Question about HP LaserJet 1300 Printer
PROBLEMS I HAVE A HP LASERJET 1300 PRINTER TO WORK IN MEDIA PRINTING. I HAVE A PROBLEM WHILE TILING THE PAGES. MY PRINTOUTS COMES OUT IN THREE TILED PAGES. BUT ALL THE THREE PAGES ALIGNMENT IS NOT SAME. THE FIRST PRINTOUT DOESN'T MATCH WITH THE OTHER ONE. THERE IS A DIFFERENCE OF ABOUT 5 MILIMETER. WHAT WILL BE THE SOLUTION?
  • 40 Answers
Please explain what you mean by "tiled" pages.
Posted on May 29, 2007
HP CM2320 MFP blank pages come out with printout
Hi my hp cm2320 nf prints normally and prints when you press the color copy button. But it will printout only blank page swhen you copy black&white. You press the black&white copy button only blank pages come out. Any help
Lang Dibba, Gambia
Jan 30, 2012 | HP Laserjet CM2320nf All-In-One Color...
I just baught HP LaserJet P2050d 2 days ago, the printouts are very poor.
Hi, you have to download the PS driver P2055 network express install.. You will get better printouts..
Oct 02, 2010 | HP LaserJet P2055d Printer
How can i clean the print heads of my HP 1300...i need to print an important report this minute..
The HP LaserJet 1300 does not have a print head. If you are having print quality issues then 9 times out of 10 it is coming from the toner cartridge. Simply swap it out if you have a spare. The only other possible cause is a bad fuser film which can cause double imaging or a problem where some of the print from the top part of a page is reprinted lighter at the middle or bottom of a page.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | HP LaserJet 1300 Printer
PDF files only print in landscape
Found it! The problem was that Adobe was set to print with page scaling set to Tile. Even though you see the preview as portrait (with page setup AND printer setup also in portrait), for Tile, it prints in landscape.
User said this fixed it.
Mar 25, 2009 | Adobe Acrobat® 8.0 Standard Full Version...
HP Laserjet 1300 yellow light flashing
Change the toner cartridge and see if the problem is rectified. Sounds like a part failure in the cartridge. This can happen at anytime, but more so when the cartridge is at the end of its useful life
Jan 23, 2009 | HP LaserJet 1300 Printer
HP laserjet 4350 DTN Folding corners
teflon coating on heat roller in fuser is coming apart. replace the fuser. also check to make sure the paper tray is set to the correct size. this means pull the tray out, remove all paper, look inside to make sure the arrow is pointing directly at the correct media size you are using i.e. letter or legal or whatever you are using. Good Luck! please rate this carefully.
Oct 09, 2008 | HP LaserJet 4350dtn Printer
My HP laserjet 1300 printer Problems
You could be set in draft mode in your printers properties, or, you could be using ECONO Mode.
Sometimes People use PCL Fonts for their printers, and other use PS Fonts. PCL is the typical font type. PS is post script, which Adobe type fonts are used.
If you are set to PS Fonts using MS Word, you might try PCL Font types instead.
Jul 02, 2008 | HP LaserJet 1300 Printer
Printing a tiled document from InDesign
you have check the tile option in print dialog box and select auto justified. now the printer will print tiled documents.
Apr 12, 2008 | HP Photosmart C3180 All-In-One InkJet...
Hp 1300 printing blank margine lines
hello it was your printer fuser asembly problem and in fuser u have teflion flim which was demange so u need to replace teflion flim
Aug 20, 2007 | HP LaserJet 1300 Printer
HP LaserJet 1300 Printer Logo
115 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
