followed the directions on the sheet that came with it and it only works all the time on port 1. If I switch it to the other ports it goes back to port one all the time. Any solutions would be great.
  • 192 Answers
SOURCE: Volume on Remote powers TV on and off?
This unit has upgrades available for this set. I am not at my shop now, but, I think the problem you described is usually cured by this upgrade. The set is under warranty, contact: 1-800-Samsung for a local servicer. If you need additional help, respond to this post and I'll reply.
Posted on Aug 26, 2007
ginko
  • 19396 Answers
SOURCE: VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Posted on Jul 26, 2008
SOURCE: PS3 PROBLEM
you may need to tell the ps3 to switch the audio to the optical cable as audio comes through hdmi also. it is in the settings for the ps3 after  you have the optical cable connected, it may be confusing the ps3 and or tv  etc by having 2 audio sources. i have the same setup as you and no problem.
Posted on Sep 12, 2008
SOURCE: Comcast 3 in 1 Universal Remote code for Samsung DVD-V5500
I had the same problem trying to use those three codes with a Samsung DVD-R155 recorder and then downloaded the pdf files for all of Comcast's remotes and came up with two codes (1) 20490 and (2) 21470. The second code worked for me. Hope that this will work for someone else.
Posted on Oct 26, 2008
SOURCE: Can't switch from AV2 to AV1 with Samsung DVD-VR375 DVD Recorder / VCR Combo
To be able to select AV1, you have to first go into the setup menu and set the control set top box setting to OFF. I think you go to the menu >> setup >> features >> set top box control >> select OFF. Note that this has the side effect of erasing any previously stored timer settings.
Posted on May 28, 2009
Monster cable review
make sure that the HDTV is in the right component input .. ( HDMI. 1..2..3..4) ..
Jan 09, 2014 | Televison & Video
Cant get sound to play through speakers? proper way to hook up?
Do you mean HDMI from Monster, if you do ensure that the cable is connected securely to the correct port. HDMI cables rely on both the devices for sending and receiving. Nothing will happen until both devices send the opposite signal. Hope it works for you!
Apr 29, 2013 | Teac AG-V2050
I just bought a HDMI to DVI monster cable. I went
what has happened is normal and you don't need extra software. You have extended the desktop. If you move your mouse off your laptop screen, it will appear on the TV. If you want your TV to show the same as your laptop, go into your system prefs, click Displays, and there should be a new tab in the middle called Arrangement. At the bottom of this window there is a check box that says " Mirror Displays"
Hope this helps
verb
Jun 25, 2009 | Apple MacBook Pro Notebook
Need Help
try connecting A/V rca cable first. go to ur diplay settings and then to video output settings in it select av multi. don't use HDMI settings let it automatically ask u when u plug in hdmi cable. Then switch to HDMI cable. I had a problem like this before with a ps3 that i had bought used. hdmi was set up and it took forever to set it up with rca cords. took many times power on and offs and unplugging video cords for it to reset. . not sure. Now when u plug in your hdmi on any tv it should automatically set up. and you have settings for a/v as backup. the other thing is it could be the just the port or cable.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
No audio on game and blu ray
PS3 is The amazing device by sony but it has some common problems like sound problem, video problem etc.. Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Dec 29, 2008 | Sony Playstation 3 (PS3) Console
Volume control
We forgot the very last step in programming. I tried programming one more time today and it worked so now everything is working correctly!!
Nov 05, 2008 | Audio Players & Recorders
PS3 PROBLEM
bear with me i'm working on a solution for you just be patient we will get it figured out
Sep 06, 2008 | Samsung DLP HL-P5663W 56" TV
PS3 PROBLEM
Maybe it isn't a problem with your ps3, but with the tv. Try resetting it, or asking help in the store you bought it.
Resetting a tv is mostly done by cutting of power for 15 - 30 minutes. Be sure to read the manual.
Sep 06, 2008 | Sony Playstation 3 (PS3) Console
HDMI to DVI cable connection picture problem
You are Just trusting on Monster Cable, thats what your doing wrong. HDMI and DVI are not same formates.
Jul 29, 2008 | Hitachi 51F500 51" Rear Projection...
Samsung DVD-R135 Logo
191 people viewed this question
Jerry Greenberg
Jerry Greenberg
