Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
DTV connection question for Mitsubushi WS55857
I have an older Mitsubuti WS55857 with a DTV component connection that my HD Cable box connects into using R,G,B cables.
I am able to watch 1080I HD cable broadcasts but am wondering if I can hook up a newer DVD that uses HDMI cables using some sort of a conversion connection and watch DVD's in HD?
I'm not quite ready to buy a new TV so any suggestions would be helpful.
  • 30 Answers
Yes, You would need to use a HDMI to Component converter to make the connection. They are in the $200 to $300 range.
Posted on Jun 17, 2009
  • Rick_in_NJ Jun 21, 2009
    There are available HDMI to RGB converters available to make the connection. Look to spend $100 to $150. Search the web for "HDMI to RGB converters"
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Cable box connections
The model listed has only ONE HD input and it is on the rear and marked DTV--it is a component input with red, green, blue and a red and white for audio---cable box would have to have same outputs on its rear.
Apr 18, 2012 | Mitsubishi WS-48313 48" Rear Projection...
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: http://www.hdtvsupply.com/hdtocoad.html . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
Nov 17, 2010 | Mitsubishi WS-65613 65" Rear Projection...
Runco DTV-5800-component to BNC connection problem
component cables have standard RCA fitting on the end. you can however but adapters enc to RCA. these work well are are readily available through eBay
May 04, 2010 | Runco DTV-5800 58 in. Rear Projection...
Where do I plug rca cables from the cable box into an RX-V2500 Yamaha receiver?
Depending on what type of connections your cable box has available you can do the following:
1) If yo only have the standard VIDEO & L R AUDIO connections you can use the DTV connection on the back of the V2500. If your cable box also has an S-VHS connection this would be the same connection to use.
2) If you have COMPONENT VIDEO connections on your cable box then you would still use the DTV connection. Looking at the back of your V2500 the regular DTV RCA connections are just to the left of center. Farther over to the left are the COMPONENT VIDEO connections. They are labeled Y, Pb, and Pr. These allow for the higher needs of HD TV transmissions. If your cable box has these connections then making use of them would allow for the best quality for your picture.
The following website has your manual available for download in case you need it:
http://www.devicemanuals.com/guide/Audio%20and%20Video/Yamaha/Yamaha-RX-V2500-Owner%27s-Manual-TVRBek9UVT.html
Please let us know if you need any further assistance with your issue.
Mar 12, 2010 | Yamaha RX-V2500 Receiver
My menu says dtv Currently unavailable. How do I use the HD feature on my Olevia LT32HV
Do you have a High Definition cable/satellite reciever or a Blu-Ray player? Does your tv have a HDMI input or component or DVi or all of those? Most newer HD components use the HDMI connection. The HDMI connection is a single cable that has both video and digital audio together. The component connection is a connector with three rca jacks that are red, green, and blue. Audio is connected seperately with this connection via red and green rca audio jacks or a digital audio connector. The last is a DVi connector that is found on computers. Some older HD tvs and components use this connection. There are adapters available to turn a DVi connection into a HDMI connection. So if your TV does not have a HDMI connection but your HD reciever does you can use and adapter but you will not have any audio this way without using a seperate connector for the audio.
Sep 16, 2009 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
Protron 42'' LCD TV
If you need to connect to DTV,you must have RCA cable(video/audio cable,could be component video cable and audio left and right!) Also,in order to have that connect it,you need to have a cable box,directv or dishnetwork box that got the component video output. If you are connecting the coaxial to the TV,you are not going to have any signal in the DTV connection,cause there is anything connect it to there!
solutiondoct
Nov 11, 2008 | Protron PLTV-4250 42 in. LCD Television
HD Picture is Scrambled, but Has Sound
I had the same problem
you have to set up the componant on DTV.
the signal my be hd 1080i and the only connection with componant that can support this is the DTV port.
the other componant connections only support 480,
good luck
Apr 06, 2008 | Mitsubishi WS-55711 55" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
65 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
