If it is the flip top ph I opened mine very carefully and find that after time opening and shuting them the wee computer plug comes aprt from the flip part... it is like a male and female plug I couldn't bleve thats all it was after mths of it playing up then stop'n all together it sat in the draw for nearly a year be4, I pulled it apart and find the problem its from opening and close'n the ph just open it and plug it careflly back in
Usually when the mobile falls into the water you need to remove everything and immediately take it to a service center so that they will wipe it with some petrol. Now it doesnt work since you dropped it in water only. Check it again with a Nokia service provider.
This solution should help fix the issue. I advise you use the Nokia PC
Suite to backup your phone data prior to doing this reset. Also, you
should download and install Nokia Software Updater and use this to update your phones firmware and software in the future.
Enter *#7370# code from the keypad. and press the Dial button.
Type unlock code 12345 press continue.
Restart your phone.
You should check for updates on the phone at this time Enter *#0000# from the keypad and press the dial button
Select "Options" and then select "Check for updates".
Remember to backup your phone before performing these functions.
