Diagonal lines through the picture of Samsung DLP set.
This set is about four years old and the warrenty has just expired.
Sometimes the diagonal lines in the picture will clear up after about fifteen minutes.
  • jusbpow Jan 10, 2009
    I had the same problem and now my lines are permanently present.  They run diagonally across the whole screen - looks like from left to right.  My television is about the same age.
  • 790 Answers
Hi
where the line is coming out? from left to right of your screen or bottom to top?
Thanks!
Posted on Dec 27, 2008
I have diagonal lines on the picture of Samsung HLM50
Most likely bulb is not in correctly or a issue with the optical light engine this set uses
Nov 29, 2012 | Samsung HLM507W 50" Rear Projection HDTV
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
I also have diagonal lines running through picture. However, when
HI, the PIP runs through a separate stream and, is separate from the main. these lines are being produced by a failing DMD or, Light engine. You will need to replace this failing board soon. it is failing slowly.
Jun 25, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV bad picture
Some Samsungs have a problem if the set is turned on bfore the input put device due to a firmware issue. Try turning on the device (game, DVD, etc) BEFORE turning on the TV.
Let me know if this helped.
visit my site:
www.mcveyelctronics.com
May 02, 2009 | Samsung HCM5525W 55" Rear Projection...
Poor solder connections, resolder convergence ICs or you may beed to replace them.
Dec 27, 2008 | Samsung HLN5065W 50" Rear Projection...
Diagonal lines through the picture.
I've found the lines caused by the digital board before. Unfortunately it is expensive. I'd recommend running it on HD and it will bypass the faulty circuit. The lamp light flashes telling you the lamp is firing up. As the lamp ages, it will take longer and longer until it fails.
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
Diagonal lines on a Samsung 46" TV
picture is ok /converg.-ok/;diagonal lines on screen; looks like waves.Appear on tv and video modes.I observed same problem on some another tv in my practic,but this case is worse.
Sep 09, 2008 | Samsung HC-P4752W 47" Rear Projection...
Diagonal white lines...
Thats the first stages of the 3 red lights ,the white lines are vertical sheering caused by the vga chip.Microsoft now give 3 years warrenty for the 3 red light error plus if you have only just had it back from Microsoft then it will have deffo got a year on it anyway.
Jun 08, 2008 | Microsoft Xbox 360 Console
Diagonal lines on upper 1/3 of screen
It sounds like the dmd board may be defective but you can try rebooting the set and see if it makes the picture any better...
1 - Turn on the Tv.
2 - Press & Hold the up arrow key on the remote and then press the power button on the front of the Tv.
3 - Tv will reset & reboot
If the picture is the same it's probably the dmd board which is part of the "B" block assembly and I don't believe they're sold separately. The "B" block is about $1100.00 dollars.
Hope this helps!
Bill
Apr 23, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Televison & Video Logo
216 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
