Our GE washer still works fine but during the wash/agitation cycle the knocking noise sure seems loud. I took off the front cover and all looks fine although there is some belt dust building up. My question is this washing machine just normally a loud machine or is there something wrong that I should be looking for?
-   During the agitation cycle machine makes a loud screeching and knocking sound...suspect that the bearings are shot. Some oil residue is now collecting on the bottom panel along with belt dust from the friction. Anyone know if it is the bearings or the transmission that needs replacing?
-   nightfoxfx
I believe you must have one of the bottom of the line cheapo washers, as I do--the one with the plastic, rather than steel wash tub and basket? These are pretty poor machines. They cut corners drastically in every part of the design. I've replaced the aluminum hub that supports the spin basket ( the hub is bare aluminum and corrodes within about 5 years use from the highly alkaline detergent, then it fractures under mechanical stress. Then the motor burned out. I was able to get a nearly new motor on ebay for $90 incl. shipping. (BTW, if you need appliance parts try GOOD Appliance on ebay for new and salvaged parts--they're excellent! 100% feedback rating)
However, I now have the same problem--a fairly loud knocking noise during the agitation phases of the cycle. This is cause by a really crappy transmission design that does not wear well. My advice is just ignore it as long as it works and isn't leaking oil and the tub seal is still good. If it does finally go to pieces get one on ebay--that is if you feel up to doing the job yourself since a repair person would charge more than it's worth to install it. I believe new ones can be had on ebay for about $80, some are sold with seal kits.
Bottom line is--if you want a machine that will last you for 15-20 years--don't buy a cheapo model. The front loaders are better as they use far less hot water (energy and water savings) but a good one is going to be anywhere from about $800 to $1600.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for GE WJSR2070B Top Load Washer
Would like to Find out HOW to Adjust the Leveling Legs on this Machine. They have a Machine Thread,...
(More)
Would like to Find out HOW to Adjust the Leveling Legs on this Machine. They have a Machine Thread, they are Plastic, and Have a Dowel Pin through the Top which makes it so You can NOT Turn it. So, How do I Adjust these withOUT having to Open up the Machine? Apparently the Legs are Inter-connected from side-to-side//the Back Ones are a "Pair", and the Front Ones are a "Pair"...at this Point my Machine is about 1 1/8" too Low on the Back to Leve...IF I can Find out HOW to Adjust, then I can Lower the Front Legs, and Raise the Back ones...This Out of Level has Already caused the Centering Straps to Break (which I just replaced)...
the tub will start to spin then cutoff, slow down,the tub will start to spin then cutoff, slow down,...
(More)
the tub will start to spin then cutoff, slow down,the tub will start to spin then cutoff, slow down, then try to start spinning again. It never gets up to spin speed. The drain pump is okay. With the front of the cabinet open, i can see the tub start to spin then the clutch assembly shifts as the speed increases then shuts down.
GE washer Model WJRE5500G0WW, serial OM167469G purchased new on 3/26/07 washer works fine, no...
(More)
GE washer Model WJRE5500G0WW, serial OM167469G purchased new on 3/26/07 washer works fine, no leaking water and then there is water on the floor. water level, amount of soap, amount of cloths all do not seem to matter.
i have a GE Model WJRE5500g0WW washing machine. It is two years old, purchased new. After the...
(More)
i have a GE Model WJRE5500g0WW washing machine. It is two years old, purchased new. After the clothes had spun dry, water was observed on floor. Drain tube checked and okay, not plugged up. Before I open the machine up, any suggestions?
