Question about Kenmore 22422 Top Load Washer
MY 25062500 Kenmore Elite spins and clicks but won't drain.
We put a couple of wigs in a pillow case and one escaped. The cycle ended with an"ld"error which,at the time, I thought meant "lid", silly me. I pulled the wigs out and started another load hanging the wigs up to drip dry. Lots of suds and "ld" "ob" errors later, I've drained all the water out and have flushed it several times, but still no drain. I checked the drain hose which doesn't seem to be clogged. Any ideas?
I followed the advice from one of your postings about the Calypso pump, leaning the washer back and removing the bottom access panel. (Be sure to disconnect AC power first!!!). Heeding the warning about "lots of water" -maybe 10-15 gallons!!!-I removed the back access panel and loosened the drain hose, then I put a pie plate beneath it to pool the H2O as it rushed out, cranked up the shop vac undid the hose and let it rip. I filled my shop vac 3 times!). Then I tipped the washer back removed the the pump which is on the right, opened it up and cleaned out the impeller. It works like a champ now. Thank you for your help!!
Posted on Dec 29, 2008
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Won,t spin
A LD (Long Drain) error code means that (more or less), the drain pump is failing.
May 11, 2012 | Bosch Washing Machines
I have an kenmore elite oasis he and the washer has a code - LD. If i try to stop and start it, it just hums.
The LD means Long drain time...that error code coupled with the hum i believe something is stuck in the drain pump preventing it from turning and that is why its humming
GENE
Aug 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite washer does not finish the drain cycle and it shows a LD error and does not finish washing.
LD error is for long drain. The pump filter in the pump assembly is probably clogged. Remove front lower panel, pump assembly is in the front with a cap that unscrews. Once cap is unscrewed you can slide out the filter and clean. Remove as much water as possible from basket before taking off pump cap or else water will come flooding out when filter is removed. Reinstall and run drain spin cycle. Should drain ok.
Feb 02, 2010 | Kenmore Elite HE4 Electric Dryer
My kenmore elite washing machine stop during the spinning cycle and show up ld code
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Dec 02, 2009 | Kenmore Elite 45986 Front Load Washer
I Kenmore Elite mod# 110.22062102
The "Ld" error means long drain. May require a new pressure switch
Aug 03, 2009 | Kenmore Washing Machines
My washer stops at the spin cycle. The LD code
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Jul 16, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I have a kenmore elite top load calypso wash motion at the end of wash cycle it does not spin and flashes a LD on display I have to turn off and just do a spin cycle to to spin dry.
LD (long drain). possible blockage at pump..check to see if pump spline is stripped. also if the drain hose is plumbed in airtight then this may be slowing the draining process.
Jun 13, 2009 | Kenmore Washing Machines
Ld code on any cycle
Feb 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore series 70 washer
On kenmore, which is made by whirlpool, there is a couple of coils attached to a bracket this is called a wig-wag.
they are located underneath the tub. when these coils engage they move a couple of bars, thus selecting agitate, spin, ect. It sounds like one of the coils is not working. Check them for power and continuity, and then go from there.
Nov 05, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
195 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
