Question about Cameras
How do I transfer pictures from my computer back on to my camera? Is it possible to transfer pictures back to your camera from the computer?
    Novelist:
  • 121 Answers
This doesn't work for all cameras, but it does work for some cameras.
1) Make SURE you have all the photos in your computer.
2) Put the memory card into your camera and follow the camera's instructions to reformat the card.
3) Take 1 new photo on the memory card.
4) Put the memory card in the card reader on your computer. If you connect the camera directly to the computer instead of using a card reader, then do that now.
5) If your computer tries to automatically copy or move the photos to the computer cancel the process.
6) Use Windows Explorer (or Finder, if you use a Mac) and open 2 windows. In one window, navigate to the drive that represents your memory card. In the other window navigate to the location of your photos on your computer. This is usually in your My Pictures or Pictures drive under your user account.
7) On the memory card you will usually find the photo is in a subfolder, it may be several folders down. There may also be a thumbnail file. To copy files from your computer back onto the memory card so they can be seen in the camera you need to copy the files back onto the card using:
A) The same filename structure;
B) Include a thumbnail file if the camera creates thumbnail files
C) The file needs to be in the right folder structure (determined in step 7 above).
If your camera makes and uses thumbnail files but you don't have them on your computer, then you probably can't get the camera to recognize the files even if you copy them back onto the memory card in the right place.
Posted on Dec 27, 2008
  • 19 Answers
SOURCE: Transferring pictures from computer to camera
Hi Mike. The only way I can think to do this, is with an separate card reader. Then you could take your SD card and load back and forth, from your computer to camera (and vice versa).
hope this helps!
Posted on Dec 23, 2007
JackHeath
  • 1049 Answers
SOURCE: uploading pictures back onto my camera
Set the camera to MTP instead of PTP in the settings menu on the camera. This will allow it to operate as a USB device instead of only interacting with the Nikon software.
Specifically...
Hit menu on the camera, go to the setup menu, and select USB and then make sure it's set to "Mass Storage" and not "PTP". Then connect the camera.
Hope this helps.
Posted on Jul 30, 2008
Tech Jenkins
  • 359 Answers
just copy and paste from computer to the mem card on your camera via my computer
Posted on Sep 24, 2008
  • 11967 Answers
SOURCE: Is it possible to copy pictures back to Sony DSX-W12 from PC?
Why can't you just use your computer to send the prints to the Officejet?
Posted on Nov 10, 2009
lock123
  • 6831 Answers
SOURCE: My camera doesn't transfer pictures to my computer
Hello and welcome to FixYa
Please go to a electronics store and buy a USB card reader. I bought one last week and it cost $0.5 so its cheap as dirt. Then simply remove the card from your camera , pop it into the reader and the pictures will appear on a drive like a flashdrive in your my computer folder.
This is a much better option than using the camera's cable as it is faster , safer , saves on your camera battery and you don't need to install any software or drivers.
Kind Regards
Andrea
Posted on Sep 27, 2010
I have just returned from holiday had no problem with my fujifinepix 500 I transfered pictures to my laptop with no problem however now after replacing card back into camera I can no longer see my pictures...
If you used the camera's software to transfer the pics there is a possibility that all the pictures have been moved to the computer so there could be nothing on the card to view.
Have you tried to take a picture and see if it gets stored to the card? If it stores a picture to the card without error then probably the pictures have moved and not copied.
If the picture will not store to the card then there is a possibility that the card is faulty.
Regards.
Jul 10, 2010 | Fuji FinePix E500 Digital Camera
Can't transfer pictures to computer
Found solution thru a google search, unplugged the camera from the computer, turned the camera off, plugged it back in and then turned it back on, the camera icon finally showed up in the Nikon transfer program
Jan 28, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Nov 09, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
And now they're not on my memory card
Very possible that it is, but I would guess that the answer is no. It sounds like it might have not transferred all the pictures but thought it did. If you have the option set of "delete after transfer" checked, it would explain this problem.
If you have not taken any pictures since the transfer, you can check the memory card for deleted files. If you have taken new ones since, then there is a possibility you have overwritten the ones you are looking for.
The program I use to undelete files that have been deleted from the recycle bin is free and can be downloaded from the following link.
http://www.softpedia.com/get/System/Back-Up-and-Recovery/Restoration.shtml
But you will need to put your camera memory card into a card reader rather than using your camera to do the transfer. I would also check your C: drive for deleted files.
Another suggestion is to do a search of your entire hard drive for ".jpg" or the file extension your pictures are taken in.
Hope this helps.
Sep 12, 2009 | Kodak EASYSHARE M1063 Digital Camera
Is it possible to transfer pics from computer to SD? I have a lot of pics saved on my computer (My pictures) and I'm trying to put them on an SanDisk (SD) in my camera. Camera is connected to computer. I'm...
Hi there.
Yes you can put a few pictures on the SD card, you can transfer pictures back and forward while the camera is connected to the PC or you can transfer them via a card reader.
Thanks for choosing FixYa!!
Jun 08, 2009 | Kodak Easyshare C813 Digital Camera
Kodak 1063 Not transferring all Pictures
Charge battery full
Then TAG the pictures with as many tags possible. Up to 10
Make new tags.
then Protect and Favourite the pictures videos etc.
Then transfer again to your "file" on computer. and check for the numbers are continius. Delete the dupl;icates that show with the 2 zeros "00"
Vitally
May 27, 2009 | Kodak EASYSHARE M1063 Digital Camera
Can I transfer pictures off my computer to my camera?
This is not possible in most cases of cameras.Sorry
Please rate my responce and help keep this a free site!
Jan 03, 2009 | Kodak EasyShare CX7525 Digital Camera
Transferring photo from computer to memory stick
Many cameras will not let you write to the card. Try using a card reader, which will make the memory card appear to the computer as a separate hard drive.
Nov 15, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Silly question
theres a link in the pentax program on the computer that comes up when u plug the camera in, instead of getting photos from ur camera to the computer, u can transfer them onto the device
Mar 16, 2008 | Pentax Optio M40 Digital Camera
hope this helps!
Dec 17, 2007 | Kodak EasyShare Z740 Digital Camera
Cameras Logo
233 people viewed this question
Top Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
