Question about Dishwashers
Will not stop draining??
Can anyone help with this problem??
  • Mats_Sweden Jan 03, 2009
    Bench top dishwasher won't stop draining. Impossible to get other programs to work. Doesn't fill, stop etc. regardless of how I turn the program knob. Pulling the plug is the only way to stop it.
  • 640 Answers
Sphion effect,,loop the drain hose up 24 to30 inche,,then let go down..
Posted on Dec 27, 2008
IDW450 dishwasher starts working then after about 7 minutes stops - beeps about 6 times and stops completely - the dishes are wet but the dish washer tablet door is not open . - can anyone help - then on...
There is probably a leak under the tub., Water drips into a catch pan and sets off the beeping. Take the kick panel off the bottom front and see if there is any water in the pan. If there is you can drain it or blot it. BUT this is an indication of a bigger problem. You might want to run it after you dry the pan and see if you can spot dripping water when using a flashlight.
Jun 06, 2013 | Dishwashers
My Splendid Washer/Dryer Mod WE802 will not drain the water. Anyone with suggestions? I cleaned the drain filter, still does not drain water
Might be that the pump mechanism is stopped due to a foreign object (hairclip etc) Ours stopped the other day and it was just a hairclip. Working perfectly now.
Aug 29, 2011 | Splendide 2000S Vented Washer/Dryer
I have a 3 yr old Simpson Eziset 550 Washing machine top loader and it is getting stuck after the first wash cycle. It washes and drains but doesnt switch over to the rinse and spin cycle. Can anyone help...
Hi just read your posting.After the 1st wash cycle the machine drains the water,Is the machine continuous draining?Or does the machine stop the draining and sit there silently?Please reply with additional information and I am sure I can help you.I have worked on this machine alot so if you reply back we can rectify the problem.Looking forward to your reply.
May 14, 2011 | Washing Machines
We have a robinair cooltech 34700z, looking for directions to change pump oil, can anyone help? thanks
For change vacuum pump oil follow the bellow step: Press main menu then keep pressing up or down arrow key till display show "CHANGE VACUUM OIL" then press "YES" key. Now vacuum pump will run for two minute & stop automatically. When pump stop you just open the oil drain cap and drain all used oil from pump (oil drain cap located outside of the machine near high & low side hose). After draining all used oil replace oil drain cap and fill 5 ounce new ROBINAIR vacuum pump oil then press "YES" key and keep filling oil up to middle of sight glass of vacuum pump. Press "STOP" key to complete the process.
NOTE: Do not over fill the pump & do not use any COMPRESSOR oil on the vacuum pump!
Hope this will help you & if it is please vote for my support
Hope this will help you. If so please vote for it. Good luck
Apr 08, 2011 | Robinair Cool Tech 34700Z Recovery,...
Does anyone know why a Miele diswasher will start to wash fine and then stop with the inlet/drain light flashing after a few mins? I looked at the pressure stat at the bottom of motor and when i blow in it...
hi,
you may have something rapped around the impellers of the circulation pump causing low water pressure. the unit will start and stop to try to clear the blockage. if the circulation pump is really jammed the inlet/drain light will light. it could be a faulty pressure switch but they are not common to fail.
Hope this helps
May 21, 2010 | Miele 24 in. G638 Plus Free-standing...
Repalced the coupling and now wont drain
sounds like the motor is locking up and tripping the overload....does it take a while before it will start again.then do the same thing and do you hear a faint click right when it stops? i would remove motor and see if the shaft spins freely.it should not be tight.
Jun 06, 2009 | Roper RAS8445KQ Top Load Washer
WASHER WILL NOT DRAIN IT GETS TO A POINT IN THE CYCLE WHERE IT STOPS AND SHOWS FP CAN ANYONE HELP I LIVE IN FRANCE AND SERVICE HERE IS IMPOSSIBLE TO FIND
hi
first way to check whether the dry hose are blocked or what
second thing is that the water pump malnufacation...
these are the basic causes for draining issues...
thank you........
Mar 06, 2009 | Whirlpool Washing Machines
Candy CNA 145 stops
Found that pipe leading from the drum to the filter was blocked. Machine at first appeared to be draining but on closer inspection was not draining fast enough. Machine now working perfectly. Hope this helps anyone who may have a similar problem.
Jul 27, 2008 | Washing Machines
Washing machine won't drain
i think you can fix it , does it stops when it reaches RINSE cycle ?? if yes , your gonna open the front panel or back panel so you can see inside machine . follow the DRAIN HOSE thats attached to SMALL DRAIN PUMP MOTOR , YOU NEED TO TAKE OUT and check for anything thats blocking the impellers and causing it to stop ( pins , buttons , etc ) let me know by your smile . . . . . .
Apr 22, 2008 | Washing Machines
GE Model WBSE2090A2WW - shut off intermittenly
Does the machine drain on its own or do you drain it manually? The drain pump may be jammed or seized. Try giving the door a light bang with your hand on the handle. The door interlock could be faulty. If the machine starts up after you hit it with your hand on the door handle, the interlock is faulty. Good Luck!!
Sep 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
Dishwashers Logo
83 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
