Question about Sony Walkman WM-FX290 Personal Cassette Player
My walkman won't turn on !!
I tried to turn it on but it won't. The red light won't even flash. When I press the on/off button the screen remains black. What should I do????
  • 2 more comments
  • Anonymous Jan 21, 2009
    Can please someone tell me what to do my walkman turn on and the red light isnt flashing:(
  • Anonymous Mar 23, 2009
    Same problem its like mine is completely dead
  • Anonymous Mar 28, 2009
    i put some videos on and know it will turn on to the walkman part
  • Anonymous Apr 13, 2009
    my walman now turns off all the time when the title comes up. I tried fixing it after a thousand tries.I had it but screwed it up by plugging the charger back in.
gamerfixer07
  • 344 Answers
SOURCE: PS3 does not turn on. When I press the on button, red light turns green thne to yellow then to flashing red.
This is called a System Error. It is about the same as the Xjunks ring of death. You need to call Sony if you haven't broken your seal yet.
Posted on Jun 25, 2008
gamerfixer07
  • 344 Answers
SOURCE: ps3's green light turns on usually screen stay's black
Call Sony so they can fix it. This sounds like multiple problems. Good luck.
Posted on Jul 03, 2008
nuwan chinth
  • 111 Answers
SOURCE: Sony DAV-C770 Red Light Flashing but nothing is on!
power supply or power amplifire unit problem.give it to repair proffesional.
nuwan.
Posted on Jan 19, 2009
SOURCE: flashing red light
I think this sounds like my problem (need to replace the projector lamp). However, when I hit the "on" button, my SXRD 50" blinks green for about a minute then starts blinking red. Can you confirm the bulb solution? I was very pleased with this sight when my fan malfunctioned. I got the fan in a matter of day's from Sony and it fixed that problem.
Posted on Mar 19, 2009
SOURCE: ps2 turns itself off.
Hi, I had same problem, I just changed the fuse underneath mainboard, 3.15 Amp 120V If it doesn't work change this for 4AMP fuse
Posted on Oct 23, 2009
Why does Lenovo Thinkpad e145 not turn off.red light flashing
For this particular scenario, it is most likely the system board. It is probably still a good practice to pull the battery and AC and try to reset by pressing and holding the power button several times, for several seconds each time, and then re-attaching AC and try to restart.
If the symptoms remain, please contact service for assistance.
Jul 28, 2014 | Lenovo 73P5259 ThinkPlus Preferred Pro -...
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
The Wii turns on but the remote won't connect to the screen...all lights working also, bought a new sensor bar and still nothing...???
Turn on the Wii console, when at the home screen press any button on the wii remote, if the lights on the wii remote remain dark then it needs new batteries.
If the lights all light up at the same time then stop this means you are not synced. Press the 1 and 2 buttons at the same time to sync, this will work if they have been synced before.
If your four lights still blink blue then you need to open the little compartment on the console that is right below the disc tray. Inside is a little red button, press the button. Now open your battery compartment on the wii remote and take out the battery, then press the red button inside. Put the battery back in and the controller should sync up. If you are still having trouble you will need to contact Nintenedo Technical Support.
Hope this helped!
May 16, 2011 | Nintendo Wii Console
Ink red light on . which colour is out?
When red ink light flashes - one or more ink cartridges is low. When you print, a message on your screen will tell you which one(s).
When red ink light remains on - one or more ink cartridges is empty. When you try to print, a message on your screen will tell you which one(s).
Furthermore: When following the procedure for installing a new cartridge, if the red ink light was on or flashing, pressing the ink button will cause the carriage to stop with the cartridge that needs replacing under the "ink out mark" (ink droplet with a slash through it).
Jan 08, 2010 | Epson Stylus C66 Inkjet Printer
My sony ericsson phone wont turn on
When i connect cable USB Sony Ericsson in my computer it have problem and error, can not open it.
How to format short cut key in Sony Ericsson W810i.
Jul 29, 2008 | Sony Ericsson Walkman W810i Cellular Phone
My sony ericsson W810i wont turn ON
G'day, tell me, when you press the on/off button does the infra red port flash a red light? If so the is a software related fault. On my google page: http://trogg07.googlepages.com/. There's a set of instructions that have worked for K800 but apparently it works with any SE phone that uses a DCu-60 Cable. You could try it at your own risk.
Tell me how it goes.
Cheers
Oct 30, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Sony Walkman WM-FX290 Personal Cassette Player Logo
434 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
