Question about Evga nForce 680i SLI (122CKNF68) Motherboard
Need help on BIOS // flash situation.
Hi, I noticed you were able to solve the problem on this thread: http://www.fixya.com/support/t1372300-bootblock_bios_v1_0_bios_rom_checksum
I have the same problem only I'm stuck at this screen:
Award BootBlock BIOS v1.0
Copyright (c) 2000, Award Software, Inc.
BIOS ROM checksum error
Detecting floppy drive A media...
Drive media is : 1.44Mb
Automatic Load AWDFLASH.EXE .....
!! ERROR -- Floppy Disk Not Found !!
Replace the DISK AND PRESS ENTER
I have a floppy disk inserted with awdflash.exe on it, and P04 Bios from EVGA for my EVGA 650i Ultra Motherboard. I appreciate any help you can give me. thank you so much for your time.
  • cinfman May 11, 2010
    If you are able to get into windows, I would say to use the new Nvidia Control Panel, under the system update option it has where you can update the bios without having to put the file on a disk.
  • Howard Lester May 11, 2010
    Ok, stay away from the bios flash for a bit. Try to boot without the disk in the floppy. Does it boot then? Let me know
  • 79 Answers
SOURCE: please help!!!!!!!!!!!!!!!!!!
check the manual , there is a jumper plug that allows you to move a jumper over to reset the bios to default , ie , the jumper makes a connection between two pins for 10 secds and then replace back to rest position..do this with the pc off and unplugged of corse,
Posted on Aug 08, 2008
  • 158 Answers
SOURCE: bios check sum error
this is a common problem wirth asus motherboards the only thing is to re set the bios to do this romove the power plug from pc wait for 30 second - 1 minute for the static to be removed from board then find the bios battery and remove this then find the jumper that says clr cymos or bios then place the jumper on the opposite two then press on button then place jumper bace to orraginal possition then place the power cord back to tower psu then reboot pc then all will be fine replace battery in the holder enter bios then hunt for all relevent thing like first boot should be hdd then cdrom then floppy drive this is only if you have got one.
to set-up bios properly please e-mail me with your motherboard details and I'll e-mail you back with a list of things you should do to get the bios back to good working order.
Posted on Aug 26, 2008
  • 74 Answers
SOURCE: BIOS CHECKSUM ERROR
Normally a bios checksum error is caused by a dead cmos battery. In a laptop that can be a pain - some are specialty batteries, some soldered directly to the motherboard, etc.
Start the laptop and enter the bois, there usually will be something to tell you what key to press, most of the time it is f2 or f10. Once in the bios set the date, time and boot order, then save and exit the bios. If it boots ok then try to determine what type of battery and it's location on the laptop to replace it.
If you let me know the make and model of laptop I will try to help determine that info and also where you can get the battery. That will more than likely be from eBay....
Hope this helps
Posted on May 02, 2009
ysastek
  • 28 Answers
SOURCE: when i boot the computer what comes on the screen
try replacing the battery on the motherboard.
Posted on May 16, 2009
  • 27 Answers
SOURCE: When I try to boot this motherboard, I get the
You can download the bios from the following site:
http://www.box.net/shared/oxzpvvtu57
Please be careful flashing a bios.
Posted on Feb 17, 2011
I had tried to flash my Gb-k8vt800m board using @Bios and got a bootblock lock up. I had saved the original bios to a file on my desktop prior. I now have that hard drive as a slave in second identical...
99.9% of all computers will never need the bios flashed.
This is printed on the bottom of the gigabyte web site.
Warning:
Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction.
