Question about Denon AVR-3806 Receiver
'Intialize microprocessor reset' inside Denon AVR-3806 7.1 Channe
Left rear surround channel is out
  • 395 Answers
SOURCE: Denon AVR-681 receiver
this manual is the same as the 681 the only difference is the front input and power difference. this web sight http://www.usa.denon.com/AVR1602_682_ownersmanual.pdf
Posted on Jan 13, 2008
chie-chie
  • 98 Answers
SOURCE: Denon AVR 3806 - No Power
open unit replace fuse....im sure u have blown fuse..
rate me fixed ok
Posted on Feb 14, 2008
  • 92 Answers
SOURCE: MK Sub woofer to Denon AVR
you caan either buy a SPLITTER OR JUST RUN A SINGLE LINE OUT OF THE RECIEVER INTO THE SUB. BOTH DONT NEED TO BE PLUGGED IN. SUBS ARE MONO NOT STEREO. THERS NOD IFFERENCE IN SOUND
Posted on May 20, 2009
xscrewdriver
  • 246 Answers
SOURCE: My Denon AVR 3806 keeps
Your receiver has short circuit somewhere. The protection circuit shut off the unit to prevent more damage. You can try to disconnect all speakers. If there is not improvement, you need to send your receiver to repair.
Posted on Jul 06, 2009
smarthome2
  • 1114 Answers
SOURCE: Denon AVR-3806 keeps losing video signal.
If your using HDMI, pull it from the receiver and run directly to the TV, then run optical or digital coaxial to your receiver. It's referred to in the industry as a "Handshake" issue. It has to do with firmware and hardware of your receiver and continuous ridiculous updates from the recording industry to protect copyright. Hope this helps. If you still have issues, post a comment and I will help you troubleshoot further.
Posted on Sep 21, 2009
Testimonial: "Thank you for the info. It was very quick and helpful."
Denon avr-1612 keeps shutting off and on
You have an output problem, check outputs for short
Apr 07, 2014 | Denon AVR-1612 5.1 Channels Receiver
Denon AVR 1508 distortion on left channels
I have a different model, but sometimes suffer this when power outages or other strange things happen. Its usually the microprocessor getting confused and not doing its job properly, once none of the speakers came on at atll!
In the handbook, it will tell you how to do a factory reset - that always sorts mine (Same brand, Denon). Just a pain setting it all up again.
You should be able to find a PDF version of the handbook online if your's is misplaced in the house move.
Dec 17, 2013 | Audio Players & Recorders
Denon AVR 600 Subwoofer Test
Can you explain about your system problem in detail.
So that it will easy for us to offer you better solution.
Dec 03, 2017 | Denon AVR-600 Receiver
5ch/7ch stereo in 5 channel mode
Front panel button engaged for 5 or 7 channel operation? Also check front panel rear surround speakers button is engaged. Should get you back to 7.1 unless you have changed the rear surround speaker setup for a 2nd zone, also be sure you have a 7.1 DSP setting enabled.
Feb 22, 2009 | Denon AVR-2105 Receiver
Back speakers with av denon 1908
Plug your rear 5.1 speakers into the surround speaker connections. Be sure to use the AVR 1908 set up menu to set rear speakers (not an amp assign). Hope this helps.
Jan 03, 2009 | Denon AVR-1908
Only sound from Direct and Stereo settings on Denon AVR 788
Other listening modes (dolby, dts, neo6) are decoded from digital signals.
Direct will relay your only your discrete analog inputs - so if you want to use your AVR as an amplifier for those channels, you'll need to supply an input signal in a different manner.
Nov 16, 2008 | Audio Players & Recorders
MID-RANGE DISTORTION
hi it is an amp module failure inside £129.00 plus vat 4 hours to replace total strip out £380.00 total to do these are made by samsung and rebadged horrible things dump it thats my advice regards kirk
Oct 14, 2008 | Denon AVR-3806 Receiver
Dts audio cd
kindly check digital settings on your dvdplayer. The output should be in digital domain. Are u using original dts audiocd or burn dts audiocd.
Oct 01, 2008 | Denon AVR-3806 Receiver
Denon AVR-3806 Receiver Logo
585 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
