The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
SOURCE: Sony Cybershot DSC-W100 Digital Camera
This does depent on the software you are using to print the images- The data is in the images the computer programs has to find it. What program do you use to print?
SOURCE: Sony DSC-S40 White LCD Screen - Permanent Fix
Needs a little brute force. Release all screws you can find. At the bottom above the o of the word Sony is a plastic lip (or clip) which you cannot see, but holds the camera together.
Do be affraid to pull a bit and it will come off.
SOURCE: sony dsc-w100 won't turn on even with new battery,
Check for corroded or broken battery contacts.
SOURCE: Hello, I have a Sony Cyber-Shot DSC-R1 from 2002.
Hello
For repair of shutter button you have to contact nearest Sony Service Center, where you will fine Original Button in actual price.
You can get help from this link
https://eservice.sony.com/webrma/web/index.do
Hope this helps, if so do rate the solution
