Question about Samsung SC-L810 Camcorder
Camera does not record sound
When i record on camera, there is no sound on playback. I checked the volume and speaker is on on playback but no sound. I also tried on other camera similiar to mine but there is no sound on tape.
I am seeing a similar problem.  i hear 'blips' but mostly silence.  mine has worked fine for about 3 years and just started about 2 mths ago.  maybe head cleaner?
Posted on Aug 18, 2008
  • 27 Answers
Have you tried hooking your camera up to your tv with the cord it came with and try to see if it has sound that way? maybe the speakers are blown...and if its not the same recorder it was recorded with sound maybe distorted or and even picture can be too so thats no sure way to know if it worked or not...If your camera is or was new guess its not new anymore its been over a year now since you posted it...but I would of taken it back to the store I bought it from and said hey this dont work fix it or replace it thanks...but since this is so far out I would try hooking it up through the tv and make sure you have the cords hooked up properly to your hookups on your tv or vcr whichever you run it through...and the right channel to view and hear the video...
Another thing I would try is through the menu try to find a setting for sound maybe you had it on something like silent movie type or something...
Thats all I thought of hope it helps.
Sincerely,
Rabeka Jo
Posted on May 15, 2008
When recorded on video mode there was no noise on playback
If "noise" is sound, then the problem may be the volume is set strangely or there is no on board speaker. this is common on a lot of cameras. If you've heard sound before and the volume is fine, you either blew out your speaker or it just "broke". Call Panasonic and let them know you have a defective product.
May 22, 2011 | Panasonic Lumix® DMC-FS3 Digital Camera
I recently recieved a Bush Noise Cancelling Desktop Microphone M-013NC , i've plugged it into the back of the computer and turned all microphone volume settings upto full, but when i try using the sound...
There are two separate settings in control panel for record and playback. It appears you have playback enabled but not recording - see below
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 21, 2011 | Audio Players & Recorders
Since installing Microsoft Lifecam VX3000, I have no sound on my computer or on the Lifecam
check your audio out
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Aug 06, 2010 | Microsoft LifeCam VX-3000 Web Camera
Camera records loud background noise.
Ensure your webcam mic is set as default
Vista
TEST SPEAKERS
Restart computer
If the problem is due to feedback try using a set of headphones
Jun 06, 2010 | Logitech Webcam
Audio
Set the mic as default
Plug in the webcam
TEST SPEAKERS
Restart computer
May 30, 2010 | Logitech Quickcam Chat Webcam
Sound won't work
make sure the webcam mic is set as default - especially importsnt if you have laptop with a built in mic as well
TEST SPEAKERS
Restart computer
Configure to your chat program
May 02, 2010 | Logitech QuickCam Communicate STX Personal...
I try to record a voice message with lifecam vx-1000 but when I try to playback to check the message I don't hear anything. I have checked all the volumes & they're all fine. so why can't I record a...
Set up Audio example
Laptop x webcam/mic x Vista x Yahoo Messenger
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Restart computer
Dec 13, 2009 | Microsoft LifeCam VX-1000 Webcam
No sound on my samsung
if you put a old tape in that has sound in it and it does not playback sound then your internal speaker is bad. easy fix and not to much.
Mar 12, 2009 | Samsung VP-D80 Mini DV Digital Camcorder
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Video was recorded with volume but no sound on playback
Be sure that the camera is able to record with sound. When you mean no sound during playback are you talking about playback thru the camera or playback on computer after you download it. Be sure that your camera has a speaker on it to play sound back or that the volume playback is turned up. Also, to help with your situation a little better when asking for help list the model number and manufacture when ever possible. It will help with lengthy feedbacks.
Jun 09, 2008 | Fuji Cameras
Samsung SC-L810 Camcorder Logo
121 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
