I am trying to hard rest my samsung galaxy s by pressing the volume up and then the power button but nothing is happening. Can you please tell me how to do this
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
SOURCE: I WOULD LIKE TO RESTORE TO FACTORY SETTINGS ON MY
go to the menu then settings then security and in security you should see something about restoring to facorty settings
SOURCE: bluetooth makes my samsung delve restart.
i dont know if you're still having this problem or not, but i was and it seems as though i have found a solution.
go to the dialer and type ##33284# and go down to the bottom to bluetooth testmode and click 1. RF Testmode the bluetooth will power off.
SOURCE: How to restore ALL factory settings to the Nokia 2630
my Nokia 2630 Serial Number 354861022927732
I do not restore due I have not known his code
please tell me the code
SOURCE: can u plz tell how
SOURCE: My straighttalk samsung galaxy precedent
Change the settings. In the main menu tab, under accessibility, uncheck the "power button ends call" This will fix the problem. It allows you to pull down the dial pad.
Testimonial: "Outstanding. I followed your instructions and now it works perfectly. Thank you so much."
Published on Jun 3, 2010
