Kenwood KAC-X401M Car Audio Amplifier Logo
brett johnson Posted on Apr 20, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenwood excelon kacx401m
When i power the amp it plays for about 1 second and then the power indicator starts to flash, and there is no sound. can u tell me what the problem is. it's also missing the power slide door, could this be the problem? it worked when i first hooked it up but now it cuts out immediately. any info would be greatly appreciated
  • robforsure Jan 31, 2008
    ya i know what you mean im having the same problem with mine it will turn on for like 10 secs and it will bump the hell out of my car and then shut off
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
564
Points
Actually i have the same amp and the power connector was bad and was blowing fuses. It was a bad solder joint. I took it apart and gooped it up with more solder and now it works like a champ. I tested the resistance on the connectors and the power cable had more than the rest. Not sure if this is the same problem you are having but it worked for me.
Philip Rowney
Level 2:
Scholar:
  • Expert 94 Answers
  • Posted on Apr 24, 2007
Philip Rowney
Expert
Level 2:
Scholar:
Answers
94
Questions
0
Helped
56086
Points
147
Sounds like an overload, amp switches on, can't get enough juice and switches off. Get a friend with a volt meter to measure the voltage at the amp power terminal as you turn it on, if it drops below 10.5v the amp hasn't got enough juice. Some amps can cut out before the fuse blows, so you never know it's an overload. I'm not sure what you mean by a 'power slide door'
Cannot get it to power on How does it work?
Kenwood Excelon DDX9902S DVD receiver at Crutchfield ...
www.crutchfield.com > ... > In-dash Video Receivers Crutchfield Corporation
Rating: 4 - ā€Ž21 reviews - ā€Ž$674.99 - ā€ŽIn stock
Kenwood Excelon DDX9902S Android Auto integrates your phone's app with the ....deliver an ultra-clean signal for adding additional amps for even more power. ...... Only thing I can't get to work with the Apple Car Play is the ITunes radio.
Car Stereos FAQ - Crutchfield
www.crutchfield.com > ... > Car Stereos
Crutchfield CorporationJump to What's the best way to connect the Crutchfield wiring ... - A: Most CDreceivers will play at least ... for example, some receivers work with ... If you can'tfind a new cassette deck ... the remote wire did not power the amp .... KenwoodExcelon KDC-X399 ... 12 tips for getting the best sound quality in your car.
Kenwood KDC-BT362U CD receiver at Crutchfield.com
www.crutchfield.com > ... > All Car Stereos
Rating: 4.5 - ā€Ž174 reviews
A smartphone haven With Kenwood's KDC-BT362U CD receiver, you can ... A newcar stereo offers power that's superior to most factory radios, along with .... Gettingthe installation kit and the wiring harness with my stereo purchase was great. .... Cons: Pandora did not work and I tried contacting customer service and their ...
Kenwood - Car-Audio FAQ
Red light is on and subwoofers dont play but regular speakers play
when you say redlight is on it isnt very clear as the power light for the amp is red...right above the cooling fan are 2 indicator lights and if either of them is on your issue can normally be addressed by faulty wiring, you may have wired the speakers at at an ohm load the amp isnt made for which over time will blow the amp if not right away. Also if you dont have inline fuses and such setup i the system then something as simple *** a power surge could have blown the amp...again since the power indicator(red triangle in the center of the amp) is red it could always be that your head units RCA outputs are bad if you have any hooked up at all.
I have a kenwood eXcelon KDC-X759 and after i hooked it up it just kept flashing code off, and it will take a cd but no sound and the radio works fine
does the cd seem to be working other than no sound? if so, are you running the audio through an amplifier? if you are using an amplifier, you may be using the antenna remote wire (blue) instead of the amp remote wire (blue/white stripe) to turn the amp on. when using the antenna remote wire it turns off when going to cd mode.
On a kac-x650d does the power light stay on or flash
Hello mpredday,
The Kenwood Excelon KAC-X650D power light is ON during normal operation. It blinks blue to indicate BMS selection, yellow for low voltage, purple for DC voltage on the outputs, red for overheating, and green for a shorted or grounded speaker wire.
Hope this helps.
Blinking E-03
somthing is fried on your motherboard
No sound flashing e-02 in window
Turn power off this will release the protection turn power back on if code is still flashing contact kenwood dealer
It comes on but
I believe that the amplifier is in protection mode; more than likely you either have an internal short in the amp or a bad speaker running off of the amp.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
