Question about Bose Acoustimass 15 System
Geiger counter sound from subwoofer
I have an Acoustimass 15 subwoofer (Serial No 02136499162 0473A). My system has been problem free until a few days ago when my subwoofer began a sound similar to a Geiger counter. Do you have any idea what could be causing this problem?
  • 1 more comment
  • radice511 Dec 27, 2008
    I should add the clicking sound is intermittent almost like an ambient background noise in a movie.
  • radice511 Dec 28, 2008
    BarryMusic,
    Thanks for your response. My system is not wireless. I purchased it about 8 years ago. So, if it is a transistor or chip inside that is developing noise by itself, is this repairable? Or would this type of repair be cost prohibitive and would a replacement be a better option?
  • radice511 Dec 29, 2008
    BarryMusic,
    Thanks again for your assistance. Very informative. I'll give it a go.
I had the same problem. Intermittent geiger counter noise with no inputs or outputs attached, only power. I took it apart, tapping components, trying to isolate, no luck. Paid $140 and sent back to Bose for repair, no luck. Took it back to Bose store and made them keep it for 3 days, they said no problems. Took it back home, plugged it back in and there is was AGAIN. Told my wife it had to be the power. She suggested to unplug the pressure activated heat blanket plugged in for the dogs (same circuit)when it does it again. It worked. I could kick myself in the bASS. Hope this helps someone else.
Posted on Feb 13, 2010
    Scholar:
  • 51 Answers
If it's a wireless system, the circuits are drifting off frequency or could be picking up interference from just about anything. If not wireless, you probably have a part (transistor or chip) inside that is developing noise by itself.
Posted on Dec 27, 2008
  • BarryMusic Dec 28, 2008
    The next step is to disconnect the input from the speaker system, just to make sure it's not the input cable picking up interference, or making its own noise from marginal connections or an intermittent internal short. If the noise continues, then it definitely sounds like a noisy circuit component. I'm not familiar with the inside of this unit, but it's probably the newer surface-mount stuff or even a specialized processor. Cost-effective serviceability depends on whether it uses commonly available parts, or if the parts are specifically manufactured for this particular unit. Unfortunately, you'd have to have a tech look inside of the unit to make this determination. One thing you might try though is to open the unit and tap around with the handle of a screwdriver - you might fix an intermittent connection this way, or at least reveal the defective part. Many marginally-operating parts will also be sensitive to physical shock or vibration. ALWAYS KEEP ONE HAND IN YOUR POCKET WHEN WORKING INSIDE LIVE EQUIPMENT, though I doubt that there will be dangerous exposed voltages in this unit. Just stay away from the larger parts, which will be part of the power supply circuit.
Location of serial number on Bose L1 s1
The serial numbers for the L1® 1S Cylindrical Radiator®s are on the back. The serial number for the Power Stand is on the bottom of one of the legs.
Sorry, I can't help with the Acoustimass system.
Feb 17, 2014 | Bose Acoustimass 15 System
What are the units of measurement used in a Geiger counter?
The Geiger counter uses a few different types of units, mainly mR/r (Milli-Roentgens per hour) and uSv/hr (micro-Sieverts per hour).
Jan 21, 2014 | Measuring Tools & Sensors
When was the Geiger counter invented?
The principle was first discovered in 1908 but the it wasn't fully developed until 1928 by Geiger-Muller.
Bose acoustimass 15 no sound out of left and right speaker
The left and right front speakers may have been blown
Jan 28, 2013 | Bose Acoustimass 15 System
Need new system input cable for acoustimass 10
I've made a diagram of my serial cable. You can easily make one with some speaker wire and a 15-pin d-type female serial connector. Solder the wires as shown in the diagram.
Jan 26, 2010 | Bose Acoustimass 10 III System
Bose Acoustimass 15 subwoofer is completely dead.
Clarify, did it ever work for you? Were both receivers used properly configured for the subwoofer? Did you also test the other speaker moduels running off the subwooferto see if they work?
Speaker Receiver setting
• Left and right LARGE
• Center LARGE
• Left and right surround LARGE
• Center surround* LARGE
• LFE/Subwoofer ON
With an Acoustimass 16 Series II system or upgraded Acoustimass 15 Series IlI system only.
Apr 23, 2009 | Yamaha RX-V663 Receiver
How to make a 15 pin female sound in cable
Ya, here is a diagram I made of my Acoustimass 10 IV input cable. All you need is a female 15-pin d-type connector and a bunch of speaker cable (also one RCA connector for sub connection). Here's my diagram:
Mar 10, 2009 | Bose Acoustimass 10 III System
My sound in cable was missplase and can i make it my self and pls any body can send me the cable structre. pls...........
Here's a diagram of the 15-pin serial input cable that came with my Acoustimass 10 IV system. You just need a 15-pin female d-type connector, one RCA connector and a lot of speaker wire. Here's my diagram:
Acoustimass Subwoofer has a low "hummm" sound when turned on.
Sounds like an inadequate ground wire in the signal cable. You may have to replace the cable between the reciever and bass module. It also, however, may be IN the bass or reciever module.
Aug 04, 2008 | Bose Acoustimass 15 System
Bose Acoustimass 15 System Logo
899 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
