Question about Toshiba TDP-S8U Multimedia Projector
Connecting notebook to projector
I connected the Pc cable provided to the projector and notebook. At startup I can see the Windows XP logon on the tripod screen, but after that the screen goes blank (blue). Could you please advise.
  • Deon Bagley Apr 20, 2007
    Hey Dude
    Thanx so much for the info, Much appreciated..
    Brigadier General:
  • 6,966 Answers
Hi, it is possible that your notebook is set to a high resolution that your projector cannot handle. You may want to try to: 1) run your notebook as is (without connecting to the projector); 2) soon as windows booted up, right click on any clear area of your desktop and click on Properties; 3)Go to the Settings tab; 4) Set the Screen resolution to the lowest possible setting, towards left (less) and the Color quality to the lowest possible. Clilck Ok then reboot. Run once to see everything is OK except your icons are bigger now. Youo can try connecting your projector to see if it works. Hope this be of help to you. Cheers.
Posted on Apr 20, 2007
  • Louie  Role
    Louie Role Apr 20, 2007
    Hi again, if this works, you can try setting the resolution and quality higher one increment at a time. Stop when your projector goes "blue" again, press escape to revert to previous setting. Kind regards.
Installed win 7 but want restore to xp
To reinstall win XP from usb flash drive you need WIndows XP cd, 1 gb flash drive and Novicorp WinToFlash. Download WinToFlash to your computer and follow instructions to transfer Windows XP from cd to flash drive, After that boot your notebook from usb device and select "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon" then install win xp normally, but format C partition. After first start of your notebook boot again from flash drive in "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon". Now windows is starting, go to start/my computer right click on it and go to properties in this windows go to advanced tab and there go to startup and recovery, click on settings, in new window go to edit tab and in new window change the line "multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP" /noexecute=optin /fastdetect" after windows XP write the type of your XP Professional, Home Edition, or Media Center. Now you can remove usb flash drive and boot normally from hdd.
Nov 12, 2012 | Advent 4211c Notebook
Tip
Quit the Registry Editor and log off
Automate the above task using this utility
This tiny utility provides you the option to choose a color from the Color Picker dialog and can reset the logon Wallpaper if you want. Choose your preferred Color and click Apply Background color. Remove Logon Screen wallpaper option clears the logon
How to disable the Windows XP Splash Screen / logo at startup ?
To disable the Windows XP splash screen (logo) at startup, and to see the list of drivers loading at startup, follow these steps:
Click Start, Run and type MSCONFIG
Click the Boot.ini tab
Under Operating Systems section, select the appropriate entry and then enable the /SOS switch in the Boot Options section below
Click OK and close MSCONFIG utility.
The corresponding entry in the Boot.ini file is automatically added. Example given below:
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect
becomes
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect /sos
The /sos parameter displays the names of the drivers as they load during the boot process. Use when startup fails (while loading drivers) to determine which driver is failing to load. See Boot Parameter Reference for more information.
Also see /noguiboot parameter, which can also disable the splash screen.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Not able to connect to (sense) LCD projector
make sure you have all the latest and updated drivers installed for windows XP.
Jul 02, 2009 | Sony VAIO VGN-FE880E/H Notebook
Logon
Go into your BIOS
Set the 1st Boot device preference to CD
Insert your windows XP disk
Boot from CD
Run XP Repair
You do this at your own risk. I am in no way accountable for damage to your computer.
Give me a message if you need further assistance
Blazamane
Jan 07, 2009 | Computers & Internet
Help me...
Hi and welcome to FixYa,
Initially, have you tried pressing Fn + F? keys on the notebook to cycle through the choices; notebook display, notebook display + external, external only. The F? key would be one of the function keys with the small monitor icon.
Additionally, you may want to lower not only the screen resolution but likewise with the screen refresh rates.
Good luck and Thank you for using FixYa. Happy New Year.
Jan 02, 2009 | Dell Inspiron 2200 Notebook
Acer aspire 3610 not booting pass flash screen
you can reinstall os with ur xp.
with xp disk in drive at startup do you get option to boot from cd.
if not go into bios at startup and enable cd boot in boot options as first;save and exit;restart.
I assume you know how to install windows(xp)
Mar 03, 2008 | Acer Aspire 3610 Notebook
Logon
Can you describe the issue ion more detail?
Do you see a startup screen with the Windows Logo? Does the logon screen come up? Does the computer get out of the BIOS startup?
Nov 19, 2007 | Compaq Presario 7478 PC Desktop
Pssword lock out
If you still can't find the solution try this thread: http://www.fixya.com/support/t156781-forgot_administrator_password
Oct 09, 2007 | Microsoft Windows XP Professional With...
Camera detection by windows xp
Hi, You need to connect the cam and PC using 4 pin to 4 pin firewire cable.  After connecting,
Switch on the cam.  Open Windows Movie Maker and import the video from device.
Aug 25, 2006 | JVC GR-D370 High-Band Digital Video Camera...
Toshiba TDP-S8U Multimedia Projector Logo
185 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Timothy Van Der...
Computer Links
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
