Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Sony Wega 55" Replaced Bulb TV still does not work
Called a repair man that wanted to charge $500 to replace the bulb. Decided to purchase the bulb ourselves are replace. Once we replaced the bulb and turned the TV only red light flashes and the TV does not turn on. The bulb clearly blew because there was white powder everywhere. Is there a reset button or something. Please help Thank you
  • 8 more comments
  • Nancy Williams Apr 20, 2007
    The red light flashes 6 times.
    Thank you I really appreciate the advice.
  • Nancy Williams Apr 21, 2007
    I think my problem is the thermal fuse. Do you happen to know where I can get a service bulletin for my make a model tv and the correct part number?
    Arpi
    my email is nancyjwilliamsgold@yahoo.com
    Thank you I really appreciate the help.
    Arpi
    I Sony TV is a Grand Wega KDF-55WF655 55" rear projection tv.
    Thanks you,
  • Anonymous Dec 28, 2007
    I have the same problem and would like to get the service manual to check the thermal fuse. Thanks
  • Benflo Dec 29, 2007
    I replace the bulb with original one and after that I get 4 red blinking trouble code.What can be wrong.
  • carson44 Dec 12, 2008
    the red light flashes 5 times for us also. If the lamp driver is defective do we just change the lamp?
  • Anonymous Mar 15, 2014
    My SXRD 55" Sony KDS50A2000 bulb was replaced in the old housing. When i turned the tv on after replacing the bulb it flashes green about 6 times, then turn red and flashes 4 times. What is the problem?
  • Anonymous Mar 22, 2014
    replaced the bulb and it still going off with a red light flashing
  • Anonymous Mar 29, 2014
    My TV was left on for more than a week and when I turned on I had nothibg, so I checked the Projection Bulb and it was shattered. Called to order Lamp and told them what was wrong and was told not to replace bulb without replacing Ballast, so I have ne Ballast but can't find where old one is to exchange
The red light flashes 5 times so that means the lamp driver is defect. how do i fix that? please help!!
Posted on May 29, 2008
  • junoalaska
    junoalaska Feb 19, 2014
    What happens if the bulb is flashing four times for a 60" DLP and I replaced the bulb with a sony XL-5300 for it only to come on for a fraction of a second then the bulb to blink red 4 times. The replacement bulb came with the TV I am totally frustrated! I am disabled and cannot afford to spend $4-500.00 on fixing this.What to do?
  • junoalaska
    Is the only solution there is in this society,is to buy a new one? Is everything disposable? Have we really gotten that pathetic that the major Co. in this world trained us invest thousands of dollars and when something breaks just buy a new one? We really deserve what we get if we except that sort of thing when we buy top of the line equipment!
    Sergeant:
    Champion:
  • 326 Answers
Hello, please check how many times the red light flashes. If it is 3 times this means that the lamp cover is not fastened securely. If the red light flashes 5 times this means that the lamp driver is defect. If you need more help please advice
Posted on Apr 20, 2007
  • Arpad Kothai
    Arpad Kothai Apr 20, 2007
    6 times flashing means that the GM board is defect. Please contact the Authorized Sony Service or the technician with best references.
    Best regards,
    Arpi
  • Arpad Kothai
    Arpad Kothai Apr 21, 2007
    please leave me your email. I will try to send you the Service Manual (12Mb).
    Best regards,
    Arpi
Grand WEGA KF50WE610 50 in. Rear Projection HDTV-Ready Television: my sony wega 55'' tv is telling me that the projec...
If you have not done it before I would recommend changing the entire assembly. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains how to fix this and where to get the parts. Thanks for using FixYa and for the generous rating.
hardrocko
May 05, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Red stripe across the top after lamp replacement
I have the EXACT same problem with the same model TV. I just searched online to find a solution and found this post. If anyone knows the answer, please let us know. Thanks!
Jan 21, 2010 | Sony Grand WEGA KDF55E2000 55" Projection...
Intermittant shut down with blinking green light on Sony TV 55"
Hi,Make sure you get the Original Philips lamps since they last 6000-8000 hrs 2-4 yrs,way better then Osram which last 4000-5000 hrs 1 - 1/2 yrs.
Oct 01, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
RED LED FLASHES 5 TIMES PICTURE ON SCREEN DARK-CAN HARDLY SEE IT
Ur tv might need the picture bulb replace,how long this tv had it bulb been replaced?
Sep 29, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
No video but there is audio after replacing bulb
NAKE SURE YOUR FRONT COVER THAT GOES OVER THE LIGHT IS'NT ON TO TIGHT ALSO CHECK THE 2 SCREWS THAT MOUNT THE LAMP COVER MAKE SURE THERE NOT TO TIGHT AND THAT THERE BOTH SCREWED IN THE SAME AMOUNT AND ALSO CHECK THE FAN ON THE BACK OF YOUR T.V. AND CLEAN IT IF NEEDED
Mar 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony 55" rear projection tv
TIGHTEN THE BULB --AFTER YOY CLEAN THE DUST OFF THE BULB VENTS ON THE BULB ITSELF. PROBLEM SOLVED. EASY--CHEAP. Hey it worked for me. My picture was turning off blinking 29 times for picture 37 times for audio. This was the first issue with my KDF-55WF655 since I unwrapped it almost 5 years ago......... ITS STILL ON!!! I hope this helps someone.
Feb 14, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDS-R50XBR1 shutting off
When the lamp becomes weak in this Sony the unit will shut off intermittently. I would replace the lamp and use only an OEM Sony lamp, not an LTI or other knock off. The knock off lamps are of poor quality in my experience and opinion.
Apr 15, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
1,447 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