The problem with your computer has nothing to do with the hard drive. You need to repair the bios. There is a way to flash the bios without booting into Windows. I'm pretty sure that a floppy drive is involved. You're going to have to figure out how to flash it back to your original bios that you have saved on your hard drive without booting into windows. There is some info on gigabyte web site about flashing bios. My internet connection is bad today and I can't download very well from that site or I'd give you an address. www.gigabyte.com.tw
Also remember that when you flash the bios all the settings in your bios reset. You should enter setup and click on the "load optimal defaults" Then you need to make sure date and time are right. Need to set boot options. Check that the clock ratio is right for CPU. There are a lot of options in there that can be keeping your system from booting it isn't necessarily a failed bios flash other than not getting the settings right after flashing.
Nov 25, 2009 | Intel Motherboard
Bios rom checksum error
Hai, That message dosn't sound like an error. i suspect the ram is faulty/incompatible and the pc won't boot because of it.
Change back to the old ram and reset the bios (jumber on the motherboard)
Aug 07, 2009 | Computers & Internet
Need to know how to thread the bobbin on the Magnolia 7312!
Hi there noticed you still need help and have been asking for quite sometime, so I am going to try to help you, also if you have no luck on the websites below try asking a premium chat or premium question on fixya.com and you will get guaranteed assistance by our best experts but it might cost you $3-$10 but you will get fast guaranteed assistance ok and we will stick by you
try here, this might help, also ask yahooanswers a question on the top of this website......
http://answers.yahoo.com/question/index?qid=20090115223207AADSKXy
try this website below aswell and contact them to ask how to thread the bobbin, contact button on top of webpage ok
http://www.american-sewing.com/janome-magnolia-7312.html, your very welcome and good luck there, Brett, Fixya
Jul 01, 2009 | Janome MyLock 634D Mechanical Sewing...
Award BootBlock V1.0
Hi.
The BIOS (Basic Input output System) on your motherboard has become corrupted and the computer can't boot normally. The Bootblock is a "failsafe" device that allows the computer to boot far enough to use the floppy disk drive, even though the rest of the BIOS code is scrambled.
How do you think this happened? The most common cause is people trying to "update" the BIOS and messing up the flashing process. Sometimes some particularly nasty viruses can wreck the BIOS code as well.
Now this might be fixable. You will need to download a known good BIOS from Iwill's website and the Award BIOS flashing utility. Then you will need a bootable floppy disk (DOS) to start the computer. You will have to copy the BIOS .BIN file over to the floppy beforehand and the flashing utility. There will be information on the Iwill website on how to flash the BIOS.
Here is a full detailed webpage on how to go about all this:
http://pages.sbcglobal.net/jefn/bootblock.html
I just did a quick Google search using the motherboard details you provided and came up blank ....
If you can't get the BIOS flashed and usable again then I'm afraid it's time for a new motherboard/computer.
Dec 30, 2008 | FIC AZ 31 Motherboard
Satellite A215-S7422 Lost BIOS Password S#y7066387q need to no location of CMOS reset no time for louisville
Hi there, and welcome to FixYa.
Two ways to solve your BIOS problem:
One:
Removing the battery inside for the bios and find the jumper for clearing the CMOS.
Two:
Download your flash BIOS from here:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1852724&rpn=PSAFGU&modelFilter=A215-S7422&selCategory=3&selFamily=1073768663&selModel=1852724%7CPSAFGU
As you don’t have a diskette on your model, you might be able to install it on a memory key, and boot from that, depending on your previous BIOS setup???
/Teis
Do vote before you leave,
Thank you
Nov 28, 2008 | Toshiba Satellite A215-S7422 Notebook
Bootblock
This messages indicates that the BIOS could not be located and loaded up. Normally this happens when the BIOS is corrupted. The corrective action required is to re-flash the BIOS using a DOS bootable diskette in the 1.44 FDD. Aside from the BIOS file, a flashing software is also needed. Pls start here.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 22, 2008 | MSI K9VGM-V Motherboard
Evga nForce 680i SLI (122CKNF68) Motherboard Logo
213 people viewed this question
Top Evga Computers & Internet Experts
Larry Rider
Larry Rider
Josh Levin
Josh Levin
 Ian Kayhan
Ian Kayhan
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
