Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Need thermocoupler for GTI Gas Technology fireplace insert
Model number 8000TV; serial # 2458
    Problem Solver:
  • 5 Answers
Contact your nearest Heat-N-Glo dealer for part #446-511 thermocouple. If you need a thermopile thats part #2103-512. To find your nearest dealer go to www.heatnglo.com
Posted on Jan 26, 2009
I had a heating company look at my 22 year old gas fireplace. He tried something, but if it doesn't work, it would need a new gas valve. How much should a GTI gas valve cost? Thank you.
you will have to shop around as prices vary sometimes very much . If you can find make and model number you could try National Energy they stock parts .
Nov 17, 2016 | Heating & Cooling
Pilot is on, wall switches for both ignition & fas have been changed out. Still get NO flame when wall switches are turned on.
Heat & Glo ' Install & Owners Manuals
www.heatnglo.com/Owner-Resources/Install-and-Owners-Manuals.aspx
Each fireplace, stove and insert has a rating plate which contains your model number and serial number. Gas and wood burning fireplaces have a rating plate in ...
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition ...
? 2:21
www.youtube.com/watch?v=_-8dY8tUGhw
Aug 24, 2012 - Uploaded by HeatandGlo
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition System Video ... Relighting Your Heat & Glo® Standing Pilot FireplaceVideo - Duration: ... How to Install Your New Gas Log Set - The Fire Place - Palm Desert - Duration: ..
Oct 07, 2015 | Heat N Glo 6000 Gas Fireplace Manual
Gas fireplace will not light up
If it has a pilot light, (website says it does) I suspect its the thermocouple. These are easy to change yourself and cheap, you can buy a universal thermocouple and it will be cheaper than a Napolean one. The end of the thermocouple is a fat copper pin that sits poking into a small pilot flame. The heat of the flame on the copper tells the system that the gas is burning ok so it allows more gas through. But after a few years the copper end gets covered in black charring and this slightly insulates it from the heat, so it signals to turn off the gas.
Dec 15, 2013 | Napoleon Fireplaces Napoleon IR3N 24000...
I have an Insta Flame Canadian Fireplace Manufacturing Inc. gas fireplace, installed in 1990. The problem is that when I light the pilot light, it will ignite, but it will not stay lit when the knob is...
sounds as though you need to get the thermocouple(copper wire that sits in the pilot flame) replaced, check first to make sure it is tight at the gas valve end, as they can loosen over time due to expansion and contraction.
Sep 06, 2011 | Heating & Cooling
Looking for user manual for Insta-Flame H20 fireplace
The Insta-Flame burner was a product of Majestic Fireplace/Vermont Castings, which went bankrupt and is no longer in business. However, Monessen Hearth, bought the gas fireplace and gas log part of the business. But, their new model numbers don't match up yours. If you could provide me with how old your fireplace is , the full Model Number and Serial Number. I may can help you.
Please advise.
Mar 23, 2011 | Heating & Cooling
Vent-Free Gas Fireplace Turns Off
check pilot light to make sure properly in place with thermocouple check gas feed for proper pressure and new doesnt mean free from defects -bad valve,thermocouple,temp sensor
Mar 04, 2010 | Heating & Cooling
Need user manual for Temco Model ADL36-2 Vent Free Gas Fireplace
need a fireplace log for temco fireplace, serial number 10807, model number adl 36-2. middle log is missing.
Dec 21, 2009 | Computers & Internet
I have a Marco Natural Gas Direct Vent Fireplace that you turn on with a wall switch. Lately it will not light when the switch is turned on, this happens about 50% of the time. It is not the switch because...
The only thing a fireplace like your has that could be faulty is the thermocouple or safety switch on the gas valve.
A thermocouple is a likely suspect. Look in your manual for a part number and buy a replacement. Cleaning the old one might work too if it is heavily coated with carbon.
Dec 16, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Propane fireplace insert won't light
Gas apliances have safety features built into them so you don't blow yourself up. The pilot heats a thermocoupler which tells the gas valve there is a flame, open the main gas to the burner. If you can see the flame area of the pilot look for a round post about 3/16 inch in diamiter. This should be directly in the flame, if not bend the bracket so it is in one side of the pilot flame. The thermocouple is attached to a mounting bracket. This will be held in place by a 1/4 inch hex screw. remove the screw and the capilary tube leading to the gas control valve. Before you do anything, close the main gas supply to the fireplace and disconnect the power to the fan. You may need to semi dismantle the fireplace to get the thermocouple. The gas valve end is a brass 1/4 pipe thread plug. Turn the outer nut and remove without twisting the tube. Reverse this order to install a new one. Besure not to twist the capilary tube, tighten brass nut 1/4 turn past hand tight. Your better heating supply house will have these in stock. Restarting the pilot will take a few tries because the gas was off. Your gas suplier would charge about $75 to fix this. if you don't have the proper tools and it dosen't look pretty stright forward don't do it. You could get dead.
Dec 01, 2008 | Heating & Cooling
Need Help
I have a 14 year old GTI fireplace the pilot is lite but when i push the button to turn it on , the fire place does not come on help please
Apr 03, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
2,631 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Steve
Colin Stickland
Colin Stickland
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
