When I turn my computer on the screen acts as if in sleep mode
The screen on the monitor is yellow when I turn my computer on. It acts as though it's in sleep mode. Is it a monitor problem? This desktop was purchased in 2001. I do not have the model number, but it is a desktop.
  • dinger224 Apr 08, 2009
    when the computer is hooked up to the monitor the monitor is yellow likes it is in sleep mode but when i unhooked the cable from the computer it turns green and comes up and says that the cable is not hooked up hook it back up it does the same thing i got a new video card and tryed that but it does the same thing i have no idea what to do any advice would be a help thanks
    Problem Solver:
  • 6 Answers
It is likely not a problem with the monitor, because the lights indicate that the monitor is turned on.
It may be a video card problem. Do you know if you have a video card, or if it is integrated graphics? Check all of the connections from the monitor to the computer. If you can connect the monitor to another computer and it works, then it is definitely your computer.
Very, very unlikely, but it could be that you're using a damaged cable. If you have another one on hand, try it. If not, don't go and buy one because this likely isn't the problem.
Another thing you could try is turning the computer off, unplugging the power cable (going to your computer), and hold the power button for about 30 seconds. Then plug it in again and power it up.
I posted this solution in your other topic. No need to make more than one.
Posted on Dec 27, 2008
Hit start Alienware computer goest to alien head on screen then straight to sleep mode. Please read
When you say computer clock do you mean the LED read out on the mother board? if so the numbers you are seeing are error codes you will need the mother board manual to know what those codes mean. If you don't have the manual it's possible you can go to the mother board manufacturers web site and download one then you can look up the codes to see what the problems are. Hope this helps
Jul 26, 2012 | Alienware PC Systems Computers & Internet
When the CPU switch on, the system running upto 10 minutes. after that the monitor screen automatically off.
Here is artical I found on how to disable sleep mode on a monitor, this would be for VISTA or 7, if you are using XP it's a bit different. ____________________________________________________________ How to Disable Sleep Mode on a Monitor
Your computer monitor or laptop screen will enter sleep mode after your computer remains idle for a set period of time. You can disable sleep mode if you prefer the screen to remain illuminated. You merely need to change a setting in the Windows Power Management properties box.
Difficulty: Moderately Easy Instructions
  1. Click "Start" and "Control Panel".
  2. Click "System and Security" and "Power Options". This will bring up a new dialog box.
  3. Click the menus to the right of "Turn off the Display" and set them both to "Never". This will disable sleep mode.
Read more: How to Disable Sleep Mode on a Monitor ' eHow.com http://www.ehow.com/how_6953659_disable-sleep-mode-monitor.html#ixzz1CiGFFyLk
Feb 01, 2011 | Acer AL1916W 19" LCD Monitor
I have two questions .On the face of my monitor there are 3 button 1 is ^the other points down and 1 has a square with lines inside can you tell me what these buttons are for and also how can I make my...
the buttons are for channel selection , volume or for scrolling for contrast
the yellow light is sleep mode and you can go to bios set up on starting the computer and set monitor to start from any key operation and from start up
actually it will automatically come from sleep when the pc is turned on as the screen is needed to see the start operation of the pc, give you a welcome message and hold for account log in
Nov 15, 2017 | AOC 416V 24 inch Monitor
Are screen savers good for TFT monitors
unless the monitors are being turned on and off frequently the sleep mode idea is alot more efficient
Mar 30, 2010 | Dell E197FP LCD Monitor
Monitor goes to sleep
go to control panel, display properties, screen saver, turn off,
than go to power options, turn off the "turn off display" option.
Jun 06, 2009 | HP Computers & Internet
Monitor in sleep mode
This problem could be caused by windows or the monitor .You need to hook up your monitor to another computer and see if you get the same response. If you do check and see in the owners manual if there is a control for power management.Find the control and try to adjust it, or turn it off. If all this does not work than you need to take the monitor in for servicing. If the monitor works,you may have a problem with the computer bios or windows itself. Check all power management controls in the bios and window settings and see if you can find the problem.Check the Microsoft website for this problem with your operating system and a solution. Hope this helps.
Apr 08, 2009 | HP w1907 LCD Monitor
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
My screen acts in sleep mode when computer is turned on
Dec 27, 2008 | Computers & Internet
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
Flat monitor is stuck in sleep mode
difficult to say what is sleep mode yellow light green ight blinking light pleas elaborate
May 10, 2008 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
Alun Cox
David Payne
David Payne
